Control RGB LED Lights From Your Phone or Web Browser
5,167
123
7
About: Aerospace Engineering student. Freelance developer. Life hacker.
Welcome to my guide on how to control RGB LED lights from your smartphone or web browser by making use of the DMX protocol.
I started this project back in February 2015 because I wanted a better way to control the RGB LED strips than this dreadful remote, while keeping the DMX decoder we were using to power them.
If you want some more background and details, I'd appreciate it if you checked out this original blog post over on my website. And also take a look at the video above for more visuals.
How it works
You start by accessing the IP address of the Arduino (Ethernet Shield) from your browser of choice, at which moment you’re presented with a mobile-ready webpage that looks something like this: a few buttons for your favorite colors and three text fields right below to input any RGB value you want.
Anyway, you select one of the colors, and then the software will encode the RGB color combination as an HTTP GET request, effectively sending the r, g, and b values back to the Arduino, as you can see at this point by checking the URL address:
http://192.168.1.52?r=255&g=255&b=255
After receiving the aforementioned request, the Arduino will generate the corresponding DMX signal to the decoder whose only job will now be to power up the LED strips to the expected color.
Let's get started, then.
Step 1: The Bill of Materials
Let's talk details. Here's a mostly comprehensive list of all the items you'll need to build this kind of system:
  • The RGB LED lights (duh..)
  • A 3-channel DMX decoder (AliExpress)
  • An Arduino Mega 2560 (rev. 3) for the extra RAM it offers over the UNO boards (Arduino)
  • The Arduino Ethernet Shield (Amazon)
  • Cat-5 Ethernet cable and a microSD card for the Ethernet board
  • A MAX485 transceiver (Maxim Integrated)
  • A 100Ω resistor
  • A reliable 12V power supply for the LED strips
  • A 9V / 500mA power adapter for the Arduino (guide)
  • A breadboard, a few jumper wires, and the necessary length 3-wire electric cable to connect the Arduino to the DMX decoder
Step 2: Hardware Setup
Let’s start with the power side of things. Typically in a higher-power LED installation, you’d connect the lights to the 12V power supply of your choice and be done with it. However, in this case, we’ll place the DMX decoder in between, so now the power supply powers up the DMX box and then the LED strips plug into its output.
My specific DMX decoder has 3 pins for DMX input, corresponding to GND reference voltage and D+ and D- signals. Here’s where that 3-wire cable hooks up, connecting the box to the Arduino and electronics.
On the other side of the setup resides the Arduino Mega microcontroller attached to the Ethernet Shield. The board is also connected to a breadboard, which houses all the electronic components, along with 9V power and a Cat-5 Ethernet cable.
Step 3: Electronics
Next up, the electronics. There's no soldering or anything, just a few jumper wires to put this all together in a breadboard.
The whole circuitry is shown in the Fritzing diagram. As explained here, here, and there, this combination of a MAX485 transceiver, a 100Ω resistor, and a couple jumper wires will handle the conversion from the digital output of the Arduino to an electrically-compliant RS-485DMX512 signal.
Step 4: Software Setup
Finally, now that we're done with the hardware side of things we can switch our focus to the software that's running on the microcontroller. If you prefer git-cloning to copy-pasting, you can easily do so as the source code is now available as a repository on GitHub.
The center piece is the library DmxMaster (formerly DmxSimple) by TinkerKit. Once installed via the downloaded *.zip file, it will be responsible for generating the digital output off PIN #3 that plugs into the transceiver to generate the aforementioned DMX signal.
Here's how it's called:
DmxMaster.write(1, 255); // channel (1: r, 2: g, 3: b), value (0 - 255)
Step 5: The Webpage: Index.htm
The webpage itself is just an HTML file stored in the microSD card that I wrote by making use of jQuery Mobile because I'm lazy and I don't like writing CSS.
Notice the file name is index.htm and not index.html. This is by no means an accident, as it turns out the Arduino SD card library has trouble reading files with extensions longer than 3 characters as it uses the legacy 8.3 filename convention.
