DIY Arduino Based Automatic Wire Cutting Machine
4,438
52
17
About: Electrical engineer by profession
This is arduino based automatic wire cutting machine
Step 1: Video
Hello friends
I have made a Automatic wire cutting machine using Arduino nano controller board.
based on this original design by
Must Love Science
Basically there are 3 process level of this machine like
1) first process is Input
Input like wire length and wire quantity provided by pressing push button also the real time data can read on 16 X 2 LCD
on more professional note i prefer to use custom made PCB instead of using bread board or zero PCB
also if 10 PCB's are available in only 2$ so why not to use then for projects
WWW.JLCPCB.COM is the place where you can get 10 PCB in just 2$ along with first shipping free consider to visit Jlcpcb.com for more detail
2) Processing
all the inputs were processed by arduino nano and give command to stepper motor to feed required length of wire and instruct to servo to make cut of required quantity.
3) Output
Stepper motor, servo motor & cutter are the final output component
Step 2: Material Required
followings are the material required
arduino nano :- http://amzn.to/2Dcp2bK
stepper motor :- http://amzn.to/2Dg6wycstepper
motor driver :- http://amzn.to/2Dg6wycstepper
16 x 2 LCD :- http://amzn.to/2Db9LYA
servo motor :- http://amzn.to/2r5oejj
cutter :- http://amzn.to/2D9X6oZ
PCB terminal :- http://amzn.to/2r8uCq7
push buttons :- http://amzn.to/2D9XbsN
Step 3: PCB Design
I have prepare PCB layout in fritzing software
then Designe a PCB and export its gerber file
This gerber file uploaded to Jlcpcb.com to order the PCB
as soon as you recived PCB
you need to solder some female header pins to mount arduino nano, LCD display & A4988 driver
also solder the PCB terminal to connect power supply to the PCB and to connect stepper motor to PCB
here I attached the editable PLC layout file so if you can do any modification required.
Step 4: Procedure
So as soon as all the components are available
you can start assembly the machine.
for the base of the machine I used 3MM thick white acrylic sheet
I drill some hole on sheet to mount PCB, Stepper motor with extruder set, cutter & servo motor
for better idea please watch video it will give a idea how to mount those components on sheet
all the components are tightly mount on the sheet
now we can move to program our arduino
Step 5: Arduino Program
upload the code to the arduino
now connect the 12V DC at terminal of PCB this is for stepper motor
and connect USB to arduino nano this will feed power to arduino itself and servo motor
now machine is ready to perform
you need to press those push buttons to navigate between screen and to select desire data
hope you will like my this project
also please subscribe to our youtube channel for more projects
https://www.youtube.com/c/mrinnovative
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    17 Discussions
    MohanK30
    2 months ago on Introduction
    I have ordered PCB form JLCPCB for $2. but the courier charge came $23. and the import duty in India came Indian Rupees. 960. ( Approximately $15 so the total is $40 for 10 pcbs.
    instead of guiding to a China, you could have given the order to any Domestic manufacturer. We have extra pcb of no use. if any person need pcb, I can givfe for the cost price. my mobile 9486393921
    lucylily
    11 months ago
    Don't waste your time on this. It's nothing more than an a PCB vendor promotion.This is yet another junk circuit from JLCPCB.I got PCB from jlcpcb, but cannot
    recommend them (cheap, but bad quality)
    BrownDogGadgets
    1 year ago
    I noticed that when we got the PCBs made up, the holes for the Stepper Driver were smaller than all the others and our pins didn't fit through. (We used OSH Park, and they're usually spot on.) We were able to drill them out and get things working, but you should check the files on your end.
    Drilling them out was a bad idea, it killed the pass through connection and the stepper motor doesn't work. You should update your PCB since the holes for the Stepper Driver don't work. Maybe drilling them out but soldering both top AND bottom would work, but otherwise this makes using a stepper driver nearly impossible with the current PCB design.
    NandoB4
    1 year ago
    What are the resistor values? Both for the variable resistor and for R1 on the top?
    BrownDogGadgets
    Question 1 year ago
    ShashiK3
    1 year ago on Step 4
    Sandeep, Your video "Electrical Overview.mp4" does not download ? It fails - Please check.
    ShashiK3
    Question 1 year ago on Step 3
    Sandeep, Are there not any Export Import Restrictions from the Govt, when ordering PCB from overseas ?
    Is the approval from the Govt required for clearing the customs or any such formality as the product is at the Indian shores ? Just curious.
    ShashiK3
    1 year ago
    Sandeep, Nice Video. What is the product at 1:36 in the video ?
    I did not see in the Bill of Materials that you prepared.
    It is the one with the Blue and Golden collar where the wire got pulled ?
    I enjoyed all of your videos and trying some of your experiments on mine too.
    Good Work and Good Luck.
    Very Innovative.
    JohannesE6
    1 year ago
    Could you post correct Amazon Links? They arent working in the case of stepper motor and motor driver..
    Mr innovative
    1 year ago
    off course I'll mention you credit and links
    I think it would missed by our team
    MaclskMr innovative
    Reply 1 year ago
    Thanks! I really appreciate it.
    I love the build by the way. It looks great!
