Copper Dragon Egg
19,801
290
22
Hello,
When I have seen the rextorn video, I decide to make my own copper dragon egg!
I make no photos of the egg construction :(, but the proccess is exatly the same as the rextorn video.
I will do photos for my next copper egg.
At the end and after 60 hours of work, the copper egg weighs 2,7 kg for 23 cm.
What you will need :
- Styrofoam egg 20 cm like this
- 4 copper plates 20cm*40cm*0.5 mm
- Gas torch like this
- Tin
- Sheet metal hand like this
- black patina for metals
- Metal polish like this
- Cement bag
- One plastic container 40cm*30cm*30cm
Step 1: Do the Egg Print
With the cement, one container, and half of the styrofoam egg do the egg print.
But the cement and some water in the container.
Wait 3-4 min and use the styrofoamto make the egg print.
Wait 10-12 hours after.
Step 2: Make the Copper Egg
Unfortunatly I take no photo of this...But it is not so difficult.
You will have to anneal the cooper.
You will find a lot of video on internet like this
Use the gas torch to heat copper and when it is red, put it quickly in water. Then you can use a hammer and the cement egg print to shape the egg.
You will have to repeat the process (anneal + hammer) a lot of time to get and half of copper egg.
When you have one half, let's go to make the other half.
When you have the two half, you can soldering them with some tin.
Weldone, You have make the most difficult!
Step 3: Make the Scale
Now the proccess is exactly the same than Rextorn video
Before doing this, I make an example with the styrofoam and some paper.
I use 3 cuts of scale :
- 2cm*2cm => red paper
- 3cm*3cm => purpple paper
- 4cm*4cm => green paper
Use the sheet metal hand to cut the copper.
Use the hammer and the cement egg print to give some curve to the scale. Be carreful use some small piece of fabric because you don't want scratch the scale :)
Use the hand sander to make some curve on the scale.
Step 4: Soldering the Scale on the Copper Egg
The proccess is exactly the same than Rextorn video
I use then gas torch to do the soldering.
I begin with the 2*2 sacle, then some 3*3, then all the 4*4, and then the rest of 3*3 scale.
My attempt with the styrofoam and some paper was very hepfull....
Step 5: Finish the Copper Egg!
Before finish the egg, make a lot of example. You really doesn't want make a big mistake!!!!
For the black patina read this thread (in french).
1 => Use white vinegar too clean the egg.
2 => Use the black patina (I recommend to make a test before!!!!)
3 => Polish with the hand sander (Test the polish before used it on the egg)
4 => Use the metal polish (Again make a test before)
Step 6: Find a Beautiful Box
To do :)
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    22 Discussions
    bb4029
    Reply 2 years ago
    Annealing copper is different than steel. You actually do just as the post suggested. Heat and then quench. After you hammer and shape a while it will again become hard and brittle and you will have to anneal it again, maybe several times in the course of the project.
    MSawyerbb4029
    Reply 2 years ago
    When you quench copper it works best if you lower it into the water on edge.
    I don't know why but that is how we anneal copper head gaskets.
    Dennis43
    2 years ago
    Nicely done to you and rextorn, Those are absolutely gorgeous eggs.
    Mholmen
    2 years ago
    This is beautiful! I would love a bowl full of these on my coffee or dining room table. What a great conversation piece.
    ClaudiaC57
    2 years ago
    Stunning! Don't let the trolls bring you down, as you made a beautiful piece.
    I had been hoping you'd made this out of styro and craft foam, then faux painted it using rub-n-buff, ala cosplay weapons -- though that would be nowhere near as robust. But, I think I see some new projects in my future...
    cyprien35ClaudiaC57
    Reply 2 years ago
    The most difficult is to make the cooper egg. I think you can use a 0.3 mm copper plate instead of the 0.5 mm plate.
    It will be easier to make the egg and robust enough to welding scales.
    The 0.5 mm copper plate was good but a little too rigid.
    Perhaps with 0.3 mm there is no need to anneal the plate...just need a good hammer :)
    Patrik
    2 years ago
    Please do not steal photographs from someone else's video! Looks like every singel one of the copperwork photographs starting at Step 2 were stolen straight from the Rextorn video you mentioned.
    It is NOT OK to pass off someone else's work as you own.
    TessB6
    Reply 2 years ago
    Yep., every pic seen was from the other guys video.
    TessB6
    2 years ago
    He stole the guy's screen shots from his video. Nothing seen is his so how can you say his egg is beautiful. It's not his!
    cyprien35
    Reply 2 years ago
    See here :)
    dhall-1
    2 years ago
    So you took a Styrofoam egg, pinned some post-it notes to it, then took 10 screenshots from someone else's video and called it your Instructable?
    Did you even make this yourself?
    cyprien35dhall-1
    Reply 2 years ago
    Yes I make it myself!
    But unfortunatly I didn't take photo of the process. I realize at the end that I can post the process :(
    If you doubt, try to find on internet a cooper egg with a 30 cm flat ruler, or a cement egg print :)
    dumbau
    Reply 2 years ago
    It always amazes me when someone tries to make someone else look like a fool only to prove themselves are an a$$. It only takes a 3 second search on the internet to find out that you do quench copper in water to anneal it.
    and7barton
    Reply 2 years ago
    Actually it's YOU who seems clueless. You anneal copper by heating to a dull reddish black and QUENCH in cold water. The same process is used for brass and aluminium. To anneal steel, you heat and cool down as slowly as possible. With steel quenching hardens it. So annealing copper uses the exact opposite process that you'd use for annealing steel.
    NicolasC69
    2 years ago
    https://www.youtube.com/watch?v=TqF6n-kIugs
    narrowyoureyes
    2 years ago
    Great egg! You should enter this into the wizarding contest!