As you can see above, it consists of 9 direct-access-to-color buttons, a form with 3 text fields for custom RGB input, and an extra large button for turning the lights off. Here's the full code (for syntax highlighting, click here):
<!DOCTYPE html><br><html>
<head>
	<!-- Main -->
	<title>Arduino says: Pick your color!</title>
	<meta name="viewport" content="user-scalable=no, width=device-width, initial-scale=1">
	<meta charset="utf-8">
	<!-- jQuery Mobile -->
	<link rel="stylesheet" href="http://code.jquery.com/mobile/1.4.5/jquery.mobile-1.4.5.min.css">
	<script src="http://code.jquery.com/jquery-1.11.1.min.js"></script>
	<script src="http://code.jquery.com/mobile/1.4.5/jquery.mobile-1.4.5.min.js"></script>
	<!-- Custom CSS -->
	<style type="text/css">
	.centered {
		text-align: center;
	</style>
</head>
<body>
	<div data-role="page">
		<div data-role="header">
			<h1>Pick your color!</h1>
		</div>
		<div data-role="content">
			<a href="/?r=0&g=0&b=0" class="ui-btn ui-corner-all" style="background: black; color: white;">Turn lights off</a>
		</div>
		<p class="centered">As fast as possible...</p>
		<div class="ui-grid-d centered">
			<!-- Buttons for your favorite colors here -->
			<a href="/?r=255&g=255&b=255" class="ui-btn ui-corner-all ui-btn-inline" style="background: white; text-shadow: none;">White</a>
			<a href="/?r=255&g=90&b=0" class="ui-btn ui-corner-all ui-btn-inline" style="background: #FFC800; text-shadow: none;">Warm</a>
			<a href="/?r=255&g=128&b=50" class="ui-btn ui-corner-all ui-btn-inline" style="background: #FFE1C8; text-shadow: none;">Clear</a>
			<a href="/?r=255&g=0&b=0" class="ui-btn ui-corner-all ui-btn-inline" style="background: red; color: white; text-shadow: none;">Red</a>
			<a href="/?r=255&g=60&b=0" class="ui-btn ui-corner-all ui-btn-inline" style="background: #FF6400; color: white; text-shadow: none;">Orange</a>
			<a href="/?r=0&g=255&b=255" class="ui-btn ui-corner-all ui-btn-inline" style="background: #00FFFF; text-shadow: none;">Light blue</a>
			<a href="/?r=0&g=0&b=255" class="ui-btn ui-corner-all ui-btn-inline" style="background: #0000FF; color: white; text-shadow: none;">Deep blue</a>
			<a href="/?r=0&g=255&b=0" class="ui-btn ui-corner-all ui-btn-inline" style="background: #00FF00; text-shadow: none;">All green</a>
			<a href="/?r=0&g=255&b=128" class="ui-btn ui-corner-all ui-btn-inline" style="background: #00FFC8; text-shadow: none;">Bluish green</a>
		</div>
		<p class="centered">... or from 0 to 255</p>
		<form method="get">
			<fieldset class="ui-grid-c centered">
				<div class="ui-block-a">
					<input id="red" type="text" name="r" placeholder="Red" data-mini="true">
				</div>
				<div class="ui-block-b">
					<input id="green" type="text" name="g" placeholder="Green" data-mini="true">
				</div>
				<div class="ui-block-c">
					<input id="blue" type="text" name="b" placeholder="Blue" data-mini="true">
				</div>
				<div class="ui-block-d">
					<input type="submit" value="Go!" data-mini="true">
				</div>
			</fieldset>
		</form>
	</div>
	<footer class="centered"><small>© Pol Mesalles Ripoll, 2016</small></footer>
	</div>
</body>
</html>
As a final remark, you can see that jQuery scripts and styles are downloaded from a CDN instead of being read from the SD card. That's because this approach is simply put waaay faster. And if one day the internet connection cuts out, the webpage will keep working; it just won't look this fancy.
Step 6: The Arduino Sketch: Final.ino and Debug.ino
All this code comes together in the Arduino sketches, a.k.a. the "C++" scripts to be compiled on the microcontroller. If you're new to the Arduino world, this is as simple as writing your code using the open-source IDE, plugging in your board with a USB type-A to type-B cable, selecting the appropiate board model and serial port, and clicking "Upload".
When programming, you just need to keep in mind what libraries to include (DmxMaster, Ethernet, SD) , and whether your code should run once (inside setup), indefinitely (inside loop), or be available globally (outside of any function). Here's the full code, with additional commentary (for syntax highlighting, click here):
#include <DmxMaster.h> // DMX communication<br>
#include <SPI.h> // required for Ethernet library
#include <Ethernet.h> // web server
#include <SD.h> // microSD card access
#define N 24 // max buffer size, corresponding to the response "GET /?r=255&g=255&b=255" (23 characters)
// Ethernet controller
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0xCD, 0xB1 }; // MAC address for the Ethernet Shield (you'll find it on the sticker)
IPAddress ip(192, 168, 1, 52); // a free local IP of your choice - if you want to use DHCP, check debug.ino
EthernetServer server(80); // web server will be running on port 80 for simple HTTP access
// GET variables
char c; // read buffer
String url; // store buffer
File web;
void setup() {
	url.reserve(N);
	Ethernet.begin(mac, ip);
	delay(1000); // wait for everything to be up & running
	server.begin();
	SD.begin(4);
void loop() {
	EthernetClient client = server.available(); // look for incoming clients
	if (client) { // a new client has connected
		boolean newLine = true; // it is, indeed, a new line
		while (client.connected()) {
			if (client.available()) {
				c = client.read(); // will read char-by-char to check for the newline ending
				if (url.length() < N) url += c; // will only keep the "GET" responses, ignore the longer "Referer" ones to avoid confusion
				if (c == '\n' && newLine) { // the HTTP request has ended, now send a reply
					// GET
					if (url.indexOf('?') >= 0) { // check if it's the right "GET" response
						// Obtain each individual R-G-B value and send the corresponding DMX signal to default pin #3
						DmxMaster.write(1, url.substring(8, url.indexOf('&', 9)).toInt()); // R
						DmxMaster.write(2, url.substring(url.indexOf('g', 10) + 2, url.indexOf('&', 13)).toInt()); // G
						DmxMaster.write(3, url.substring(url.indexOf('b', 14) + 2, url.indexOf(' ', 17)).toInt()); // B
					// Send HTTP header
					client.println("HTTP/1.1 200 OK");
					client.println("Content-Type: text/html");
					client.println("Connection: close"); // close connection once we're done
					client.println();
					// Send HTML from microSD card
					web = SD.open("index.htm");
					if (web) {
						while (web.available()) {
							client.write(web.read()); // echo the whole webpage
						web.close(); // finished reading the HTML file
					break; // from while
				if (c == '\n') {
					newLine = true; // it's a new line
				} else if (c != '\r') {
					newLine = false; // still reading that line
		delay(1); // wait for the browser to get the data
		url = ""; // reset buffer
		client.stop(); // close the connection
The "production" code is available as final.ino, while debug.ino will throw a couple more errors if certain conditions aren't met.
