Cool It! DIY Dashboard Cover Under $10
22,842
55
9
About: At the Eureka! Factory, we love making things, and thinking about things, and learning about things, and enjoy helping empower others to a curiosity driven life, too, so we can all live and learn in meaningf...
We live in Florida, and in the summer, our poor old Honda Civic air conditioner struggles to pump out luke cool air, at best. When we're driving on cloudy days, or when a cloud passes across the sun, the A/C is downright chilly. But when the sun's beating down on one of those 90+ degree days on that big black dashboard, the air turns decidedly warm.
On a lark, recently, I tossed one of our folded circular window screens up on the passenger side dash - the ones that spring open and you wedge into the inside of your windshield to help keep the interior cooler while you're parked. Although it made a bit of a reflection on the passenger window, it seemed to at least relieve the some of the relentless heat coming off the dash a bit, and it got me to thinking.
I looked at the springy window cover device and considered if that could be re-purposed, and also at those shiny, crinkly accordion fold versions. But neither was quite what I was looking for. Then I found some silvery gray satin fabric at Walmart. It looked just like the stuff on my springy cover, and was soft and shiny. At $6/yard, I figured it was worth a try.
It took about 10 minutes to create a working prototype and to my great delight, the results far exceeded my expectations! On a 90 degree afternoon, with my super simple dashboard cooler, my vehicle A/C circulated cold air without any trouble at all. I could physically feel the difference between the two sides of the dashboard, with the area under the satin cover considerably cooler.
What follows are the instructions for my little prototype. Results may vary, but if you've got a similar problem, this simple solution could make your summer driving a cooler experience.
Step 1: Materials
You'll need
Step 2: Make Your Dashboard Pattern
Lay a sheet of newspaper across your passenger side dashboard, and trace out the shape of the dashboard. This will be the pattern for your satin dash cover.
Step 3: Cut Pattern
Cut out your pattern and then lay it out on your dash to double check the fit. I chose to only cover the passenger side of the dash, because I wasn't sure about reflection issues with the satin fabric, and the passenger side seemed like a safe test case.
Step 4: Cut Your Satin
Make sure you cut your fabric so that the finished product lays shiny side up on your dash. So if you lay your pattern right side up on the fabric, make sure you've got your fabric right side up underneath it. Conversely, if you prefer to cut on the "dull" side of the fabric, flip your patter over.
Step 5: Double Check Fit
Lay your cut satin across your dash, and trim where necessary (around A/C vents, etc.)
Step 6: Attach Fishing Weights
Attach a small fishing weight to each of the top corners, to help anchor your cover to the dash.
Step 7: Keep Vents Clear
The cover is pretty light and shouldn't really cause any problems here, but make sure your final fit doesn't block the vents across the top of the dashboard.
Step 8: Stow and Go!
Your Dash Cooler is super easy to fold up and store in the glove box or the center console, and then use as needed. When I toss it up on the dash, the little corner weights open it right up to the right place and it stays in place the whole time.
Step 9: Reflection
My biggest concern was reflection on the windshield from the dash cover, which is why I only tried it on the passenger side. It actually wasn't a problem, especially when wearing polarized sunglasses, which almost completely eliminated the reflection. I don't know how it would appear to a passenger (that's the next test), but I do know that enjoying a drive with a well functioning A/C that makes the drive 10 degrees cooler is totally worth it!
Next steps can include:
  • Taking some temperature readings, with and without the cover, for some actual metrics
  • Trying out some different satin fabric hues
  • Finishing the cover with clean edges and customizing artistically
  • Creating a full dash cover, if I can find the least reflective fabric color
Overall, I'm extremely pleased with the result of my homemade dashboard cooler. I'd love to see what others can do with this idea, and hope you'll share back some of your own versions.
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    9 Discussions
    LeslieB33
    Question 11 months ago on Step 3
    I had the same concern about the color reflection issue. Do you think it would happen as much with like beige or white? Also, do you think silver or white works better on the inside the hot car temperature issue? I looked online for ready-made ones and they are all like $50!! Yowza. I have been toying with the idea of using white stick on foam too. think i might try like a test patch just to see what happens with the glue, and like if it will mess up my dash.
    HogHunter
    3 years ago
    As a fellow Floridian I can appreciate the way the sun effects a car's A/C. I never would have thought a simple solution like this would have the results you have gotten. I will make this but I am not sure the fishing weights will work with my truck's dashboard. I don't mind putting Velcro tabs on it so I may end up with that.
    I also wonder what effect the shiny side has as opposed to the lack of heat absorbing dark color. I wonder if just changing the color will have similar results. Perhaps a muted color will have less reflection.
    I'd say it has more to do with the color than the reflectivity. Our Odyssey has a really big black dash, but it has a very glossy finish, which causes the same type of reflection/glare that EurekaFactory experienced with the silver fabric. Even with the sunlight reflecting off of it, it still absorbs a ton of heat. The window shades are shiny in an attempt to keep the sun from getting into the car, but once it's in there, the light will just reflect off the inside of the windshield and bounce farther into the car. If you're buying fabric, I'd go for a light color with the least reflectivity possible. You'll probably still get a little glare off the inside of the windshield - similar to setting a sheet of paper on your dash.
    That could very well be. That's why I suggested trying some different hues - this could still use a few different variations on the experiment. I wondered about the degree of heat reflecting off the glass too, although didn't detect any real issues there on a cursory totally non-scientific examination. Love to see some different variations on this, and will probably keep tinkering with it on my own, but it really has helped.
    We thought about your question while driving around today. I was in the passenger seat and got to evaluate the dash cover from that perspective. It was overcast most of the time we were out, so not the best day to test, but we're pretty sure it's the shiny reflective quality of the silver satin. I wondered about a black satin but then I think we'd be back to same issue as before. It really wasn't that reflective on the window though, even when the sun came out. Plenty to tinker with here, though!
    NaN9
    3 years ago
    Does it affect the car driving in front of you?
    EurekaFactoryNaN9
    Reply 3 years ago on Introduction
    I think I'd have to be in the car in front of me to know for sure! :-) But here's a parking lot shot from the front. I don't think the dash is angled up high enough to bother other drivers though. This is a minimal impact thing, only a couple of feet long and maybe a foot wide. I'll tail a friend sometime in the near future though (on a sunny day), and ask for a front driver report. :-)
    Thanks! I've been driving around with the cover on the dash for the last few days, and it continues to work like a charm!
