Curved Cat Stairs for Your Living Room
28,458
453
48
When I got a dog, I realized the cats were spending a lot less time with me in the living room. I decided to build them an escape so they could stick around and stay out of the puppy's reach.
Here is how I built a curved staircase to ensure safe passage from the couch to the top of a bookcase.
Step 1: Stringer Molding
Mold the outer stringer which will define your stair case's curve by soaking wood in water and clamping to a form.
  • Cut a sheet of plywood into two 4'x4' pieces
  • draw a circle onto each piece that will be the diameter of your staircase's curve
  • screw studs connecting the two pieces of plywood (kind of like a half-pipe)
  • mark a length of about 4' (the eventual height of your staircase) on the first and last stud
  • Soak lengths of 1/8" by 4" hard wood in water (a kiddie pool) for a few hours
  • clamp 1/8" strips to the frame (layer two thick and make sure to stagger them if they aren't long enough to span the whole length), curving from your start mark on the first stud to the stop mark on the last one.
  • Allow to dry
  • Unclamp, glue the two thicknesses of 1/8" together, and reclamp.
  • Allow to dry
Step 2: The Steps
Use your stringer form to create a stair step template
  • Remove the studs from your stringer form
  • Draw a circle 6" inside one of the existing circles; this separation will be the width of your step.
  • Do some math: you'll want to make 90 deg worth of steps, so figure out how deep you want each step and how high each step should be. (I did about 10 steps, 4" deep on the inner circle and 4" tall)
  • Cut out one step to use as a template. Also cut a template for your first and last step which follows the inner circle but not the outer: you want this step to lay flat on the wall rather then curving back in
  • Rough cut some steps (I used 1/2" hard wood) and trace your template with a router for some smooth curves
  • Also cut out the upright pieces: a bunch of rectangles (4" x 6" x 1/8" in my case)
  • Glue these all together. Either take a bunch of time or make a sculpture with every clamp you own like I did. You might want some screws too (drill pilot holes!)
Step 3: Assembly
Now it's starting to come together: All that's left is connecting your stairs to the stringer and painting
  • Glue the stringer to your steps. My stringer didn't totally cover the stairs rise/run, so I lined it up on the top and the overlap underneath isn't really noticeable.
  • Tack the stringer in place with some small screws. Drill pilot holes! it would be a shame to split anything at this stage.
  • Paint it your (or your cat's) favorite color.
n.b. The stringer will likely not make a perfect 90deg and be a little slack. This is ok, thats why we're supplementing our glue with screws.
Step 4: Enjoy!
Screw the stringer directly into the wall (again, pilot holes!) and if you really want, spackle the screw hole and paint.
Now your cats have a staircase and you have some cool art!
p.s. if the cats seem skeptical, sprinkling a little catnip on the stairs or whatever's up top seems to help ;)
First Time Author Challenge
First Prize in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    48 Discussions
    lilly1761
    3 years ago
    Ben would you be wiling to make one for me? Please contact me at: lilly1761@yahoo.com Thanx!
    blomeclown
    4 years ago on Introduction
    That is beyond cool.
    But you could have saved lot of time by simply discussing the project with your cats.
    They would have told you to get rid of the dog.
    IceKittyblomeclown
    Reply 4 years ago on Introduction
    But if you ask the dog, it would have told you to get rid of the cat.
    So do you get rid of both?
    Or do you just make the dog and cats kiss and make up?
    Friendship.
    floatchickblomeclown
    Reply 4 years ago
    Kudos to you, benschwartz!
    I second what kstadden said, blomeclown. Perfect comment! LOL.
    CJA3D
    i am sure the cat must be super excited !!
    R_H
    Should make the steps out of clear plastic ( perspex ).
    karlanz
    4 years ago
    Love it, inspiring, one of my cats loves to be up high, and this would be just perfect. Well done :-)
    bettina-sisr
    OK you get major points for doing this for many reason, a couple of which are; cats are cool, and sculpture is awesome! Thanks, from all the kitties, especially yours!
    e-beth
    4 years ago
    I built a "staircase" for my cats from some Ikea shelves and some jute mats. It's more like a back and forth kinda thing. I can definitely attest to the catnip bait.
    sakko303 e-beth
    so I'm looking for wall mountable perch/climbing solutions for my little guy that don't take as much work, and I am digging this one. There are many cool IKEA shelves out there to choose from.
