Corner Desk
5,347
93
8
My design for a corner desk
Step 1:
Here I rested the top I cut out of an 8 foot piece of Oak veneer plywood. I wanted to judge how big to cut the center chair area. First attempt I cut it smaller, sat in front and determined that a bigger circle was needed.
Step 2: Setting Up the Top
Here is the final result of the top cut out
Step 3:
Next I wanted to have the uprights look somewhat cool. At least in my opinion. This was my fourth attempt at the design. I used 3/8 inch particle board for this step
Step 4:
Missed a few pictures but this is the result of cutting all of the pieces to put together for the base of the desk
Step 5:
Here is what the final pieces look like when they were glued together. these are upside down. I am using an extra sheet of plywood to work on. It gave me enough of an area to see where to place the pieces. The plywood I used was not finished on one side. I was going to paint it so it didn't matter to me. Had it been veneer on both sides I might have left it all wood.
Step 6:
This is what it looked like with the top on the two sides
Step 7:
In this picture I flipped the top upside down again and put the two base pieces in their spots. I then put down a thin piece of plywood to draw the curve I wanted for the toe kick panel area. I also used another thin piecer of plywood and bent it to the desired curvature. Traced out the line and cut the thin plywood. Taking that cut piece I then traced it onto a 1/2 inch particle board. this gave me the base for my toe kick panel. I figured I had to support the top piece so I cut out some scrap pieces, glued them into place. The top piece will be the same 3/4 inch Oak veneer plywood.
Step 8:
Here is what the steps for the toe kick looks like
Step 9:
Now onto the top again. I decided to round the curved edge that I cut. I used a router to get the basic edge, then used a file, then sandpaper to finish it up. This took some time but I feel it was worth it.
Step 10:
The first picture is all 4 pieces just sitting there. I chose to make the desk in sections so I could get it into a room without killing myself. Second picture is the pieces put together. Final picture is it stained and painted. I ended up painting the bottom shelves black as well.
Step 11:
I had to put LED lighting under the front.
Step 12:
Final installed desk
Step 13:
Here is my desk that I made. I think it is pretty cool. I have enjoyed working on it. I like a lot of light when I do some close up electronic repair work.
Final thoughts:
I wish I had designed the desk with a few drawers. I am planning on making two drawers. One on each side.
I plan on adding some thin plywood with holes cut in it to make a pattern to cover the base a little more. I think it would add a little finishing touch.
Thank you for looking.
Step 14:
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    8 Discussions
    lukesjette
    Tip 4 months ago
    This is really great, I would have gotten thin plywood, painted that black to match the rest, then attached to the back, this would hide the wires. Makes a cleaner look.
    racerx5
    2 years ago
    Awesome desk really nice!
    Swansong
    2 years ago
    Awesome design! I like that the front curves in like that to give you better access to everything.
    Sdlong42Swansong
    Reply 2 years ago
    Thanks, I was tired of the normal desk. I decided one day to build my own. I have never built a desk before but I figured, what the heck. Really wanted a corner desk but could not find anything I liked.
    Sdlong42Dui ni shuo de dui
    Reply 2 years ago
    Thanks, I did the best I could with what I had to work with. Love sitting at the desk.
