Customizable Fleece Hats
138,191
364
76
You want to keep your noggin toasty in the nasty winter weather.
You don't want to wear a hat that looks like everyone else's hat.
You like lions (or dragons).
Now you can combine all of these desires into a simple, yet useful, item of clothing that's infintely customizable and tailorable to your (or a recipient's) tastes.
Disclaimer/apology: Since there's no limit to the variation on this theme, I've only provided the most basic directions. If you have specific questions on how I did certain things, I will be happy to try and explain it in a seperate instructable or through private correspondance.
Step 1: Preliminary Measurements and Layout
You will need:
Fleece
Sewing machine + standard sewing stuff
Scissors, measuring tape
Felt, buttons, etc for finishing touches
Think about what you want to make.
i.e. The lion hat needs a mane and a muzzle, in addition to eyes, nose and ears. I made the mane and muzzle from felt, since I did not wish to deal with unhemmed edges exposed on the outside of the hat.
Measure your head and add half-an-inch: this will be the length of your fleece. The height of the cloth will need to be 9-10 inches, for an adult.
Cut fleece.
Make ears, tails, spines, et cetera:
Sew your idea on to two pieces of fleece (or one piece folded in half), trim it, flip it inside out.
Place these items to the side.
Step 2: Assemble Pieces
Grab the ears you want to add (and if you want a ruff, that too), and any spines or such.
Locate where the pieces want to be (spines go at Center Ridge, ears go at Ears, and ruffs go across Ears as well).
You'll sew the like-color edges together (red edge to red edge, blue to blue.)
Make sure you sew the ears and stuff in place as you sew the edges. You may wish to pin these things in place before you start sewing.
REMEMBER: You are sewing this hat inside out, so please make sure your ears and stuff are placed correctly so that when you finally flip the hat right side out, they'll be in the right place.
Step 3: More Details on Attatching Ears/manes
Here are two photos of my finished lion hat and some clarification (I hope) of how to assemble the mane.
I had first sewn the two seams running from forehead to top-center of the hat, as well as the seam all the way down the back of the hat. This left two seams at the top still unsewn. This is where I put the ears and the mane.
I held the hat right-side-out and figured out how far I wanted the mane and ears to stick up, held it them place between the fabric, and flipped the hat inside-out.
Then I sewed across the entire seam from one side of the hat to the other, pinning down the mane and ears.
Step 4: Finishing Touches
Hopefully your ears and tails and stuff are in the right place.
Have your hat inside-out.
Grab the bottom inch-and-a-half or so of the hat and fold it up, around the "outside".
You're going to hem this thing, so make sure the raw edge is on the inside of the hat, once it all gets flipped right-side out.
Hem with a large zig-zag stitch all around. (This allows the cloth to retain some stretch without tearing the hem-thread.)
Flip your hat right-side out. You're almost done.
Do you need to add a muzzle, eyes, or other facial features to the hat?
Grab your felt. Cut it to shape. Sew it on to the outside of the hat.
Add eyes. A nose. Stuff.
Now trim all the extra thread and stuff, clean up your workspace:
You've got yourself a hat.
Here are some additional ideas:
Cthulhu
Penguin
Dog
Bear
Roman Centurion Helm
Greek Corinthian Helm
Kangaroo
Dragon
Batman
Rooster
Sushi
Step 5: Examples
Penguin, Roman Centurion Helm, Cthulhu (missing eyes)
Corinthian Helm
Cow
Mouse (Yuki, from Fruits Basket)
Lobster
Panda
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    76 Discussions
    Someone asked me for the yotsuba hat pattern.
    The pattern is the 5-ends crown given in this instructible. Here is the pattern I drew for Yotsuba's bunches, you should cut it out 8times. It is 7.5cm high and 6.3cm wide.
    I advise you now to pin a second layer of fleece down the hat where your forehead will be (where Yotsuba's bangs are). Go on and make the hat normally.
    Pin 4 bunch pieces to the hat and adjust to make it symmetrical. When the positions are right, sew a small circle on the centre of each piece, then start sewing the second piece of each bunch on each first piece. Leave a little gap to put some filling, then resume sewing. Your bunches are ready.
    Go back to the forehead and draw the bangs. Cut and sew the two pieces of fleece along the edge of the bangs. It should prevent the bangs from curling up too much. You don't have to make another seam than the bottom one.
    That's it, you have a yotsuba hat!
    I love this tutorial. I made a polar bear hat since I only had white fleece and black felt, handmade (I didn't have a sewing machine back then) and apart from the handmade sewing it was really easy.
    I did a small inside hem instead of a big one outside because I assumed the back seam would be visible on the back of the head with an outside hem. I also softened the pointy ends on the forehead by sewing a little longer and rounder down.
    I am planning on doing a jellyfish hat, a Yotsuba hair hat and a Cthulhu hat (although I am still thinking about how I will put the tentacles, I think in your design it is too obvious they have been added afterwards - sorry) and will definitely put pictures of them as well.
    Thanks a lot!
    handyjim
    7 years ago on Introduction
    cool ive made a bunny hat ill try and put a picture on as soon as i can.
    Awesome101
    7 years ago on Step 5
    i like the cow because haru is my favourite character in fruits basket <3
    thnx 4 idea
    bass girl
    8 years ago on Introduction
    when i first saw the hat, i thought that it was of kon. he is a stuffed anmal from a manga serius named bleah.....i was very happy. even though the hat was a lion, i still think it is kon
    childe
    9 years ago on Step 5
    Great instructions!  I used them to make a Gir hat (the robot dog from Invader Zim) for my best friend's ten year old daughter, and I had no troubles at all, despite my slightly wobbly stitching.
    I chose to use a second colour of fleece to line the hat (mostly for aesthetic reasons, but also because it gets very cold here in Canada and the extra layer will be useful).  I suggest to anyone who wants to attempt this, definitely sew the two pieces of fleece securely together before you try to do any of the shaping darts, or the pieces will flop all over the place and be a total pain.
    I also used some leftover little scraps to "stuff" the eyes on this hat so that they'd stick out and look properly bulbousy.  I think that this technique could be easily used to make noses, beaks, muzzles, ears, etc. that are more 3-dimensional:  just sew most of the way around the piece, then pack it full of stuffing before you sew it completely closed.
    gemtree
    This is totally cool but I want it to look like a mane on my head, not a head on my head. Can you cut it to go around the head more, incorporating the person's face into the design? Like this? (I hope this image add on works)
    ryzellongemtree
    Short answer: not very easily, and probably not very satisfactorily.
    Slightly longer answer: since a mane is more than just what frames the face, you'd have to do a lot of finagling to get the rest of the hat covered in mane-pieces. Also, even the framing of the face is kind of impossible with this type of hat design without bisecting the entire hat. Even then, the mane would sit across the top of the head, not along the hairline/forehead.
    gemtreeryzellon
    I was thinking to use furry material instead of fleece. Then bring the material down to frame the face.
    Not sure I understand parts of the drawings in step one. Last two pictures do not make sense. Are these other pieces that are cut? What does 5ths and 6ths mean? And I can't figure how the ears are done. I am a bit dyslexic so I need more input to get some ideas.
    ryzellongemtree
    The design isn't going to accommodate bringing the material down to the face.
    As per the text, the final pair of images on the intro page of these instructions are the top views of the two different patterns.
    Ears: take two pieces of felt and stack them. Sew a "C" shape on to them. Trim the felt close to the seam. Flip the "C" inside-out.
    gemtreeryzellon
    I guess this would call for a different technique entirely, Thanks for the ideas.
