Crochet Your Wedding Bouquet
19,482
293
11
My daughter wanted her bouquet made of crocheted flowers.  Flowers are probably one of the easiest and fastest things to crochet.  The time it takes to create a bouquet will depend on the size of the bouquet you want.
Supplies:
Step 1: What You'll Need
Cut a styrofoam ball in half and cover it in lace (you can use a thrifted lace curtain).  Hot glue the lace to the styrofoam ball.
Step 2:
Here is an easy flower pattern I use.
The small five petal flower (my fave) pattern is:
Make a magic ring.
Into the ring:  1SC, CH2, 2DC, CH2, 1SC, *CH2, 2DC, CH2, 1SC*, repeat from *to* 3 more times.  SLP ST into ring and fasten off.  Pull the ring tight. I just knot the ends on the back and cut.
Leaf pattern:
CH 8.  In second CH from hook, SC.  In next CH 1 HDC.  1 DC in next 3 CH.  In next CH, 2 HDC.  In last CH 1 SC.  Turn to crochet on the other side of the leaf.  1 SC in the last CH you just SC in.  In next CH 1 HDC, 1 DC in next 3 CH, then one HDC in next CH and 1 SC in last CH.  Slip st to end to make a point for leaf.  Fasten off.
Step 3:
I used white ball pins to attach each flower onto the styrofoam ball.
Then I cut different types of lace and hot glued that onto the cone.
I used different weights of yarn, even embroidery thread, and hooks for the flowers to get different sizes.
This is a great heirloom to hand down and also use as a decoration!
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    11 Discussions
    JoeC380
    Question 2 months ago on Introduction
    thanks for sharing this beautiful bouquet, I am going to make one for my sister wedding. May I know if any hints for a successful bouquet? particularly for fixing flowers, are pins sufficient to fix in place or need to add glue? how long pins you used? THANK VERY MUCH.
    ChristyC23
    2 years ago
    I love this I am trying to crochet roses and daisys for my upcoming vow renewal i have the rose pattern i want but having trouble finding the daisy pattern any suggestions???
    Carleyy
    5 years ago on Introduction
    I love this because you can keep the flowers forever!
    glitterflims
    5 years ago
    I would love a crocheted bouquet for my wedding in September. Must learn how to do it! Any hints? My flower is anemone
    maizeglitterflims
    Reply 5 years ago
    I found a free pattern for anemone here here.http://melibondre.com/blog/?p=400
    If you don't crochet, I would suggest making the smaller flowers first.
    Good luck! :)
    artfulann
    FABULOUS! What a wonderful keepsake as well as so colorful and fun!
    maize
    Hi Holly,
    Thanks for all the sweet comments. I didn't really keep track of the hours it took to make the flowers. I crocheted flowers while watching tv. They work up really fast. Constructing everything took a bit longer because you want to make sure the bouquet isn't lopsided with bigger flowers on one side than the other. :)
    HollyMann
    This is so cute and you look beautiful too! The crocheted bouquet is gorgeous! :) The pics looks amazing. Not sure why people missed this - but glad i found it! How long did it take to make one?
