Corner Clamp Jig
21,232
516
18
Jig to assist 90 degree corner clamping.
Step 1: Mark MDF
Find some scrap wood or MDF and mark cut lines and drill points.
Step 2: Drill
Drill holes to accommodate clamp heads.
Step 3: Cut
Saw excess wood from corners of jig.
Step 4: Clamp
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    18 Discussions
    willmothclan
    2 years ago
    Great idea, going to make up a set. Thanks for sharing.
    followyourheart
    2 years ago
    Good idea! I could have used this in my shop today. I struggled with gluing a small frame. Will have to make something similar.
    davemilli
    2 years ago
    Lovely idea, but experience has shown that there must be no inside corner, ie there must only be two side at right angles and not joined.
    M L G
    2 years ago
    my only reservation is that might it not be better to drill smaller holes and then jig them as larger perpendicular squares? that way it will be slightly easier and less fidgety when it comes to fitting your clamps and possibly a more even precise pressure can be applied and less chance of slippage as youll be clamping flat rather than on a curve? if that makes sense?
    M L G
    2 years ago
    what a simple yet great idea, well done and Thank you for sharing!
    TomV4
    2 years ago
    Corner clamping isn't easy without a special set up. The clamping pressure really ought to be perpendicular to the glued surfaces for greatest effect. Applying masking tape to the outside of the pieces before gluing and "folding" helps a little. There are also spring clamps with sharp points to apply pressure across the joint.
    This tool is especially useful for ensuring the parts are held at a right angle while gluing. Good work, and thanks!
    steve.oakley.10TomV4
    Reply 2 years ago
    Don't use white / wood glue. use urethane (aka gorilla glue ) or epoxy , then no pressure on the joint is required, just keep the pieces in place until it sets. :)
    zencukeTomV4
    Reply 2 years ago
    About the glue joint; You are right but most commercial jigs are no better.
    antling
    2 years ago
    What I've been thinking of making for sometime now, thanks for the share and I find it as a very helpful tip.
    JAMESM466
    2 years ago
    This would also be useful for dry fitting joints for drilling and securing with screws. When joining corners I always seem to be one or two hands short. Nice job.
    zencuke
    2 years ago
    Nice. Thanks. It doesn't apply pressure to the actual glue joint in the corner which would be better but it sure is simple. Most of the commercial corner jigs have the same problem. I have a couple of cheap commercial ones (much more expensive than this though) and I almost always need to put a strap around the whole thing to apply pressure to the joint. I like this design better. After seeing this my commercial ones are probably headed to the trash. The brand I bought has lots of little complicated parts and builtin clamps which are thin and cheap. (OK maybe I'm the cheap one for buying them in the first place.) but this one has a stronger and better clamping base mostly because it is thicker. You could make an even better one for bigger projects just by gluing two pieces of MDF together first but that probably isn't necessary.
    Yonatan24
    2 years ago
    Great idea! Thanks for sharing!
    kylegilbert
    2 years ago
    This is great. Excellent design.
    Meglymoo87
    2 years ago
    Thanks for sharing :)
    CraftAndu
    2 years ago
    Very simple and useful! Thanks
    artisanerd
    2 years ago
    Great idea, thanks!