Step 7: Voice Control Via "Ok, Google"
If you have followed the instructions up until now, you should already have a fully functioning system. The final—and optional— step is to get the lights to turn on by using your voice.
For this to work, you'll need an Android phone with the Google app installed. You'll also need to download Tasker and the AutoVoice plugin. Everything is explained better in the video, but here's a summary:
First of all, make sure the "Ok, Google" command is enabled on your phone by opening the Google App > Settings > Voice > "Ok Google" detection and turning on the first two options. Also grant AutoVoice access to allow for the Google Now integration by going to Settings > Accessibility.
If you've never used Tasker before, here's an introduction. And step-by-step:
  1. Open up Tasker
  2. Create a new profile with the bottom-right "+" button
  3. Choose Event > Plugin > Autovoice > Recognized
  4. For the configuration, speak your voice command (i.e., "turn on the lights") by selecting "Speak filter"
  5. After saving the changes, go back to the profiles tab, and a pop-up menu will show up; choose "New Task"
  6. Name it as you like and then click the bottom "+" button
  7. When asked to select an action, search for "Browser URL"
  8. Fill in the URL field with the IP address of your arduino followed by the GET request with any RGB values you like. I chose the equivalent to the "Clear" button from the webpage, like this:
http://192.168.1.52/?r=255&g=128&b=50
You can now repeat the same steps for the "turn off the lights" command and any others you'd like to have. Once you're done, you should see something like the above in the profiles tab.
And... that's it. Next time you feel like adding some ambient light, just shout out to your phone "turn on the lights!"... and there will be light.
Step 8: You're Done!
By following this guide you should have been able to build a system that allows for easy control of your RGB LEDs from your web browser or phone via the DMX protocol. If you run into any issues, just let me known in the comments down below and will see what I can do.
I've been using this setup for over a year and it's been rock solid. So far it has only stopped working because of power outages or because someone (read: not me) has kicked the Arduino board and some of the wires have disconnected.
Regarding power outages there's not much I can do, but either 3D-printing a case for the system (Arduino + breadboard) or soldering it into a PCB would make it more resistant, plus dust-proof.
Remember to check the full blog post for even more... and if you've got any ideas to improve this system just let me know in the comments or tweet them to me!
And as always, just keep hacking.
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    7 Discussions
    rafununu
    2 years ago
    I'm not sure to fully understand as this is quite complex. If your goal is to change the light color from a remote device, why are you generating DMX to the controler. The arduino itself is able to furnish pwm on several channels.
    polmesrafununu
    Reply 2 years ago
    So there are certainly other ways to control RGB LED strips with Arduino, but the point of this project was to keep the main hardware setup with the power supply and DMX decoder, and then get a better control experience on top by using the browser or your voice. And I chose to do that by generating DMX.
    Now.. if you want to use any kind of different power control, you should still be able to easily integrate the webpage shown on this instructable. Let me know if you want me to expand on this!
    ayushs12
    2 years ago
    Ok,Thanks a lot
    ayushs12
    2 years ago
    Hi, nice project, any way that ok google could be done with bluetooth??
    polmesayushs12
    Reply 2 years ago
    Hi, so with an Arduino and a Bluetooth shield, afaik you wouldn't be able to build the whole webpage system. However, if you're only interested in "Ok Google", you could make the Arduino send the DMX signal upon receiving a serial request via Bluetooth... and it looks like this app might help with that.
    I haven't tried it, but according to the description, if you link the "Ok Google" command to writing a file called mnt/sdcard/sendtmp.txt in Tasker, you could Serial.read the incoming data on the Arduino (i.e. the RGB color) and then "turn on the lights".
    Let me kow if this works.. and good luck,
