DIY Altoids Infinity Mirror
36,188
536
28
About: Every week two geeky people in Rochester MN spend every ounce of their freetime creating educational videos, podcasts, articles, and music. They publish it all on the internet, free to anyone in the whole un...
I've never made an infinity mirror before, much less owned one, and thought it was much more complex than it actually was. So during the Deconstruction 2014 (a global hackathon-ish sort of thing), one of our projects became this altoids infinity mirror!
What you need:
  • Altoids Tin
  • Mirror that can fit into altoids tin (you may need to cut your own)
  • 1 way mirror (we used a filter from an old projector)
  • LEDs or Chibitronics LED stickers
  • Electrical Tape + Double-sided Tape
  • 5v power supply (wall wart) with its power jack cut off
Tools you may need:
  • Mouse Sander
  • Dremel tool w/metal cutting wheel
  • Tin Snips
  • Drill Press
  • Files/steel wool
Step 1: Cut Your Mirror Down to Size and Tape It Down
For the mirror, we used a glass cutter to score it.
  • We clamped the glass down and using fairly significant pressure, scored the mirror.
  • We then used the back of the glass cutter (what looked like a ball) to gently tap the mirror. It split fairly easily!
Note, when cutting it, make sure to allow enough space on the sides of the mirror for your lid to close!
  • Apply a piece of double-sided tape inside of the altoids cover and tape in the mirror.
  • We decided to put the mirror on the Altoid side so that we could still keep the Altoid graphic
Step 2: Prepare the Box for the Double Sided Mirror
  • Using a mouse sander we sanded off the nutrition facts for a nice silver-y surface. We also sanded it with some 000 steel wool to get a better polish. A lot easier than we thought it'd be!
  • We traced the shape of the filter/other mirror on the box and drew box inside of that one with a 1.5mm border.
    • The border is important because that was where we put the super glue to keep the filter in place.
Step 3: Establish the Power/ground Rails
Since the altoids tin is conductive, we used it as the ground plane. But this required that we isolate the positive power rail from ground.
  • Put electrical tape around the inside of the tin but below the edge by around 1.5mm - just enough for your LED/chibitronic LED negative leg.
  • Put Chibitronic copper tape over the electrical tape, also around the inside of the tin. If you're using Chibitronic LED stickers (as I did), you'll want to make sure the positive leg of the LED can reach the copper tape.
Step 4: Add Your LEDs + Final Touches
  • We used Chibitronic LEDs around the edge. Again the + side of the LED attached to the copper tape and the - side attached to the ground plane of the tin. I believe we used 8 LEDs.
  • We then soldered the + side of the wall wart to the copper tape and the - side of the wall wart to the tin.
  • We drilled a hole for the wall wart cord to go through, but if you need to give the cord more room, just use a pair of tin snips to adjust it!
Step 5: Enjoy!
And voila! The fun thing about using a projector filter is that depending on which way you turn it, you end up with a different spectrum of colors! Hope you enjoy it!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    28 Discussions
    supergilligan
    4 years ago
    Tymkrs, great project. I do have a correction though, it is one way mirrors not two way. I'll keep looking for more good projects of yours.
    Errol1951
    4 years ago on Introduction
    I built one similar but for the one way mirror I used the reflective film that is used on windows for privacy and insulation
    longwinters
    4 years ago
    Nice project thanks for posting, if you want more battery power just take the top off a second tin, cut the lip off and make a second compartment on the back to hold battries
    alcurb
    Looks nice. Pretty cool.
    I wonder if this design would allow for a flat LiPo battery be used behind the purely reflective mirror. The lipo would take about 5mm or so in depth and the charging circuit would take less room than the battery. Thanks for the inspiration.
    I inserted your project in my "He LED me to the LIGHT" collection.
    Tymkrsalcurb
    Reply 4 years ago on Introduction
    Haha, he LED me to the LIGHT :) I like that. I think it would allow for a flat lipo battery! Double-sided tape ftw!
    TymkrsAyush Sharma
    Thanks for the suggestion :) It was our first time with an infinity mirror (i hadn't even really seen one up close) until now, so next time we do it, we probably will!
    jueljpTymkrs
    make sure you share the results; nice project, it makes a nice necklace, can it fit in a more compact case for a fine looking necklace?
    Tymkrsjueljp
    I don't see why not! These leds can be powered with a 3v coin cell so it is definitely small enough for a nice necklace!
    shinystuff
    Hi, I also like to divide by zero and show the infinite vortex it creates to people! :D These are 3 of my infinity mirrors and the one with the sea shells actually uses two row of leds, the other one is a uses a bathroom mirror frame and the last one is actually a working clock(the missing led is because the led strip was too short, talk about inconvenience :( ) and it works like a charm. I don't want to sound like I am criticizing but you could use a better double mirror. I am not actually using a double mirror but a glass with a highly reflective side ( bronze-salt I think it is called). Otherwise very good project, I really like how you made the conductive part!
    hickhamtTymkrs
    agreed!! would love an infinity clock... just saw Interstellar and im all hyped up on wormholes and clocks now! lol..
    shinystuffhickhamt
    Reply 4 years ago
    Well I can give you a short instructable right here, you need a clock(round or square), a preferably thin mirror because of the arrows, a led strip and a highly reflective glass. Take the clock apart, remove the sheet with the number, drill a hole in the middle of the mirror(I asked the local glass smith to do it), glue the mirror in place, place the led strip on the inner circle, put back the dials, place the reflectic glass with the reflecting side towards the clock, put the case of the clock together, plug it in, get high, stare into the vortex, go insane and PROFIT. And that is how you make an infinity clock.
