Copper Water Feature Sign
1,507
22
watch the video
if anybody has any questions comment down below and I'll do my best to answer them
-Nick
Step 1: Materials
4x8 sheet of copper
4 rolls of 5/8 copper tube
4 rolls of 1/4 copper tube
2 60 lb bags of plaster
2 80lb bags of diamond bright pool plaster
500gph pond pump
Step 2: Cutting and Bending
my buddy works at a steel company and they helped me out a lot
they used a giant shear to cut the leaf blanks and a giant press break
to bend to gutters.
Step 3: Gutter
rivet the cross braces
heat the gutter up and spray down with water to make malleable
strike with hammer to dent and then buff the high spots with abrasives
drill holes big enough for the couplers
solder the pipe couplers through the holes
Step 4: Trees
cut out your tree profile
hit the tree on both sides on a surface that has some give
I made a bag from some old jeans and filled it with rice
Step 5: Leafs
take a 3x5 leaf blank
fold in half
flatten
cut profile of leaf
hammer striations on leaf
heat and quench
open
Step 6: Power Hammer
optional
if you are making a ton of these id recommend making something similar
Step 7: Branches
cut a slit
flux the leaf
solder
bend the smaller pipe around the first branch and repeat
Step 8: Sign
spray adhesive the template
cut out the letters
twist steel wire and place into the pipe for added strength
pound flat
solder letters to flat pipe
Step 9: Plaster and Install
plaster the walls of the basin
chicken wire the inside
1coat of regular plaster
1coat of pool plaster
1coat of masonry sealer
screw brackets into the wall
hang the gutter
attach the trees
insert the branches into the couplers
hook up the pump
run hose up to the gutter
attach sign to trees
Step 10: Finish
fill up with water and watch it go
    • Build a Tool Contest
    • Epilog X Contest
      Epilog X Contest
    • Warm and Fuzzy Contest
    2 Discussions
