Drink Holder for Card(board) Gamers
1,597
31
4
About: well...
Drinks are the worst enemy of cardboard. This object can be fixed on the table to store a mug, a can or a glass away from the precious and fragile game cards or boards. Since it is placed under the top of the table, the liquid can only spill on the floor.
It is high enough to hold a standard can, but kept short to reduce the risks of leg strikes. The clamp is strong enough to hold in place when hit by the leg.
It also offers a space for dices for example and a pen holder (which easily got lost under roleplayers papers).
It comes with a box which slides in to be useful inside a bag when playing away from home.
Step 1: Assembling the Parts
This object comes in three parts :
  • the body of the glass holder
  • the optionnal box
  • the clamping vice
The model has been designed for a 3mm thick material.
Building up the body and the box is quite simple.Nothing special here.
Step 2: Building the Clamping Vice
The clamping vice needs a 10x100mm vice, two 10mm nuts and a 10mm butterfly nut.
The first 10mm nut is enclosed inside the hexagonal parts.
The second 10mm nut is just used to block the butterfly nut. Glue or a special vice should be better but I did with what I found.
Step 3: Building the Head Screw
The head of the screw is enclosed in a glued wood cap. The idea is to
avoid denting the lower part of the table when clamping it.
Step 4: Install the Clamping Vice When Needed
The clamping vice is a mobile piece. There are slits in the back of the body to install the vice.
Step 5: Using the Box
When in a bag, the vice can be stored in the box for compactness.
I drew three different boxes :
  • one big box
  • four smaller stacking boxes
  • two stacking boxes intended to hold cards for CGG players
Step 6: Svg Files
Here's four svg files for cutting the object :
Portegobelet is for the object itself
  • boite1√©tage is for the big box
  • boite4etages is for the four stacking boxes
  • boiteCGG is for card holding
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    Luk---DIY Hacks and How Tos
    Reply 11 months ago
    Thank you :) The funny part is that it's not easy to get the reflex to use it even if it is next to you. you often forgot that you have a drink in it. It's quite useful when the table is very crowded.
    Jobar007
    Question 11 months ago
    What thickness of plywood did you use here?
    1 answer
    Luk---Jobar007
    Answer 11 months ago
    It is 3mm plywood. Maybe 5mm wood be sturdier, but this 3mm plywood looks nicer.
