DIY Cat Tree.
12,983
280
16
I hadn't originally planned to write an instructables, so I didn't take pictures of every little detail. I've also not written an instructables before - but hopefully these instructions are still good enough. :)
I wanted to get a cat tree but didn't like the ones you can buy - so I built my own. This cat tree was built for a cat who loves to climb things, so the tree is fairly high and all the platforms are facing towards the wall so that the cat can climb up the post.
The cat tree is 180 cm high and all platforms are fixed to the wall. The lowest (large) platform is 60 cm above the ground, the other (small) platforms are attached every 30 cm, i.e. at 90, 120, and 150 cm, and on top (180 cm). The small platforms are 20 x 40 cm, the large one is 40 x 40 cm. These dimensions work well for a medium sized cat (5 kg).
Materials:
  • square edge timber (2400 x 44 x 44 mm)
  • plywood (16 mm thick) cut into four 20 x 40 cm and one 40 x 40 cm pieces [for those in the UK: you can buy this at B&Q and they will cut it for free]
  • sisal rope (10 mm diameter)
  • angle brackets (I used lightweight 100x100x20mm brackets for attaching the platforms to the post, and lightweight 40x40x15mm brackets for attaching the platforms to the wall)
  • screws and wall plugs
  • double-sided tape
  • optional: carpet underlay
  • carpet
  • timber or plywood for the base (minimum size 450 x 50 mm)
Tools:
  • saw
  • hammer
  • screwdriver
  • drill
  • staple gun (heavy duty)
  • Stanley knife
  • measuring tape
  • spirit level
Supplies:
Step 1: Prepare the Posts
Cut the timber (240 cm) into two pieces: 180 cm and 60 cm.
Attach the brackets to the posts, using reasonably long screws (something like 4x40mm should be alright). Drill holes into the post before putting in the screws.
60 cm post: one bracket at the bottom and one at the top.
180 cm post: one bracket at the bottom to attach the base, 4 brackets along the post to attach the platforms (at 60, 90, 120, and 150 cm), and two brackets at the top. First I only used one bracket for the top platform but it was too wobbly, so I squeezed in a second smaller bracket (after I had already attached the rope to the post). I would definitely recommend using two brackets for the top platform.
Step 2: Wrap the Rope Around the Posts
Attach the sisal rope to the post by putting a screw through it.
Attach the rope on three sides, to make sure it doesn't slip off the post. On the fourth side it is held in place by the bracket.
Start wrapping the rope around the post. I found it works quite well to turn the post while keeping tension on the rope. Make sure the rope is wrapped around tightly, hitting it with a hammer every few turns helps to make it more compressed.
When you reach a bracket, attach the rope with a screw directly underneath the bracket - that way the screw is out of the way and the cat won't get the claws caught in it.
When you reach the end of the post, attach the rope on three sides of the post again (the same way as at the beginning).
Step 3: Prepare the Platforms
I used 16 mm plywood for the platforms, but other materials (such as MDF) should also work.
Optional: Cut carpet underlay to the same size as the platform and attach with double sided tape. Some sort of foam could also be used instead of underlay.
Cut carpet to size, slightly larger than the platform (additional 2-3 cm on each side). Attach carpet with double-sided tape.
Staple carpet to the underside of the platform. I used two rows of staples to make sure the carpet is properly secured. Leave space for attaching the brackets. On the side of the platform which will be facing the wall I only attached the carpet on the side of the platform and not the underside.
Step 4: Put Everything Together
The platforms are fixed to the wall with small brackets. First attach these brackets to the platform, and then attach the platform to the post. Each platform is attached with two brackets, except for the top platform which only has one bracket.
I assembled the cat tree in the following order:
  • attach the three middle platforms to the tall post
  • attach the top platform to the tall post
  • attach the bottom platform (40 x 40 cm) to the tall post
  • attach the short post to the bottom platform
  • attach the base (I used some timber which I had lying around, but a piece of plywood would also work)
Attach the cat tree to the wall. Each platform is attached with two brackets (except the top one, it only has one). Make sure the screws fit through the holes in the brackets before drilling holes in the wall. Use appropriate wall fittings - I used 5 x 50 mm screws and 45 mm wall plugs. The platforms bend a little bit because they are only attached on three sides - but not much, and they are more than sturdy enough to hold a cat.
Step 5: Add Cat
Done!
2 People Made This Project!
  • Classroom Science Contest
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
16 Discussions
grannyjones
1 year ago
Climbing is great exercise for cats, and allows them to get to a safer place in case killer dogs are about. On top of that, climbing kitties are so cute. In Europe, declawing is not tolerated, as it is CRUEL. It should be illegal everywhere, but is not. (sad face)
sheppenstein
2 years ago
you did vary well for your first instuctible
Kerstin247JohnBradley79
Reply 3 years ago
It's an important step! Although tbh, the cat didn't really wait until the cat tree was finished, he kept testing it while I was still building it.
Ferg70Kerstin247
Reply 2 years ago
otherwise known as quality control. Fairly standard cat policy.
JohnBradley79Kerstin247
Reply 3 years ago
I`ll try to make something similar for my furry friend. Just need some spare time to go to the village house and collect the wood I`ll be using.
(Got a lot left since we rebuilt the roof and took down a few sheds/old animal buildings)
P.S The pic is taken while we were still demolishing.
Dr.Bill
3 years ago
Meow !
Dr.Bill
3 years ago
Meow !
Splizwarf
3 years ago
Is there a specific reason to use square-sided true-dimension lumber or is it a stylistic decision? It seems like the sharp corners might be a bit harder on the rope vs mildly beveled lumber (which is usually cheaper and a bit easier to find in the US).
Kerstin247Splizwarf
Reply 3 years ago
No, there's no specific reason for using square-sided lumber, I just used it
because that's what I could get easily. I don't think the sharp corners
are too much of a problem unless you use very thin rope. I used 10
mm rope and I've not noticed any problems yet - both the cat tree (built
about 6 months ago) and a scratch post (built about a year ago) are
still holding up fine. I don't see any reason why you can't use mildy
beveled lumber, it should be fine as long as it's sturdy enough and there's enough space
to attach the brackets for the platforms.
Attmos
3 years ago
I like the design, looks like your cat does too! :) Wish my cat was a climber.
Kerstin247Attmos
Reply 3 years ago
Yes, my cat likes the design too - it's very climbable and scratchable, which are definitely good features. :)
musicmen
3 years ago
Muy bonito!!!
tomatoskins
3 years ago
This is awesome! Great call with securing it to the wall.
Kerstin247tomatoskins
Reply 3 years ago
Thanks! I didn't want a wobbly cat tree with a massive base, so attaching it to the wall seemed to be the best option. I've actually built this a few months ago, and no signs of wear so far.
