DIY $5.00 Sandblaster
824,285
1,180
437
About: Instagram: withered_perception Photographer and Aerial Photographer. Proudly Collaborating With HISTORY COLORADO.
Instagram: Withered_perception
I have some rust on my driveway and some old rusty tools I got from my grandfather years ago.
I have been looking at sand and soda blasters for about 6 months. They are either inexpensive and cheap or very well made and expensive!
So I decided lets just make one.
Step 1: Get Crap
Go get some crap at Harbor Freight. This air gun kit ran $4.99.
Now find a bottle in the trash.
Step 2: Say "Hi" to the Cat
This optional but important step may be the difference between you succeeding or failing.
Step 3: Cut the Neck
Remove the locking neck for the cap.
Step 4: Drill
Grab a 3/16" bit and drill the neck just under the cap.
Step 5: Test Fit
Push the air rod in. It should be very snug!
Step 6: Mark
Mark the bottom of the air tube. Spin the tube around so you can hold the handle while you file.
Step 7: File
File a hole through the tube to let your media in. When you're done spin the tube back so the opening is at the bottom.
Step 8: Fit
Get the tube back into the hole.
Step 9: Seal
Not looking for the glue to actually stick here.
Just looking to prevent the hole from opening up too much while under pressure.
Step 10: Test Blast
Put your Saftey goggles and gloves on and give it a good blast. I shot at the rust on the drive way and removed a spot (the white part) in just a few seconds.
I will give you an update on the driveway once I have time to do some actual blasting on it.
Step 11: Real Deal
An old set of needle nose (rusty as hell...)
Step 12: Blast Away
Clean as a whistle!
Step 13: Extra Step
Because everyone keeps asking this is my air compressor a California Air Tools 10020c running at about 40 PSI for blasting.
I also use 20/40 crushed walnut for my media.
For PPE I use gloves, a P-100 respirator, long sleeves and a face shield. No excuses! Do not mess with your Safety!
[Play Video]
5 People Made This Project!
  • Pie Contest
    Pie Contest
  • Trash to Treasure
    Trash to Treasure
  • Epilog X Contest
    Epilog X Contest
437 Discussions
KellyCraig
7 weeks ago
Very clever. I think I'll build a version and keep it in my sandblast cabinet for specialty work.
RiekieMJMWDonaldP47
Answer 1 year ago
in 1975 a Diesel mechanic show me an engine overhaul and that was one of the things he did - the less force you use the better preserved the items are
RobW140
Question 4 months ago on Step 13
hi, have you baking soda with this blaster? how effective was it?
Gunsaw
6 months ago
Everyone here making this instructable should understand that the P-100 filter mask is A MUST! If you use beach sand, play sand, ANY KIND OF SAND! understand that you are risking getting silicosis. Breathing the vaporized sand from blasting can and will kill you slowly and painfully after it sets in months or years later and there is NO CURE!
GunsawGunsaw
Reply 6 months ago
Also note that using sand specially made for sand blasting has a greatly reduced silicosis risk. And remember that this device has no ceramic tip so it has a limited number of uses before the sand sand blasts the air tip into oblivion.
Nikiniku
1 year ago
I was wrong about being able to buy a complete sand blasting kit for $29. I discovered that when went to Amazon just now to buy it. $29 does NOT include the compressor. As far as the kits NOT INCLUDING COMPRESSORS are concerned, the cheapest one I could find was $11.95, and there were nine less than $19.00. The compresors I found were not that cheap. There was one for $13.95, but the next highest one was $19.95, and they went up from there. So, it looks like I won't be buying a sand blaster and compressor to clean the surface of my concrete driveway. I'll have to stick with the power drill and circular sandpaper discs I have been using.
GunsawNikiniku
Reply 6 months ago
pressure washer is best.
offrampNikiniku
Reply 1 year ago
ummm.... have you considered muriatic acid...?
JumpingThrghHoops
1 year ago
Great DIY project!
Do you think that the sand blasting or another media could be used on the underside of a car to remove rust?
Yes, a Canadian problem caused largely from the road salt used to melt the snow on the roads. I cannot see why it wouldn't work, but need to put some thought into before actually proceeding. The one thing that comes to mind is it may be necessary to cover the brakes to prevent sand from penetrating, but then again as soon as the car starts rolling it should shake and blow off.
Absolutely. I spent years in the Auto industry and Sandblasting is very common! Cover what you don't want blasted, cardboard shields work well and a simple air nozzle after at about 90PSI should take care of about 85% of the media. driving should in theory get the rest!
GunsawWithered Perception
Reply 6 months ago
This is a tiny sand blaster and the spray pattern from the tip is pencil thin. You won't want to use ^THIS item for removing rust from a car frame. Small tools or objects yes, large items, not really.
cezarang
6 months ago on Step 2
jejeje i didnt spect this... funny :P
Megalodon816
6 months ago on Introduction
Awesome project I will definitely be doing this! I also love the optional cat step, I'll have to modify that slightly to my dogs or bunnies.
