Custom Reclaimed Wood Sign
1,721
78
4
About: Former NFL Offensive lineman turned Furniture maker. I am self taught and sharing my experiences with the world!
In this video i make a reclaimed wood sign for a local business, This build is very easy and simple and can be done in less than a day with the right tools. Using custom signage to make your branding pop is a hugely valuable tool.
Check it out!
Supplies:
Step 1: Pick and Prep Your Wood
In this step you want to find some lumber that will be wide enough for your lettering. I happened to have some 100+ year old tongue and groove barn wood I locally sourced from a barn I tore down near me. Try and pick something that doesn't have a lot of voids or knots if you do choose to use reclaimed wood. Prep the wood by using a bristle brush to remove the dirt and also pull all of the nails.
Step 2: Break Down Your Lumber
You're going to want to take your prepped wood and start milling it down. I used the planer to flatten it then use the jointer and table saw for dimensioning.
Step 3: Lay Out Your Stencil, and Cut Your Pieces
Here you wan to lay on your stencil for the wood, then cut out the pieces for the sign. I use the table saw to finalize all my pieces based on my stencils. A mighter gauge is hugely helpful here, if you dont have one you can use your circular saw.
Step 4: Layout Your Pocket Holes and Assemble the Sign
Here I mark and layout where i want to join the sign together. Using pocket holes i glue and screw the two pieces together. This is a fast and simple technique for joinery like this
Step 5: Get Out the Sander
In this step you want to take your pieces and sand down the sign. Get it to where its nice and smooth to the touch.
Step 6: Apply Stain and Finish
Apply your stain and finishes choices and boom you have a custom sign.
Thank you for watching and Following along.
Follow me on social media for more updates and projects!
INSTAGRAM
FACEBOOK
TWITTER
PINTEREST
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    4 Discussions
