Convert Any Radio Into a Guitar Amp
109,628
642
49
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
Turn any radio into a guitar amp.
This is probably one of my favourite hacks that I have ever stumbled across! It’s so simple that anyone with a soldering iron and screwdriver can do it.
All radios have an amplifier built into them – it’s how your able to increase the volume. What this hack allows you to do is to tap into the radio’s amplifier so you can play guitar through it.
You may be thinking why in hell would I want to do that!
Well hacking a radio (especially a vintage radio) gives you the most amazing vintage tone. The distinct “Lo-fidelity” sounds that come out of these vintage radio’s will really surprise you. It’s a real raw and dirty sound which is perfect for playing some bluesy riffs. There is also the added bonus of creating your very own sound as no 2 radios are ever alike.
When you get your hands on a radio that you want to hack, there is a good change that it would have seen some miles. You’ll probably find that the speaker hisses or rattles, the volume jumps around or it has some other left-of-centre feature which is what makes these amps so cool.
So if you have a vintage radio lying about gathering dust, it’s time to crack it open and turn it into something beautiful.
Check out this website - it has some wicked ideas on how to convert radio's into amps and is a great source of information
Step 1: Check Out the Video
Here's the amp in action. Excuse my lame playing - its been awhile since I picked-up the axe...
I have also recently hacked another radio I found and made a video of it. This is the second clip I go through how I repaired and added a jack to the radio. So if you can't be asked reading the ible' then just watch the clip!
I'm having issues with posting clips so if you don't see the right one then try either of the 2 links below
Link 1
Link 2
Step 2: Things to Gather
Parts
1. Vintage radio - check out your local thrift store or op shop. If you have no luck at these places, then there is always eBay!
2. 1/4 mono, input jack - eBay
3. Wire - any old lengths
Tools:
1. Soldering Iron
2. Guitar
3. Guitar cord
4. Drill
5. Screwdriver / Phillips head
Step 3: What Type of Radio Is Best?
I'm no expert on this hack, but after some research and a little experimentation, there are some radio's that will work better than others. Below I have included some notes on what to look for when your out searching for a vintage radio to convert.
The radio that I hacked isn't anything too vintage, but I wanted to start on something that didn't matter if I messed it up or not. The second radio was a little more older but I found that this was even easier to hack! The back just clipped off and there as some cardboard hiding all of the electronics!
Types of radio's
There isn't really many radio's that can't be modified into an amp. The trick is to find one that has some style and is large enough to pump out some decent sound. You can modify small transistor radios but you'll probably find that they aren't very loud or have any distortion. Reason being that they are too compact. If the radio has no handle and a wrist strap or is in a little leather case it will be a bit too small to waste you time with. This is due to the small, crappy speaker that they come with. Look for a radio that's at least 5 by 5 inches or so with at least a 3 inch speaker that will ensure the speaker is big enough to have an effect on the tone.
Batteries
The size and quantity of the batteries that the radio takes will effect the tone!! The bigger the size of battery the fuller the tone and the more volume the radio will have. Try and find a radio which takes "C" or "D" batteries as these will give you the best result. Radios which take a 9v or AA batteries won't give you the best sound. It is definitely worth though experimenting and seeing what type of sound you can get out of the small "transistor" type radio's. You never know...
Step 4: Pull Apart Your Radio
The first radio that I did the mod on was more of a recent one. I didn't want to screw-up a vintage one on my first go. Turns out it's really quite a simple hack, especially if you have AM and FM, but more on that later. It also turned out that this modern radio has amazing tones and overdrive!
Steps:
1. First un-screw all of the screws holing the radio together.
2. With a screwdriver, lever off the knobs and switches. They should pop off with some jiggling.
3. Gently remove the cover making sure that no wires are pulled out.
4. Lastly un-screw the circuit board.
Step 5: Wiring the Jack and Identifying the Volume Pot
When deciding on where to add the positive wire on the voltage pot, you need to do a little bit of testing. There are usually about 5 solder points that the voltage pot has, and the wire from the jack will need to be soldered to the right one for the amp to work. Don't worry, it's really simple. I promise anyone can do this, even if you know absolutely nothing about electronics.
What is a volume pot? Damn good question! The simple answer is it's the thing that you turn to increase or decrease the volume. You can see from the pictures that the solder points are easily recognisable. Locate this on the circuit board.
Steps:
1. Solder 2 wires onto the solder points on the female jack. make sure that there is a bit of length on each one. You can trim them later
2. Plug in a guitar jack, making sure that the other end is plugged into your guitar.
Step 6: Testing and Soldering
The next steps involve attaching the wires from the jack to the inside of the radio. On my first radio I followed the below steps. On my second however I accidentally messed the wiring up and everything still worked! I'll go through how I wired this one up first and then let you know what I did on the second.
Steps:
1. One of the wires needs to be soldered to a negative point on the radio. The easiest place to solder the wire is on the negative terminal inside the battery case. There's already solder there (you'll have to add more though) and it's easy to identify.
2. So which wire on the input jack do you solder on to the negative terminal? Well on a jack the tip is the "hot" section meaning its positive and the side is the negative section. In the pictures I have attached a yellow wire to the negative solder point on the jack. Just solder the end of the wire to the negative battery terminal.
3. Now with your guitar plugged into the input jack, test each of the solder pads on the volume pot. Place the wire on one, strum the guitar and if nothing happens try the next until you can hear the guitar come out of the radio.
4. solder the wire into place and your done with the wiring.
Notes on my second attempt.
On my second attempt on making one of these (documented inthe Youtube clip below) I messed-up the wiring. Throughout the video I kept on calling the positive terminal the negative (very silly mistake!) Because of this I actually added the negative wire from the input jack to the positive terminal on the radio. Surprisingly everything still worked perfectly! Just goes to show how easy this hack really is – you can mess-up the wiring and it still works!
