Control Electrical Devices From Your Android Phone , Arduino and Create Your Own Android App
49,510
105
13
About: I make hobbyist stuffs and play with electronics follow me to know more https://www.facebook.com/arduinolabviewsolidworks https://twitter.com/learnrobotix
Hi , do you want to control all your electrical devices at your home controlled from your android mobile, do you want to create your own app to achieve this task, This post explains step by step procedure to create android app for controlling electrical appliances using MIT app inventor. you don't need to rely on 3rd party to control your home devices. This simply act as a Home automation where you can control everything from your phone. all you need is an android phone , an arduino , bluetooth module ( I've used HC-05) and a Relay.
Supplies:
Step 1: Create Android App Using MIT App Inventor
Follow the steps in the video to create your own android app
Step 2: Arduino Program
Download the arduino program and change it according to your specification and upload the program to arduino.
connect the arduino to the electrical appliances with the help of relay. block diagram for this can be found in the introduction. follow the video below to know how to connect relay and other circuit to arduino.
Step 3: Testing of MIT App and Arduino Program
If you want to control all your devices by voice command here the ible for you to make your own voice control android app and control all your devices and have fun https://www.instructables.com/id/Control-devices-b...
Also check some other interesting projects here: http://www.labviewarduino.in/
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    13 Discussions
    plz let me know how to connect battery to the relay and at what point
    GurumoorthyI
    6 months ago
    how to create the app on Android Studio.I am familiar with that.please help me with required source codes
    SESHUK2
    1 year ago on Introduction
    Can we use 12v,10A relay module ??
    I think some problem is present in the arduino program ?? Serial monitor is not working ?? It is showing Should you select line ending ?? Can you explain this problem ?? Please do reply
    Biku14
    1 year ago
    Unable to write broken pipe !
    This error is showing on android device.
    What should i do
    ankitha123
    2 years ago
    can one use same relay module for both arduino uno and raspberry pi 3.. plzzzzz reply
    maheshgarkhedkar
    2 years ago
    To Mr. Magesh Jaykumar,
    I want to ask you, what will be the total cost of the Project " Control Electrical Devices from Android Phone"
    Prasadautomation
    3 years ago
    how to operate electrical devices through internet
    Ben Stan
    4 years ago
    Is there a option to automatic pair a specific bluetooth module on every klick on a button? :)
    I used 12v 5A 4 relay moudle.. You can use any module as long as it can withstand the output rating.. I used female/male wire connectors.
