Custom CNC Arcade Cabinet
1,827
18
About: Who is Laguna Tools? We are the people we employ, the products we sell and the passion to serve our customers that emanates from both. Laguna Tools was born in Laguna Beach, California, out of a desperate ...
Countless adults reminisce about their favorite “old-school” video games
and let’s be honest, who wouldn’t want to replay Metal Slug or Space Invaders with a classic arcade cabinet? We decided that would be a fun way to start our Laguna Projects, so let us go back to the 70’s with a modern take on classic arcade games! This arcade cabinet is a great beginner project and makes for a fun & nostalgic addition to any room you put it in. If you’re new to using Vectric VCarve or Aspire it’s a handy reference on how to set up 2D cuts.
Step 1: Get Your Materials
Smartcade Materials
  • 3/4” sheet of melamine, plywood, or mdf
  • Raspberry Pi 3.0Arcade Kit Note: this kit is great if you’re not savvy with electronics because it comes with everything you’d need but otherwise the parts can be found cheaper separately.
  • Wood Screws (alternatively you could adjust the drill command for ¼” dowels if you want clean sides on your cabinet)
  • Monitor (This was designed for an old 3:4 ratio lcd screen but any screen will work with a little adjustment to the dimensions of interior parts)
  • USB Speaker
Step 2: Cut and Assemble Directions
  1. Cut out the parts and assemble everything except the back and bottom pieces.
  2. Attach the monitor (this is the most difficult part to get right)
  3. Attach all the buttons and the joystick and wire everything together
    Note: We bought the kit and the wires were pretty short. We needed some extra wire to connect everything together
  4. Connect the monitor and speakers to the Raspberry Pi
  5. Load up some games and configure the buttons
Step 3: Links to What We Used
Step 4: Looking for More Quick Projects?
Laguna DIY CNC Projects
Items such as Guitars, Dice Towers, Cornhole games, Walnut Speakers and more! Or search "Laguna CNC" and view them here on Instructables!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    3 Discussions
    ZachaeryD
    1 year ago
    Did you use a CNC machine or a laser cutter which specific machine did you use
    LagunaToolsZachaeryD
    Reply 1 year ago
    Hello,
    We used the SmartShop II CNC Router to build the cabinet. We then used our EC Laser to cut out the acrylic you see on the front. You could use only the router or even just a laser if you wanted to make the cabinet out of acrylic.
    https://lagunatools.com/cnc/smartshop-series/smartshop-ii-2/
    https://lagunatools.com/cnc-laser/co2-lasers/smartshop-laser-ec/
    This project could be done on any of our CNC routers. Thank you , please let us know if you have anymore questions.
    Swansong
    1 year ago
    That looks awesome, I'd love to have an arcade cabinet if we had the room for it!
