Crocheted Sisal Rug
43,664
208
18
About: Check out my etsy shop too! etsy.com/shop/scoochmaroo
With these simple instructions, you can make your own sisal mat any size you want.  It's perfect as a welcome mat, in a mud room, or think big and make a new dining room rug!  All you need is some sisal from the hardware store and a crochet hook, and you're ready to go.  For the price of one door mat, you could make 50!
You don't even need to know how to crochet, because I'm going to do my best to teach you!
Supplies:
Step 1: Materials
Git you a big heapa sisal (hardware store) and giant fat crochet hook (I used this one, but would choose a smaller hook for the next one).
And some gloves or tape to wrap around your fingers.  You'll figure that out soon enough. - sisal is tough on the skin!
Step 2: Chain
If you're new to crochet, don't fret.  It's totally easy.  Check out this tutorial or this video for some help, and I'll do my best to talk you through what  I did.
First, make a chain as long as you want the rug to be wide.  Mine is 24".
To make a chain, start with a slip knot, and place that on your crochet hook.  Loop the sisal over the hook part of the . . . hook. . . and pull that loop through the slip knot, leaving you with only the new loop on the hook.  Repeat!
Step 3: First Row
Ok, you've made a whole chain as long as you want the rug to be wide, yeah?    Cool.
Now you're going to crochet new loops into the chain  you just made.
Insert the hook into the second chain from the hook.  Wrap the sisal around the hook just like you did in the last step.
Pull the sisal through the first loop only.    This leaves you again with two loops on your hook.
Wrap the sisal around your hook again, and pull it through both loops on your hook.
Look at you!  You just made a "single crochet"!  Well done.
Now keep doing that across the whole row.
Step 4: Remaining Rows
The next row is slightly trickier.  But only slightly!  See, when you crochet your next rows, you've got two loops to deal with for each crochet.  Confusing?  To help illustrate, I slid my fingers through each of the places you would normally crochet into.
But!  This project is a little special!  I wanted some fun ridges in the rug, so I only crocheted into the front loops.  You don't have to do it this way - you can crochet the traditional way and slide your hook under both loops each time. It's up to you.
First, you'll make one more chain stitch.  This will help you turn around and work the other row.  You'll do this at the end of each row before you proceed your next round of single crochets.
Next, slide the hook under the front loop of the first single crochet.  Then do a "single crochet" (like we did in the last step) into that loop.  Repeat across the row.
Now, keep repeating this step until the rug is as long as you want it.
Step 5: Border
Once the rug is the size you want, you're pretty much done, and can cut the end of the sisal and weave it through the edges.  If you want to get fancy though, you can crochet a border around it.
I did a series of slip stitches, which is like a simplified single crochet.  Instead of pulling the new loop through the first and creating another loop to pull through both, you just pull the initial loop you make through both the loops on the hook.  One less step.
Make two to four rows of slip stitches all the way around the rug - sides and everything.  When you come to a corner, make three slip stitches in each stitch so it will have enough material to turn the corner easily without making it too tight.
Enjoy!
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    18 Discussions
    static
    2 months ago
    My grandma made mats like these for women's nylon stockings, and bred bags she cut into strips.
    SuzyM1
    4 years ago on Introduction
    Does anyone remember when macrame was so popular in the 60's and 70's? No needle needed. There are lots of knots to use and if you can find some waxed twine that is the best. I used twine soaked in creosote and it is a terrific substitute. It has a strong smell so some people may not like it but it is used or use to be used in humid areas and areas that have a lot of boats, fishermen and sailors : ) It is after all a sailors talent to macrame.
    Here is a free tutorial: http://www.stonebrashcreative.com/MacrameTutorial.html
    JillyJo43SuzyM1
    Reply 4 years ago on Introduction
    The twine is fine but a word of caution on the creosote----this is very very bad on the human condition ie cancer, allergies, children/dogs-poisonous. The creosote plants here were closed down many many years ago due to the above issues & more.
    SuzyM1JillyJo43
    Thanks JillyJo43 for your concerns. Re: the dangers of creosote and in fact I don't think products made for the public market are even produced anymore using creosote. Yes, creosote, (chapparal) once it is processed and becomes a coal tar can be toxic in certain situations depending on how it is used, however, it is still used commercially for railroad ties and telephone poles specifically. The EPA is now recommending that railroad ties not be used in landscaping as has been done in the past due to environmental concerns.
    It is still used in some medicinal products such as cream used for psoriasis and some Asian medicines.
    Here is a link for further information in case anyone is interested in knowing more about these products. and their effect on human and animal health.
    http://www.atsdr.cdc.gov/phs/phs.asp?id=
    stiltPro
    8 years ago on Introduction
    Ask your friendly local coffee roaster for his/her discarded green coffee bean bags. Some are burlap, some are sisal or jute. The sisal/jute bags make terrific farmer's doormats. Free for the asking, and you'll get a geography lesson besides!
    staticstiltPro
    Reply 5 years ago on Introduction
    Round here the demand for burlap bags is such, free bags wouldn't exist :( Such is life
    static
    My grandma would crochet rugs out of just about anything. Women's nylons bread bags mostly I'm sure she would have used plastic grocery bags, but she died before they come into common use around here. Go to a farm supply store and get a roll of baling twine (natural fiber or plastic) you would be stocked for life. Make a hook out of a dowel and use rope you could have a gift for the jolly green giant.
    melody2012w
    7 years ago on Introduction
    It's a joy conversing with you:) Whoa..thanx for the excellent tips..I can't wait to start making my crochet sisal rugs.....
    melody2012w
    I can't wait to start making some crochet sisal mats...thanx for the excellent tips it's a joy conversing with you:)
    melody2012w
    Whoa... thank you sooo much for sharing these excellent tips..hmmmmm...
    I can't wait to start my crochet sisal rugs..:):)
    ladybgood
    wow, just came across this and it brought me back to when I was a kid. My grandmother taught me to crochet using a big hook my grandda had carved. we used rags instead of sisal.
    great instructable and thanks for the memories :)
    billhorvath
    Excellent! Nice work. I used sisal for the bottom of a knit bag that I ended up giving to mom. It's very tough stuff -- Ideal for this purpose.
    ChrysN
    Nice, I could use a new rug. I was thinking that it would be rough on your hands, but I see you have suggested using gloves under materials, good idea.
