DIY Beer Bottle Lamp
676
About: So basically i am a crazy person, who loves to think the most odd way ever possible,who makes what he thinks and also let other also make those . Check out my crazy projects if you like do follow me :D
Hey guys in this Instructable, I will show you how to recycle old glass bottle into a beautiful Night Lamps.
This Night Lamp is a portable one and works on CR2032 Battery.
Each Battery Lasts for around 20 Hours on Constant Drain.
Step 1: You Will Need
For this Project, you will need
Step 2: Solder the Fairy Light
Cut the Fairy Light From the battery holder, this battery holder can be reused for some other project.
Taking a CR2032 Battey Holder connect the terminals to the two wires of the fairy light.
Keep a Mind about the polarity of the LED Light
Solder it Using some third hand, check out this third hand
https://www.instructables.com/id/DIY-Flexible-Sold...
Step 3: Take the Label Out
Using some Hot water and dishwashing soap, prepare a container to dip the bottles.
Soak the Bottles for 30 min then scrub them slightly the labels will feel peel off easily.
Step 4: Put the Light in the Bottle
Now drop the Fairy Light in the bottle slowly, Once the end part comes to put the battery holder in the top of the bottle. You can use Glue gun to secure it but I have used some Black Tape to keep it secure.Once everything is done you can put the battery in and enjoy the ambiance.
Tape Contest
This is an entry in the
Tape Contest
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    AnandM54
    5 weeks ago
    Cool idea !!
