DIY Bullet Headphones
23,978
501
61
About: DIY projects, personal Tipps, Instructions and well made Videos. That`s basically all what I`m here for! :D Want to support me? Show me some love on my Youtube Channel!
Dear DIY Fans,
This little Project is about crafting your own Bullet Headphones. They do not just look unique and stylish but also sound pretty well. It is a weekend project, wich is not expensive at all, but it requires some basic crafting skills.
I produced an aesthetic video, that will guide you through the main steps and hopefully will be some Inspiration.
If you like my very first Instructable, please vote for me in the FIRST TIME AUTHOR CONTEST 2016.
Thank you!
Step 1: DIY Video
Step 2: Drilling
Use 2 caliber .45 ACP cartridge cases and drill a hole (2mm drill bit) diagonally among the rim below.
I recommend clamping them into a vice to assume maximum stability during the drilling process.
You can use a puncher to create a little dent for the drill bit, but it is not strongly necessary as long as you start with a low drilling speed.
Useful advice:
Make sure to protect the jaws of your vice to avoid damage on your cases.
Step 3: Sawing
Saw the cases down to a length of 7 - 10 mm and sand down the edges roughly by using a course sanding sponge. I shortened them down to a length of 9mm in the video and i think it is the optimal size.
Useful Advice:
You can also use sandpaper to clean the sawing edges but a sanding sponge is not very expensive and will produce a smoother result.
(You could also use whats called a "debuting tool" from gun stores, to clean up the edge after it is cut off. Thank you H2Okee for giving this advice down in the comments!)
Step 4: Increase the Internal Space
Use a 9mm drill bit to increase the internal space to create room for the copper wires and to lower the weight.
Keep drilling until you can see a circular hole on the bottom and make sure to check the depth a couple of times during the process to avoid drilling through the bottom.
Step 5: Polishing (most Satisfying Step)
I recommend to attach a wooden staff with a thickness of 10mm and a length around 3-5 cm into your screwdriver and to stick the cartridge case on it. Now use a fine sanding sponge to reveal the shininess and the golden color (satisfaction guaranteed). I took a few centimeters of my grandmas wooden cooking spoon (she was okay with it). It turned out to work just fine for my needs.
Useful Advice:
I highly recommend using this method for polishing, because of the speed and the even result.
Step 6: Varnishing
Varnish the cases to protect them from external influences and to retain the metallic shininess.
I recommend using Zapon Lack. Small varnish lines during the daub process will disappear within drying.
Also varnish the inside to create a thin isolation-layer .
Step 7: Prepare the Original Headphones
The exact model number is Panasonic RP-HJE120E1R. These Headphones are pretty affordable and they have really good sound (literally thousands of positive amazon reviews).
Clamp the ear buds into a vice (with good protected jaws) and lift them softly out of their shell (watch the video in minute 3:26). You can now cut off the copper vires from the ear buds but I advice doing a quick photo of the connections at first. It will be easier to match each wire to it`s contact on the ear bud later in the soldering process. You can finally remove the old Shells.
Step 8: Marriage
Remove 1cm of the rubber isolation of the cable wire to reveal the fine copper wires. Then cover the end of the cable wire with shrinking tube (1cm long and 2mm thick). The picture above will give a good idea of the exact distances.
You can now stick your prepared cable wires through the hole of the cartridge case until you can see the black shrinking tube from the inside. A drop of superglue in the inside will provide final fixity.
Step 9: Soldering and Assembling
You can now finally resolder the wires to the contacts on the ear buds. Make sure to match the cables right. The photo you took a few steps before will help you with that. Time for a quick soundcheck.
You can now push the ear buds into the cases by hand or with a vice. They will stick together perfectly, even without any glue. You did it.
Attention:
Soldering is more difficult than it looks. If you do not have some experiences with it, I recommend to ask a friend.
Step 10: Thank You
I just want to thank you for reading my DIY Post. I hope I could inspire you for this little DIY project. I love these Headphones and I felt like I had to share it within an equally aesthetic video. If you want to support me and future projects, please subscribe to my Youtube channel and give me some feedback in the comments.
Please send me a picture if you could successfully rebuild the Bullet Headphones.
NOTHING IS BETTER THAN HOMEMADE!
First Time Author Contest 2016
First Prize in the
2 People Made This Project!
  • Pie Contest
    Pie Contest
  • Jewelry Challenge
    Jewelry Challenge
  • Fat Challenge
    Fat Challenge
61 Discussions
You can go to a gun store and get new empties (Which are actually meant for reloading but you can use them for this!) They sell these in any size that can be reloaded! 9mm would be good.
DDW_OR
2 years ago
could do one side as brass and the other side as aluminum, Left and Right side.
LoganB22DDW_OR
Reply 2 years ago
Good idea, better then engraving more marks into the casing. Like L/R.
LoganB22
2 years ago
That looks so easy, except getting the spent cartridges. How would I be able to do this with the flat non-tangle wire earbuds? What would you recommend to cut the wire hole?
cbjack
2 years ago
Loved it, now I can recycle some of the casings I see at the gun range. Very well done, very clear instructions and the music was not intrusive. Good work!
Natalina
2 years ago
Clever project! And wow amazing documentation - way to rock your first instructable. How do they sound compared to the original headphones? Curious if you can notice a difference.
JoeP70
2 years ago
Nice photos and narrative presentation. Going to have to try this out, after I bring home some brass from the next range session...
deswiger
2 years ago
I HOPE THEY COME IN A 50 CAL. SIZE FOR ALL OF US WHO LISTEN TO HARD ROCK WITH OUR EARS NEXT TO THE SPEAKERS WHILE TEST FIRING OUR 60mm MORTORS........ just kiddin', nice job. Thanks for the share, got to try this. Semper Fi.
Kiwi464
2 years ago
are there any other calibers that this would work for. 45. is'int a very common one in NZ.
KenStone
2 years ago
Great post. Great idea, Great photos. I really enjoyed this one. You really thought out the procedure before making this and it shows.
chevy
2 years ago
I wonder if i can make a pair of ear plugs, when i ride my motorcycle .
H2Okee
2 years ago
Congrats on the creativity, they look and I'm sure they are functional. Two thought for you as I am a reloaded of ammo, 1.) what you referred to as a cartridge sleeve is properly called a case, not a big deal as the pics help me understand what you are referring to, 2.) You could use what's called a debuting tool to smooth the edge of the case after its cut off, that's their purpose and they are very inexpensive at gun stores that sell reloading tools, if you don't have access to this tool your method works fine. I found your project creative and unique. ?
Rideable EntertainmentH2Okee
Reply 2 years ago
Thank you for the feedback. I am sorry for my bad english and I am sure there are probably many more mistakes in my instructable. I am going to do my best to find some of them the next days. Thanks for the advice again.
Rideable EntertainmentLeonS5
Reply 2 years ago
That's actually a good question, I want to answer here. I bought mine at eBay (10 cartridge sleeves for about 5€).
I know that some online Shops sell bigger packages of sleeves (50+). But you can write to your local gun clubs, if they can give you some. If you live in germany, I can send you a few of mine. I got some left. Hope I could help you at least a little bit.
