DIY Arduino LED Color Organ 2.0
25,995
64
23
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to build an Arduino LED Color Organ which reacts to different frequency bands in your music with lights shows. In my case the red light represents the bass, green light middle frequencies and blue is the high notes. Let's get started !
Step 1: Watch the Video!
The video gives you all the information you need to build this right. But I will also present you the code, schematic and a parts list in the next steps
Step 2: Order Your Parts!
You can get the kit with the core components from Mklec: http://mklec.com/project-kits/diy-project-kits/gr...
In addition you will need the following parts as well:
Ebay:
1x Breadboard: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x Arduino UNO: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 12V 2A Power Supply: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x Hookup Wire: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
Amazon.com:
1x Breadboard: http://amzn.to/1OtODYv
1x Arduino UNO: http://amzn.to/1OtODYv
1x 12V 2A Power Supply: http://amzn.to/1OtODYv
1x Hookup Wire: http://amzn.to/1OtODYv
Amazon.de:
1x Breadboard: http://amzn.to/1gtbtB7
1x Arduino UNO: http://amzn.to/1gtbtB7
1x 12V 2A Power Supply: http://amzn.to/1gtbtB7
1x Hookup Wire: -
Amazon.co.uk:
1x Breadboard: http://amzn.to/1Ix0qqw
1x Arduino UNO: http://amzn.to/1Ix0qqw
1x 12V 2A Power Supply: http://amzn.to/1Ix0qqw
1x Hookup Wire: http://amzn.to/1Ix0qqw
Step 3: Build the Circuit!
Here you can find the schematic, breadboard layout and stripboard layout which shows you where the wire connections and components must be placed.
There are also some additional pictures of my finished circuit on the breadboard and stripboard.
Step 4: Upload the Code!
Here you can find the Arduino Code which you need to upload to your Arduino UNO in order to make the circuit work properly.
Step 5: Success!
You did it. You just created your own led color organ!
Feel free to check out my Youtube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
3 People Made This Project!
  • Classroom Science Contest
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
23 Discussions
JuliusS29
Question 1 year ago on Introduction
Hi, if I'd want to attach a microphone instead of the audio jacl, would that require any significant change in code or schematic ?
snandor
1 year ago
Hi GreatScott! Very cool project! Is it possible to hook up multiple LEDs for each frequency in order for them to light up in a vumeter fashion?
dor123
1 year ago
the kit is unavailable ...
can someone list all the parts?
zaven46
2 years ago
Recently I have successfully made a working copy of the project.Would it be possible to get 6 or 7 color output instead of just 3. Is it matter of modifying the code and add more output mosfets?
NicolaiF
2 years ago
On the breadboard wiring diagram, there is 2 or 3 wires going to the top positive power rail, but all other wires are going to the bootom power rail. Is it just to make it look cleaner or is it because there is a need for diiferent voltages? and is it 12v or 5v for the breadboard?
RobocrafterSimon
2 years ago
Just a small question. Where did you find the MSGEQ7 part in eagle? Also I can't find it online.
I should design my own? (I wanna combine the 7 band LED bar with the Color Organ 2.0 ;) )
PetrosM6
2 years ago
Greatscott very nice instructable,could i use your code in a simiral video that i want to make in my language?
thank you!
GBNate
3 years ago
Hey would i be able to plug a 10mm rgb led into this isntead of the 3 separate leds?
GuillermoR3
3 years ago
Hi, I wanted to know how would you connect an RGB LED strip to the mosfets like you mentioned in your video.
RalphS10
3 years ago
Hello, I was wondering if I wanted to add an additional 2 LED's to each color for a total of 9 LED's (3 blue, 3 red, 3green). How would I go about/approach this?
jsapožnikovRalphS10
Reply 3 years ago
Depends on what power LED's are you going to use, for example if you are going to use 10 LED's you should use 30W external LED power supply on each color and use this board only to operate the music signal.
I'm not really sure how everything should be connected but that's the only option i could think of.
powertekGreatScottLab
Reply 3 years ago
An ATtiny84 should work as it has 5 PWM pins, only 3 are required. And you would still have extra pins to use for the Analog input. Correct me if I am wrong.
newb
3 years ago on Introduction
First of all, thank you. I've been looking for an easy, well explained kit of this for a while and they're hard to come by. I picked up one of the kits from mklec and everything works great the only issue I've run into it hooking it up the an rgb strip. It works fine at low volumes but even just normally listening volume the lights seem to get to bright and almost just turn into white.
I'm guessing there's an easy way to fix it but my coding skills are only in html and javascript so I don't really know how to fix it.
If anyone has any ideas I'm up for suggestions lol.
Luis Cunhanewb
Reply 3 years ago
You can try inserting a 100k stereo potentiometer after R8/R9 and then adjust the input.
See picture for connection instructions.
You can use a potentiometer like this one: http://www.amazon.com/100K-Linear-Taper-Rotary-Potentiometers/dp/B008DFAKI6
mgiannopoulos1
3 years ago
Hello, can you get that kit in EU?
Hi, I build your color organ on breadboard! It works but the middle frequenzes are a bit low, it means that the green Led flickers with very low brightness. Do you know how to fix it?
Swaynee
How, and where do i connect the rgb strip on the PCB?
