Custom Music Player and Electronic Piano
About: Passionate Techie ! Robotics | Electronics | Programming - Worked with Arduino, PIC and ARM Controllers
Custom Music Player and Electronic Piano:
You can find a Mini Electronic Piano as well as Custom Music player in this following instructables.
Supplies:
Step 1: Parts and Material (For Piano)
The Parts which we need are :
* Arduino
* Piezo Buzzer
* Push Buttons - 7
* Jumper Cables
* Arduino MP3 Shield x 1
* Speaker: 3W, 4 ohms x 2
Step 2: Step 2: Connections (For Piano)
The Buttons are connected to D4 to D10 of the Arduino
The Piezo Buzzer -> D11 of the Arduino
Step 3: The Code (For Piano)
Before you can start playing your piano, you will need to obtain and install the Tone Arduino library if it is not already installed. This can be downloaded from Github here. If you do not know how to install third-party Arduino libraries in your version of the Arduino IDE, reference this guide on Arduino.cc. Attached below, you will find a zip file that contains the Arduino code for Arduino Piano. Download it and unzip it somewhere on your computer. Open Arduino_Piano.ino in the Arduino IDE and upload the code to your Arduino.
Step 4: Play! (For Piano)
And that's it! You should now be able to tap on the keys and hear the corresponding notes played through the buzzer. If the note isn't accurate, you can adjust the note value in the Arduino sketch to set what value that the pitch is achieved.You can also change the scale that is played by uncommenting one of the few scales included, or make your own scale! If you make your own piano, please comment and show us some pictures and videos. We'd love to see some creative instruments!
Give a thumbs up if it really helped you and do follow my channel for interesting projects :) Thanks for reading!
Step 5: Hardware (For Custom Music Player)
I had cut the Plywood to the required dimension and Glass to cover each RGB LED Panel.
The 12V adapter is installed for powering the device and a separate adapter is used to light the LED Panel. The Relay Connections are used to switch the LED Color Panels. Make sure that the supply is isolated. Drill the plywood to mount the PCB.
Step 6: Connections (For Custom Music Player)
*Arduino -> BT MODULE*
TX -> RX
RX -> TX
VCC -> 3.3v
GND -> GND
*Arduino -> Relay Board*
IN1 -> A1
IN2 -> A2
IN3 -> A3
IN4 -> A4
IN5 -> A5
IN6 -> A6
IN7 -> A7
VCC -> VCC
GND -> GND
*Arduino -> MP3Module*
TX -> D10
RX -> D11
VCC -> 3.3v
GND -> GND
Step 7: The Code(For Custom Music Player)
You can find the sample code below.
//Chakra Healing Harmonizer using Arduino
Visit the Channel for more interesting projects
https://www.youtube.com/channel/UCks-9JSnVb22dlqtMgPjrlg
*/ #include "SoftwareSerial.h" #include
SoftwareSerial mySerial(11, 10); # define Start_Byte 0x7E # define Version_Byte 0xFF # define Command_Length 0x06 # define End_Byte 0xEF # define Acknowledge 0x00 info]
# define ACTIVATED LOW boolean isPlaying = false;
int but = 12; int r1= A1, r2 = A2, r3 = A3, r4 = A4, r5 = A5, r6 = A6, r7 = A7;
void setup () { pinMode(but, INPUT_PULLUP); digitalWrite(but,HIGH);
pinMode(r1, OUTPUT); digitalWrite(r1,LOW); pinMode(r2, OUTPUT); digitalWrite(r2,LOW); pinMode(r3, OUTPUT); digitalWrite(r3,LOW); pinMode(r4, OUTPUT); digitalWrite(r4,LOW); pinMode(r5, OUTPUT); digitalWrite(r5,LOW); pinMode(r6, OUTPUT); digitalWrite(r6,LOW); pinMode(r7, OUTPUT); digitalWrite(r7,LOW);
Serial.begin(9600); mySerial.begin (9600); mp3_set_serial (mySerial); mp3_set_volume (25); }
void loop () { check_bt(); }
void check_bt() { while (Serial.available()){ delay(10); char c = Serial.read(); if ((c == '~')|| (c == '+')) {break;} voice += c; } if (voice.length() > 0) { Serial.println(voice); if(voice == "playc1") { voice=""; p1 = 1;relay_1(); mp3_play (1); wait(hr1,minute1,0); mp3_stop (); } else p1 = 0; if(voice == "playc2") { voice=""; p2 = 1;relay_2(); mp3_play (2); wait(hr2,minute2,0); mp3_stop (); } else p2 = 0; if(voice == "playc3") { voice=""; p3 = 1;relay_3(); mp3_play (3); wait(hr3,minute3,0); mp3_stop (); } else p3 = 0; if(voice == "playc4") { voice=""; p4 = 1;relay_4(); mp3_play (4); wait(hr4,minute4,0); mp3_stop (); } else p4 = 0; if(voice == "playc5") { voice=""; p5 = 1;relay_5(); mp3_play (5); wait(hr5,minute5,0); mp3_stop (); } else p5 = 0; if(voice == "playc6") { voice=""; p6 = 1;relay_6(); mp3_play (6); wait(hr6,minute6,0); mp3_stop (); } else p6 = 0; if(voice == "playc7") { voice=""; p7 = 1;relay_7(); mp3_play (7); wait(hr7,minute7,0); mp3_stop (); } else p7 = 0; //////////////////////////////////////////////////////////////////////
