Controlling Arduino Yun With Yun Buddy
28,222
35
9
This is a simple tutorial to show how to set up Yun Buddy.
Supplies:
Step 1: Get the Arduino Yun on Your Network
If you are using a cable all you have to do is connect the Yun to your router.
If you are using wifi it gets a little more difficult.
By pressing and holding the wifi reset button on the board for 3 seconds the board will be set up as a device that your computer will be able to connect to.
Once connected point your browser to arduino.local.
Here you can configure your device to your network settings
Step 2: Uploading the "Bridge" Example to the Board
Open the Arduino IDE.
Make sure it is the latest version that supports Yun found here
http://arduino.cc/en/Main/Software
I
n the menu go to Tools->Ports->Your Yun
Next go to File->Examples->Bridge->Bridge
Upload the sketch
Step 3: Connecting Yun to Yun Buddy
Open the Yun Buddy App and ensure that your device and Yun are connected to the same network.
Enter the name of your device that you set when configuring the Yun
The default name is "arduino"
You can also use the IP address of the Yun.
Step 4: Controlling the Yun
Once the two have connected you will have the option to change digital and analog values as well as read them.
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    9 Discussions
    scalci1
    3 years ago
    when you connect to the Yun, the app crashes!
    Mdbirley
    3 years ago
    I loaded the app to a iPhone 4s and 6plus andI can not make it connect. Both the Yun and the iPhone are on the same network.
    Also the stretch on the Arduino site can not be downloaded. Can I find the sketch elsewhere
    Thanks
    Max
    tedlawson
    4 years ago on Introduction
    Yun bubbly crashes first time you hit a button?
    Any suggestions?
    Ted
    ngranados bermejo
    5 years ago
    Hola, tengo un pequeño problemita espero que me puedan ayudar
    a mi tarjeta Arduino Yun le di reset a la conexión wifi, cuando quise entrar para su reconfiguracion a Internet vía inalambrica me manda la pagina de panel de control
    y solo me pide un password, en la pagina de Arduino encontré que es Yun-XXXXXXX
    donde la X es la mac-address, pero le ingreso la el password pero no me deja accesar para su configuración
    tambien encontre dando la ip /arduino me manda un mensaje y me dice que introduzca un nombre y un password,
    espero que me puedan asesorar que pueda reconfigurar la conexion wifi via inalambrica
    saludos
    Noe
    edward.young
    5 years ago on Introduction
    This instructables page is pretty thin. You don't show anywhere in the instructions where to get it or any details on what it is. The video link is broken too.
    Is it IOS only? I'm looking for an android version.