Step 7: Adding the Mono Input Jack to the Case
Steps:
1. Work out the best place to add the ¼ inch jack. The reason why I chose the top was there was a lot of empty space there in the radio. Also, I didn’t want any interference from the circuitry. Probably would have been better to add it to the side but it works either way.
2. Drill a hole big enough for the jack to screw into.
3. Add the jack, test and if everything is working, screw the radio back together.
4. Done! Now go and upset the neighbours.
Step 8: Notes.
his is a really fun and simple hack and I would recommend anyone who has a guitar to try it out. This type of amp is supposed to be perfect for a cigar box guitar so I’m going to have to make one of these next!
If you’re worried about defacing a vintage radio then don’t. You are actually enhancing these things and making them useful again. Think about it, when was the last time you listened to AM? The only time I listen to it is when I can’t get FM on my radio. Oh and my dad sometimes inflicts it on me when his listening to the horse races.
The great thing is you can keep the radio working! The hack doesn’t have to affect it at all. As soon as you take out the lead from the input jack, the radio come straight back on. I bet if you showed someone the radio after the hack they wouldn’t even know what you did.
In Australia it is quite hard to find real vintage radio’s. Virtually all of the second hand and thrift stores I visited had nothing. My first was found down the tip and the second one was purchased at a small county op shop. It seems that one brand really dominated in Australia in the 50’s and 60’s and this was AWA. Other brands like Silvertone or Motorola seem to have not really been distributed here.
The US on the other hand has an abundance of very cool vintage radio’s available. A quick look on eBay will show a huge variety available. The great thing is, most are available to anyone in the world as long as they are willing to pay the shipment costs which can be more than the actual radio.
For anyone interested in going further with their hacks or want more credible info then my ramblings, then check out the below websites
Radio-Guitar-Amps
Cigar Box Nation
Lonesoulsurfer
Tech Contest
Second Prize in the
Tech Contest
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
  • Tape Contest
    Tape Contest
49 Discussions
jb0579
Question 7 months ago
I forgot to ask my question lol. Sometimes I get so preoccupied hoping Donald Trump will choke to death on a chicken bone I lose concentration. Anyway, when I was a kid my friend's dad was kind of an Electronics guy, Electronics wizard type. And my buddy had this Boombox which is what we called them at the time, and it didn't have an earphone jack in it. So my buddy's dad went out, cracked the case open, installed an earphone jack in it so that when my buddy would plug ear phones in, the volume wouldn't come out the speaker. How is this done? How do you know what to solder and where to get it so unless something is plugged into earphone jack the sound comes out the speaker and vice versa?
1 answer
_reallyTiredjb0579
Answer 3 months ago
Basically there will be a positive and a negative going to the speaker, desolder them and resolder them to the positive and negative of a switched audio jacks input. then solder wires between the jacks default output to the speaker. by default now the signal will go to the speakers but putting in something into the jack will break that connection and the signal will travel into through whatever you have put in instead.
if im not helping i think itd be explained in any youtube video or tutorial that aims to teach circuit bending so just look that up.
LarissaM22
5 months ago
hey, nice work there! really nice.
but I was wondering, is the same thing possible with turning a vintage tube radio into a bass amp or would that turn out not so nice?
My grandfather and I are thinking about doing this but he doesn't know much about bass guitars so we were just gonna try it and see but I thought maybe you'd know.
lonesoulsurferLarissaM22
Reply 5 months ago
You shouldn’t have any issues with using a radio with valves. The only thing is you need to be careful because of the high voltages.
ILykMakin
6 months ago
Very cool. Sounds gnarly! First clip doesn't show or say where to tag the blue lead onto the radio Watched both clips. (Get yourself a tuner). ;)
jb0579
How's about finding an old guitar somewhere with a built-in EQ, and running thru that? Or even one of those old Fishman belt clip eq's. Changing phases would be sick. You've got like an old Creedence sound going on! Brilliant! Cheers from America.
filiptrio
9 months ago
Great job! Very good!
agilbull
Question 9 months ago on Step 8
Great job. I did it with a 80s transistor radio
http://www.doctsf.com/grandlivre/fiche.php?ref=246...
This works fine with my Fender Sonoran, which is an electroaccoustic guitar but with my lespaul tribute, the sound is very ligth. My Fender as an integrated preamp, I think this is the point. Do you know how to increase the power of the radio or how to choose the good radio for electric guitar?
ThisGuyLovesToBuild
3 years ago
I did it anyway and it turned out great. Although the volume control is bypassed so you have to control the volume on the divice
darrenhall
3 years ago
Nicely done - again!!!
I have just ordered a lap steel guitar and would like to be able to practice when I am on the move - ya just saved me a load of cash and gave me the ability to get more bluesy soul for my money.
Cheers for the post.
darrenhalllonesoulsurfer
Reply 3 years ago
I am looking around for two - one small one as a portable plug in direct practice amp and another either vintage or a big ole boom box.
This INST has gotta go on the F/B page as a COOL HACK - - practical and a fun little project.
Handyman SWL
3 years ago
Would that work in the same way with old tube amps? If so I guess it would be good to have the radio receiver disable in otder to avoid white noise and static. Any one have done this mod with vintage tube radio?
lonesoulsurferHandyman SWL
Reply 3 years ago
Hey there,
Yes the mod would work with valves. You can disable the radio crystal and that should stop it receiving.
The problem you usually run into with valve type radios is they use AC so you are dealing with high voltage. If your comfortable with dealing with AC then I think using a valve radio would be ideal for this project