if(voice == "playal") { voice=""; p_cur = 1; if(p1 == 1) { p1 = 0; relay_1(); mp3_play (1); wait(2,0,0); mp3_stop (); } else if(p2 == 1) { p2 = 0; relay_2(); mp3_play (2); wait(2,0,0); mp3_stop (); } else if(p3 == 1) { p3 = 0; relay_3(); mp3_play (3); wait(2,0,0); mp3_stop (); } else if(p4 == 1) { p4 = 0; relay_4(); mp3_play (4); wait(2,0,0); mp3_stop (); } else if(p5 == 1) { p5 = 0; relay_5(); mp3_play (5); wait(2,0,0); mp3_stop (); } else if(p6 == 1) { p6 = 0; relay_6(); mp3_play (6); wait(2,0,0); mp3_stop (); } else if(p7 == 1) { p7 = 0; relay_7(); mp3_play (7); wait(2,0,0); mp3_stop (); } } else p_cur = 0; ///////////////////////////////////////////////////////////////////////////// if(voice == "playrc") { voice=""; p_order = 1; p1 = 1; relay_1(); mp3_play (1); wait(hr1,minute1,0); p1 = 0; mp3_stop (); wait(0,1,0); p2 = 1; relay_2(); mp3_play (2); wait(hr2,minute2,0); p2 = 0; mp3_stop (); wait(0,1,0); p3 = 1; relay_3(); mp3_play (3); wait(hr3,minute3,0); p3 = 0; mp3_stop (); wait(0,1,0); p4 = 1; relay_4(); mp3_play (4); wait(hr4,minute4,0); p4 = 0; mp3_stop (); wait(0,1,0); p5 = 1; relay_5(); mp3_play (5); wait(hr5,minute5,0); p5 = 0; mp3_stop (); wait(0,1,0); p6 = 1; relay_6(); mp3_play (6); wait(hr6,minute6,0); p6 = 0; mp3_stop (); wait(0,1,0); p7 = 1; relay_7(); mp3_play (7); wait(hr7,minute7,0); p7 = 0; mp3_stop (); } else p_order = 0; if(voice == "playst") {mp3_stop (); relay_stop(); p1 = 0; p2 = 0; p3 = 0; p4 = 0; p5 = 0; p6 = 0; p7 = 0; p_cur = 0; p_order = 0;} voice="";} }
void wait(int h,int m,int s) { int t = (h*60*60)+(m*60)+s; for(int i=1;i
void relay_1() { digitalWrite(r1,HIGH); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,LOW); }
void relay_2() { digitalWrite(r1,LOW); digitalWrite(r2,HIGH); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,LOW); }
void relay_3() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,HIGH); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,LOW); } void relay_4() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,HIGH); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,LOW); }
void relay_5() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,HIGH); digitalWrite(r6,LOW); digitalWrite(r7,LOW); }
void relay_6() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,HIGH); digitalWrite(r7,LOW); }
void relay_7() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,HIGH); }
void relay_stop() { digitalWrite(r1,LOW); digitalWrite(r2,LOW); digitalWrite(r3,LOW); digitalWrite(r4,LOW); digitalWrite(r5,LOW); digitalWrite(r6,LOW); digitalWrite(r7,LOW); } //************************************************************************************************************************************* void playFirst() { execute_CMD(0x3F, 0, 0); delay(100); setVolume(25); delay(100); execute_CMD(0x11,0,1); delay(100); }
void initiate(){ execute_CMD(0x3F, 0, 0); delay(100); setVolume(25); delay(100);}
void pause() { execute_CMD(0x0E,0,0); delay(100); }
void play() { execute_CMD(0x0D,0,1); delay(100); }
void playNext() { execute_CMD(0x01,0,1); delay(100); }
void playPrevious() { execute_CMD(0x02,0,1); delay(100); }
void setVolume(int volume) { execute_CMD(0x06, 0, volume); delay(2000); }
void play1() { relay_1(); execute_CMD(0x0D,0,1); delay(100); isPlaying = true; wait(hr1,minute1,0); pause(); }
void play2() { p2 = 1; relay_2(); execute_CMD(0x0D,0,2); delay(100); isPlaying = true; wait(hr2,minute2,0); pause(); p2 = 0; }
void play3() { p3 = 1; relay_3(); execute_CMD(0x0D,0,3); delay(100); isPlaying = true; wait(hr3,minute3,0); pause(); p3 = 0; }
void play4() { p4 = 1; relay_4(); execute_CMD(0x0D,0,4); delay(100); isPlaying = true; wait(hr4,minute4,0); pause(); p4 = 0; }
void play5() { p5 = 1; relay_5(); execute_CMD(0x0D,0,5); delay(100); isPlaying = true; wait(hr5,minute5,0); pause(); p5 = 0; }
void play6() { p6 = 1; relay_6(); execute_CMD(0x0D,0,6); delay(100); isPlaying = true; wait(hr6,minute6,0); pause(); p6 = 0; }
void play7() { p7 = 1; relay_7(); execute_CMD(0x0D,0,7); delay(100); isPlaying = true; wait(hr7,minute7,0); pause(); p7 = 0; }
void execute_CMD(byte CMD, byte Par1, byte Par2) { word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2); byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge, Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte}; for (byte k=0; k<10; k++) { mySerial.write( Command_line[k]); } }
Step 8: Connections (For Custom Music Player)
Step 9: Application (For Custom Music Player)
For now we will use the ready-made application. In the following days I will publish the application once after the certificates are processed.
APP Screenshot:
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
