Copper Plating Coins
4,347
118
7
About: I enjoy simple DIY projects and enjoy sharing them with others. I'm 33 and I am a sheet metal worker by trade. I really enjoy remodeling and making things. I'm married and have two wonderful children.
Here's the finished result, two quarters, a nickel and a dime
Step 1: Step 1: Gather Materials
First off, I hooked 2 six volt batteries in series. Then using a small Tupperware container, i added approx. 12 oz of water. MAKE SURE THE WATER IS ADDED FIRST!!!!!! Then I added 3 oz of muriatic acid (which I purchased at Menards but can also be found at Home Depot in the painting section). Then I mixed the water with a plastic spoon that I ended up tossing in the garbage.
Step 2: Step 2: Positive and Negative
Hook your piece of copper (I used 1/8", but it doesn't need to be that heavy) to the positive connection on your terminal using alligator clips and the negative side to your coin. and submerge the coin all the way into the acid/water mixture for approx ten minutes. This should leave a nice copper coating!
Step 3: Step 3: Wipe and Polish
After ten minutes, your coins should be ready to go! I wiped them off with a paper towel and polished them with a mixture of baking soda and water and a soft cloth.
For a more detailed version of this instructable, and other diy's please visit my YouTube channel at www.youtube.com/c/adamfleisch
Thanks for looking!!!
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    7 Discussions
    nicamarvin
    2 years ago
    Beautifully done, I've been able to do the same without power(electroless plating) on the same quarters, I will post a how to when I get the chance.
    Ryhorn12
    2 years ago
    I am using this version of the electroplating process with the muriatic acid rather than the copper acetate solution. Does the bubbling stop when the coin is plated sufficiently or is there another way to determine that? Thanks.
    Ryhorn12
    2 years ago
    The term for this is electroplating, right? Does this work with most metals?
    adamf135Ryhorn12
    Reply 2 years ago
    Yes, and the only metal I have found that doesn't work is aluminum
    adamf135LukeR59
    Reply 2 years ago
    Yes, the only metal I've tried so far that has not worked was aluminum.
    live4ktm
    2 years ago
    Very cool. I have to try this.
