DIY Build - One Sheet Plywood - 48 Bins Organizer
27,467
421
20
How to build a very simple wall organizer using one single sheet of plywood and 48 plastic bins. I am building my workshop and I needed to add storage for my small parts. Quick and easy to build, this will organize my workshop. Im using small plastic bins : 6"1/4 wide, 3"3/4 high, 7"1/2 depth.
Step 1: ​Material :
For this project, you will need :
- 1 full plywood sheet (48"x96") or in my case i had some leftover plywood. (5/8 Thick)
- Wood Glue
- Nails or Screws ( or both for stronger build )
- Paint ( I used leftover wall paint )
Tools :
Table Saw
Miter Saw
18GA air Nailer
Sander
Drill or Impact Driver
Step 2: Cutting PLAN
Here is the cutting plan for all 15 pcs.
Step 3: Cutting the Pieces
Im using my table saw and my miter saw to cut all the 15 pcs.
13X : 24"3/4 x 7"1/2 (629mm x 178mm)
2x : 62"1/8 x 7"1/2 (1578mm x 178mm)
Once it's done, im sanding all pieces before assembling.
Step 4: Assembling Parts
Im using two 4"½ spacers to make sure i have the same distance between shelves. It also makes my job easier. Im using wood glue and brad nails. Later i will put trim screw to to add strength.
Step 5: Adding Screws for Stronger Build
Because i plan to put a lot of weight in my bins, im adding screw to add strength. It's for my workshop but i still want a clean look. So trim screw have a smaller head than regular wood screw, and im using a jig i made to make sure that the same distance separates them.
Step 6: Painting
Im using leftover latex wall paint to add some color to the plywood.
Step 7: Final Result
Now it's time to mount on the wall. I located 2 studs and used metal cornet brackets to make sure it's solid. I plan to put lot of stuff into my bins. I will add labels later. Im starting my youtube channel about DIY's and i have build this wall organizer for all my small parts.
Thanks for reading my first instructable.
You can also watch the full video of this build here : https://youtu.be/MPj2apcCdhw
More projects here : youtube.com/SEBTECHDIY
    • Build a Tool Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    20 Discussions
    kbbaktha
    1 year ago
    Excellent storage of various items in bins and in this lovely bin cabinet. Thanks for sharing.
    Rjacob5201
    1 year ago
    Not sure how that works out. Your bin is 6 1/4 wide x4=25 in. and your shelves are cut at 24 3/4.
    CopyuRjacob5201
    Reply 1 year ago
    Funny, but I noticed that immediately, too. (I live in a country where "inches" are only for TV screens!) Any response from the original poster?
    Adam
    johndubchak
    1 year ago
    I love your spacer jigs, they were pretty sweet.
    joshua.artist
    1 year ago
    Nice instructable. If you paint it before assembly it'll be much easier. You can just roll it. Paint your end cuts too if it's going in your garage or basement.
    Swansong
    1 year ago
    That looks awesome! I would LOVE something like that for all of my sewing stuff. :)
    GromM1Swansong
    Reply 1 year ago
    I was thinking the same thing.
    jstork1
    1 year ago
    I hang my cabinets in my shop with French Cleats. It makes it very easy to mount, reorganize and move them. That way I don't have to worry about hitting the studs once my rails are mounted to the wall. I might use them to mount my kitchen cupboards when I eventually renovate the kitchen.
    NitroRustlerDriver
    1 year ago
    Found from his YouTube comments, these are the bins he used:
    https://www.amazon.com/KIS-Accessory-2-2-Quart-2-1-Liter-20-Pack/dp/B00BJ04MD6/ref=sr_1_fkmr1_3?ie=UTF8&qid=1495746461&sr=8-3-fkmr1&keywords=kis+omni+box
    nex_otaku
    1 year ago
    Very simple and sooo useful! Love it!
    ThirdEarthDesign
    1 year ago
    Great build, I need something like that for my new workshop (when I get round to fitting it out).
    tafkaFP
    1 year ago
    I too would like to know - where did you get your plastic bins ? How much were they ? In hindsight is there anything you would have done differently about the build ?
    bruce.desertrat
    1 year ago
    That screw jig is pure genius! This would also mount easily on the wall with a french cleat setup
    p0laris
    1 year ago
    That screw placement jig... simple and genius.
    ericlawrence
    1 year ago
    Nice, simple and well done. Can you link to your source for bins?
    sherlock1951
    1 year ago
    Awesome idea, job and instructable!!! Thank you
    jeanneambro
    1 year ago
    Very nice reference and great job on your first instructable. Question - is it really necessary to use 5/8" thick stock for the shelves? How heavy are your parts? Thx. J
    BeachsideHank
    1 year ago
    Can never have enough storage drawers, quality clear plastic bins with decent pulls are hard to find, do you have an inexpensive source for yours?
    gm280
    1 year ago
    Nice clean build. Thumbs Up!
