Create Floor Plan Using MS Excel
27,721
188
16
About: Hello I'm a hobbyist and crafts enthusiast. I love to share things I know would help solve a certain problem. Hope to share more instructables for you all!
Everyone is familiar with MS Excel, right?. MS Excel being a spreadsheet program is used to store and retrieve numerical data in a grid format of columns and rows. Excel is ideal for entering, calculating and analyzing company data such as sales figures, sales taxes or commissions. Yet did you know that it can be used for creating floor plans? Yes, you heared that right!
This 'ible demonstrate the use of Microsoft excel as a tool in designing any type of floor plan (i.e. house, industrial, plant).
So hover on the rest of the steps and learn how I did it.
Step 1: Set-Up Row and Column
Once we open the spreadsheet, we have to set-up the cells to create grid coordinate so that scaling is easy.
I set the column width to 1 and the row height to 9 units.
This can be done by following the steps below:
  • Select entire cells by pressing Ctrl+A.
  • Right click column letters then select Column Width. Change value to 1 then click 'Ok'.
  • Next while entire cells are still selected, right click row numbers then select Row Height. Change value to 9 then click 'Ok'.
  • Now the grid 'working area' is now ready for layout.
Step 2: Create the Scaling and Wall
This part goes through depending on the design in mind to be implemented.
I decided to create a house layout with 400 square feet area (scaled). I started with the wall. The width is 2 square units. By the way, my scaling for this layout is 4 square units (cells) equivalent to 1 square foot.
To create the lines simply create border lines on the cells depending on the scaling used. I put grid lines (in purple) to visualize the 1 square foot scaling.
Step 3: Start Partitioning the Floor Area
Now that the floor area has been established. I partitioned it by putting walls inside creating rooms in the layout.
I started with the bedroom and living room area. Next I worked with the bathroom and closet. At this moment I added shapes from the Shape toolbar to create figures on the layout (for the lavatory, faucet bowl etc.).
Afterwards, I created partition for the pantry and kitchen adding also shapes to make it look more of a layout .
Step 4: Refine the Floor Plan
I refine the layout by removing the lines connecting the walls making it look as one. I did it by selecting the cells with the 'unnecessary' lines then right click on it. Select the format cells option then go to borders option and remove the unnecessary lines as mentioned.
I eventually end up adding an area for the balcony of my design.
Step 5: Add Color and Last Touches
I colored the layout on some parts. This makes it look more realistic (I guess). Don't forget the labels for each area. Some decorations can be added to improve the look of the design. In my design I added a sofa, a TV, bed, table lamps etc.
That's it for my demonstration of using MS Excel Spreadsheet as floor plan layout tool. One restriction i can see using this tool is that it's limited to horizontal and vertical wall designs. To overcome this, shapes can be used as alternative arranged diagonally.
Hope you enjoyed it!
Thanks for your attention.
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    16 Discussions
    PaulD279
    Question 26 days ago
    I can't follow your instructions on how to set and draw to scale. Could you please elaborate?
    NoBoxEver
    8 months ago
    I've used Excel for ages for its original purpose-- never thought of using it for a planner. I can stop laboriously scratching away on graph paper, which is often unsatisfactory. I can also see its value for creating all kinds of patterns!
    ArtuinoNoBoxEver
    Reply 8 months ago
    yes, creating patterns using excel would be fun as well.
    raphanNancyK85
    Answer 9 months ago
    Nancy, don't post your email never ! You'll be drown in scams.
    ArtuinoNancyK85
    Answer 9 months ago
    Hi Nancy,
    Have sent already your requested excel file.
    sendrakhi
    9 months ago
    Can you please provide us more detailed information how to created this?
    Artuinosendrakhi
    Reply 9 months ago
    Thanks. At what particular part would you want me to provide elaborate information?
    dumb_and_dumber
    9 months ago
    CooL! I just remembered myself twenty years ago. I drew the same plans in Excel.
    But twenty years have passed! You can take freeware Sketchup and make much more and more clearly. Why return to the past?
    Artuinodumb_and_dumber
    Reply 9 months ago
    Well, I guess that's right..this is just a demonstration showing people a different approach to floor plan design using a practical tool already lying around. thanks.
    OutofPatience
    9 months ago
    My sister does this, but hasn't had the patience to teach me how, so I've continued to do it the old fashioned way. But I've wanted to be able to do this, so I greatly appreciate that you have taken the time to write this up. Thank you!
    ArtuinoOutofPatience
    Reply 9 months ago
    Thanks...I have done this before. Just recently remembered doing it and decided to create an 'ible about it.
    Artuinokrn1978
    Reply 9 months ago
    No haven't tried it but may give it a try sometime. the graphics looks great.
    jeanneambro
    9 months ago on Step 5
    I've used Excel for floor plans for years now - never thought of writing an instructable though - kudos to you, and thanx.
    Artuinojeanneambro
    Reply 9 months ago
    thanks. have used it well before in designing my mother's house's renovation.
