DIY Corner Radius Templates
10,071
148
6
About: Hi I'm Kriss! I’m a 20-something that likes to build tools, jigs, and other random contraptions with wood.
A set of corner radius router templates is one the most useful accessories for the router table. This 'ible presents an easy way to make your own!
Stuff you need:
Step 1: How It Works
To ensure perfect templates: a bearing guides the radius cut, then a jointing-action flattens the adjacent side. I drilled a hole for a view of the cutting action.
Step 2: Plans
Free plans for the jig are attached!
Step 3: Hijack a Bearing
The bearing of a flush trim router bit is removed. This will be used (temporarily) to make the templates!
Step 4: Pick Your Radius
Pick the radius you want, and place the bearing accordingly.
Step 5: Set Up the Jig (1 of 2)
The corner of the jig should be in contact with the bearing.
Step 6: Set Up the Jig (2 of 2)
The edge of the jig should be parallel to the workpiece.
Step 7: Routing Action!
Pivot the workpiece around to make the radius cut.
Step 8: Trim It
Cut the template at the mitre saw to any desired size.
Step 9: Drill It
Make a hole so you can hold onto the template while in use.
Step 10: Cut Aluminum Angle
Two aluminum bits form the edges. A length of aluminum angle is cut at the mitre saw. Aluminum machines quite well with regular woodworking tools.
Step 11: Drill the Aluminum
Create two screw holes in each aluminum piece.
Step 12: Complete the Template
Screw down the aluminum angles.
Step 13: Make Any Radius!
The jig can make any radius template you can imagine.
Step 14: Happy Routing!
HIGH FIVE for reading!
    • Remix Contest
      Remix Contest
    • Epilog X Contest
      Epilog X Contest
    • Tape Contest
      Tape Contest
    6 Discussions
    Jobar007
    2 years ago
    Really neat idea. I like the use of the tool that you are making the jigs for.
    danprice48
    2 years ago
    Very cool. I've had a router for a long time but not really used it in any depth--this will help get over that hurdle. Thanks for such clear instructions!
    Jayefuu
    2 years ago
    Thanks for posting more here Kriss! This one's definitely on my "to make" list
    HomeBrewski
    2 years ago
    I really enjoy your instructables, than you for posting this. Hope you make more (I have subscribed to you on YouTube also).
    That straight edge you used to measure 3/4" from the edge... do you happen to have a link to that? Very cool!
    ToolifyHomeBrewski
    Reply 2 years ago
    Thanks!
    Here's a link to the ruler: http://amzn.to/20TBZIx
    mortenlc
    2 years ago
    Very nice. Thanks!
    Cool idea with the "peephole" :-)
