Copper Fire Log Heater: Burns Clean With Alcohol!
105,832
477
269
About: Travelling since 2013. I'm currently in Australia for some reason. --- I’m Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack o...
Step 1: Materials
Step 2: Marking Dots
Step 3: Filing Grooves
Step 4: Punching Holes
Step 5: Prepare the Pipe
Step 6: Soldering the Pipe
Step 7: Clean the Solder Joint
Step 8: Corking the End
Step 9: Cutting and Fitting the Cork
Step 10: Nearly Finished...
Step 11: Making a Simple Stand- Finished!
Step 12: WHY IT WORKS
Stay Warm Contest
Grand Prize in the
Stay Warm Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    269 Discussions
    mattccc
    5 years ago on Introduction
    found the instructibile on the web archive with images
    http://web.archive.org/web/20100828162104/https://www.instructables.com/id/Copper-Fire-Log-Heater-Burns-clean-with-alcohol/
    Morana
    6 years ago on Step 1
    There are no steps anymore. What happened? Just header, table of contents and comments. Where is the content?
    nepheronMorana
    Reply 6 years ago on Step 1
    I am very sorry, but the content of the instructable is gone. It's a long story, entirely my fault. It was not able to be restored by instructables staff. I might eventually make a replacement.
    shascho
    If anyone still has this instructable
    it would be great to see it re-posted!
    zappenfusen
    7 years ago on Step 1
    Sounds like a great project. Why am I getting nothing but blanks for pages? Everything but the actual photo's. Anyone have an answer or cure? Have I been banned? My payments are auto deduct, what gives?
    Zappenfusen
    cancandanzappenfusen
    Reply 7 years ago on Step 1
    i getting the same, starts you wondering about the intrisical values of the website.
    ckgarside
    7 years ago on Introduction
    Couldn't you use pearlite as the other 50% of the mix in the chamber to help evarorate the alcohol. I use that method for all my homemade burners and it lights up first time, no preheat required :)
    _Scratch_
    I tried to make this, but didnt use copper end caps, just crimped the ends down... I failed horribly and almost burned my house down. I filled the log with acetone and lit it, but it turned out the crimped ends didnt seal, so acetone leaked everywhere, then the cap I used to fill it spilled, catching the plywood workbench I was working on on fire. So at this point I was scared out of my mind, so I took a spare rag, hoping I could snuff out the fire, but the rag soaked up the fuel and caught fire. I now had a flaming workbench, log and rag that I was swinging around, which incidentally caught the bottle of acetone on fire. I managed to blow everything out before it caught on the surrounding flammable objects, but it was rather close.
    _Scratch_WendyLD3
    Even better, right next to my bench was a entire cabinet of chemicals, flammable ones.
    itsthatsguy
    9 years ago on Introduction
    i wouldn't worry about explosions, if the pressure got to hot then the cork would blow out (much like a spud gun) and leak flaming alcohol on the surface below =)
    Slicerr2
    8 years ago on Introduction
    you can find here
    http://www.sustainlane.com/reviews/how-to-make-a-copper-fire-log-heater/A4PWASUPRVANIR1HKQKU9DIQ2C9O
