Cryptex Type_a. Flash Drive Holder/wallet
About: Steampunk artist, scientist, engineer
Hello
On this manual I added drawings for assembly classical Cryptex (on my cryptex family it has name type_a)
Cryptex can be assembled from brass/ aluminium pipes or from solid metal block using lathe
For assembling from pipes you'll need
1. Pipes
InternalExternal
d16mm d18mm
d18.25mm d20.25mm
d20.5mm d22.5mm
d22.75mm d24mm
2. Saw
3. File
4. Soldering iron
For assembling using lathe you'll need
1. Lathe
2. Solid metal blocks
For assembling from wood
1. Lathe\handmade lathe
2. Wood
3. Correct drawings for wood like wood pipes
InternalExternal
d16mm d24mm
d24mm d32mm
d32mm d40mm
d40mm d48mm
4. Glue, sandpaper
For first time try to make cryptex from wood
For 3D printing
1. Correct Drawings for your type of 3d printer
2. Add correction for dimmension
(on metalworking i use 0.1-0.25mm step in all parts)
On step 1 I’ll show you how to assembly from parts.
On step 2 check for drawings that I create in Autocad Inventor 2015 especially for instructables.com
Other interesting methods for constructing cryptex
Laser Cut Cryptex - Puzzle Box by Da3da1u5 on instructables.com
really big project and hard to assembly.... but
Segmented Wooden Cryptex by MissionSRX on instructables.com
You'll need some skils in woodworking
From IDEA to PRODUCTION - Cryptex by JABA 3D on instructables.com
and
3 D printed Cryptex by MrDarkNebulah on instructables.com
for 3Dprint
And for handmade lathe The Easiest Way to Make a Wood Bowl with a Handmade Lathe without Jigs by Hairbrush Inventor on instructables.com
Step 1: Assembly. Some Comments on Photos
Check notes on photos
Step 2: Drawings
Enjoy
Have a nice day
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
