DIY Basin/birdbath From Stone
10,713
92
16
About: I love creating. No matter what.
Start by finding the rock you want to use for your basin/birdbath. make sure it does not have obvious cracks as that will be where your project breaks later in construction.
Supplies:
Step 1: Marking Your Bowl
Use chalk or a scribe to mark the outside edge of the bowl you will be creating
Step 2: Right Tools for the Job.
Start this project bu using an angle grinder (in this case 115mm grinder) fitted with a wet and dry stone cutting diamond edge steel blade to cut the stone along the chalk or scribe line you drew on the rock to permanently mark it. In addition to the grinder you will need a strong thin stone chisel and reliable hammer. Please make sure you have a good pair of safety glasses as the stone shards (granite in my case) are as sharp as glass and can easily blind you if it ends up in your eyes.
Step 3: Cutting and Removing Rock to Make the Bowl.
Once you have cut the outline of your bowl, start cutting lines as deep as the blade will go in the rock within the outline you created. Shallower at the edges and deeper towards the middle. Using your hammer and chisel knock these slats of stone out (wear your safety glasses here).
Once an entire layer has been removed, repeat the process but cut diagonally to the previous cuts and chisel them out.
It's dusty work, as you can see. a Dust mask or hasmat mask is a good idea.
Step 4: Smoothing and Finishing the Bowl.
Once you have removed the bulk material from the rock and reached the depth you desire its time to smooth the bowl.
using the same diamond edge steel blade start smoothing the rough break and chisel marks left by the tools.
It remains a dusty job,and should only be attempted outside.
If you happen to own a wet stone grinder attachment this step will go quickly. (I don't so i did it with the diamond blade)
keep going until you are satisfied with the smoothness.
Step 5: Finished Product.
This item is a birdbath but if a basin is required a 40-50mm stone hole saw can be used to drill a drain hole for the bowl.
Happy cutting and creating.
  • Arduino Contest 2019
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
16 Discussions
haltenfelder
3 years ago
dust mask? An artist needs to feel/breath the material he is working with to get that "connection" :-)
pleasedontspammehaltenfelder
Reply 3 years ago
If by connection you mean get Silicosis...
I can't even enjoy knintknapping anymore without worrying about it. That said, nice work. I'm thinking nice pound in the corner of the yard that doubles as a chicken waterer. Now what where those fish that eat the misquito larva called...
ironsmiterpleasedontspamme
Reply 3 years ago
If you are managing to breath stone chips from knapping, I think you are doing it wrong :-) But you are definitely right, the picture of dusty nose means you've been breathing the stuff... and even with the eye protection keeping you safe from chips (a GOOD thing), consider a full face shield. the dust may not blind you, but it can still be a major eye irritant. Personally, the last time I did any granite sculpting, I borrowed the old man's full-face, power ventilated, hepa filtered welding helmet(and used a clear poly carbonate lens).
A nice heavy mist of water will help keep the airborne grinding dust to a minimum. Better still, if you can, flood the cut with water, and use air tools (electric angle grinders, of the variety we are likely to own, do NOT like getting wet).
Call me paranoid if you want, but I prefer to use bottled oxygen for welding, not because I need it for breathing.
pleasedontspammeironsmiter
Reply 3 years ago
When you knap, besides the larger flakes, there are always fine particulates that get airborne. In the days of flintlock rifles, the poor slob hired to knap the flints would get sicosis with two to three years.
KellyCraig
3 years ago
Now, go get a grinding stone, a backing pad and some polishing pads (the type that need water lubrication and cooling last far longer than dry pads). Of course, you can also invest in the heads they use to smooth concrete and such.
The big grinding stones only run about seven to ten bucks and can even be used to round over edges on granite tile.
Dump these on a variable speed grinder and run them at low speed and you'll have all sorts of fun. I have some basalt rocks I polished out in the drive and they're almost like a dark brown obsidian.
KellyCraig
3 years ago
Where in the hell is your dust mask?
I play with granite using a variable speed grinder for my cutter and to run my router bits and polishing heads. Most of what I do is with water, which is nasty enough (much of the water gets vaporized and carries dust with it).
All that aside, nice job.
cryodog60
3 years ago
Really nice. I've been looking for something like this. I have a large rock or should I say boulder that I wanted to build a fire pit in it. It measures about 6' across and is about 30" thick. It takes a backhoe to move it. I might try this method. The only issue that I might have is that it is chert, very similar to flint hard as hell. We shall see. Who knows, maybe I do an Instructable about that effort.
nengelbrechtcryodog60
Reply 3 years ago
a note on what you want to do. make sure your rock is heat resistant... i am not familiar with that type of rock as we do not have Flint rock in South Africa or don't have it in large enough quantities for me to have ever come across it. Slate we have a lot of, but that stuff explodes if exposed to high heat... so phone your geological society and ask the right questions.
cybergod
3 years ago
Love your work. An interesting little idea. Might just try it. I do love your Japanese Safety Boots as well ? (no offence meant for Japanese people, it is just an Aussie bit of humour).
nengelbrecht
3 years ago
I added a suggestion of dust mask for the dust created...
KLethal
3 years ago
nice job!! How long did it take to make it ?
nengelbrechtKLethal
Reply 3 years ago
takes about 4 solid hours to complete, given the rock is not too hard or you have a large grinder.
