DIY CNC Table & Tool Storage Cabinet | How to Build
About: Weekly how-to project videos about #woodworking, metalworking, and more. #Maker. Created by Johnny Brooke.
In this video and Instructable, I'll show you how I built this workstation for my new CNC, the Shapeoko 3 XL! This unit also doubles as a tool storage cabinet and would also be great for those benchtop tools you don't have a good spot for in your shop. Drill presses, bandsaws, lathes, sanders... they would all fit nicely here. Let's get started!
Step 1: Purchase Your Materials & Gather Your Tools
For this build, I used 3 sheets of ¾" plywood and 1 sheet of ¼" plywood. You'll also need an 8 foot 2x2.
For hardware, you'll need:
Here's a list of the tools I used:
Step 2: Break Down Your Sheet Goods
To break down the sheets of plywood, I used a combination of a circular saw, table saw, and miter saw. You could use a circular saw for all of the cuts, but you'd have a much more difficult time keeping your cuts square.
For exact measurements of the pieces in my build, I have plans available here. The plans include a detailed cutlist, cutting diagram, and SketchUp file.
Step 3: Assemble the Tool Storage Cabinet
For assembling the cabinet carcass, I used a pocket hole jig. This is a phenomenal tool for cabinet construction, as it creates a sturdy joint that's simple to create. Using the carcass pieces I cut in the previous step, I assembled both of the carcass assemblies.
Step 4: Add Leveling Feet to Tool Storage Cabinets
In the Hardware section at the top of this Instructable, you'll see the parts needed for the leveling feet. These parts are 8 pieces of 5/16" T Nuts and 8 pieces of 2" 5/16-18 stainless carriage bolts. To install the feet, first attach the 2x2 piece inside the bottom of the cabinet carcass using wood glue and 1 ¼" screws.
After the 2x2 pieces are attached, drill one hole at each corner, pound in a T-Nut with a hammer, and then thread in the carriage bolt. Voila! You have a set of leveling feet that will not rust and are incredibly sturdy.
Step 5: Assemble and Install the Drawers
To build the drawers, lay out your drawer sides onto the drawer bottom. Using the bottom as a template, attach the drawer sides using 1 ¼" brad nails and glue. Assembling the drawer sides on top of the bottom will ensure your drawers are squared. Also, attach the bottom with glue and 1 ¼" brad nails. Reinforce each corner of the drawer and the drawer bottom with 1 ¼" screws.
After the drawers are assembled, install your drawer hardware. Spacer blocks are helpful here, as they make sure the drawers are level and evenly spaced.
Step 6: Level Tool Storage Cabinets & Install CNC Table Top
Place the cabinets in their final location and level them using the leveling feet. Connect the two cabinets using 1 ¼" screws through the sides of the cabinet. After the cabinets are connected, install the top by attaching it with 1 ¼" screws through the carcass below.
Step 7: Install Bottom Faceplate and Drawer Fronts
Attach the bottom faceplate using screws from the inside of the cabinet carcass, then install the drawers. Once installed, cut a ⅛" spacer and attach the drawer fronts, using the spacer in between each drawer front. Temporarily attach the drawer front using spring clamps, then attach them permanently using 1 ¼" screws from inside.
Step 8: Attach Hardwood Trim to Front of CNC Table
Cut a piece of hardwood to size and then attach it to the front of the CNC table with glue and brad nails.
Step 9: Add Your CNC / Benchtop Tools and Get to Work!
If you'd like, you can roundover the edges of the top and add a finish. I'd recommend a basic polyurethane finish here. With that, the CNC table and tool storage cabinet is done! Hopefully you enjoyed this build! This tool storage cabinet will provide tons of storage in your shop and is a perfect spot for your CNC or benchtop tools.
If you'd like to check out more of my builds, subscribe to my YouTube channel. I post new projects every Tuesday. Thanks!
Step 10: BONUS: Watch Me Build the CNC!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    2 Discussions
    seamster
    2 years ago
    This is a great looking cabinet. It would be awesome if you included a cut list or diagram for the various components :)
    craftedworkshopseamster
    Reply 2 years ago
    Recreating all of that info here on Instructables would be too much work. The exact measurements and cutting diagrams are available on my website. Thanks!
