DIY Cardboard Mobile Stand
3,281
13
About: Always pass on what you have learned. https://www.youtube.com/yodha4u
I'm making a simple mobile stand out of cardboard. This is a pretty simple process and is a good beginner DIY project.
Uses of Cardboard Mobile Stand
  • Use at Desktop
  • Use in Kitchen
  • Use at Terrace Table
Items Required for Cardboard Mobile Stand
  • Cardboard
  • Scissor
  • Ruler
  • Pencil
  • Eraser
  • Blade
  • White Sheet.
Step 1: Arrange All Tools at One Place
Make sure all tools are at one place so that easy to find all objects.
Step 2: Prepare Design on Sheet
Prepare Design template on sheet, also make precise marking on sheets.
Step 3: Cut the Design Template
I used a scissor to cut all the outline of Design - I.
Step 4: Make a Triangle Cut
In triangle cut, These marking are:-
for Fold ( - - - - )
for Cut ( ____ )
Step 5: Prepare the Other Half
Make sure the other part has similar size of cuts, which includes a equivalent triangle 1.4 cm and vertical cut of 4.2 cm. Cut The triangular shape through blade.
Step 6: Prepare Cardboard for Cuts
Draw an outline with the help of template sheet on cardboard.
Step 7: Cut Cardboard As Per Designed Outline.
Start making cut the cardboard as outlined.
Step 8: Use White Sheet Paper
Use white sheet for triangular and vertical cuts.
Step 9: Cardboard Mobile Stand Is Ready
Join both cardboard and fold the triangular shape which gives a support and balance to stand.
    • Pie Contest
      Pie Contest
    • Paper Contest
      Paper Contest
    • Weaving Challenge
      Weaving Challenge
