DIY Crypto Mining PC (ETH, XMR, ZEC)
5,812
83
6
This guide is going to show you how to build an Ethereum Mining rig yourself which has two main steps - choosing and sourcing your equipment and then putting it together! Depending on times its probably going to take you a week or so to get all the pieces and then another half a day fiddling with configurations etc. Its the same as building your own computer normally but with a few extra considerations that mainly involve which GPU's you pick.
If you don't want to buy mining equipment, You can also try buying a cloud mining contract with Hashflare or Genesis Mining.
Step 1: Sourcing Equipment
1) A MotherBoard - A motherboard is the brain of the computer and is what you build everything onto - the base of your mining rig. The main feature you are looking for in a motherboard is the number of GPU slots it has as this will determine how many graphics cards or GPU's it can fit - and in the end your total hashing power. 3 PCI Express slots will mean you can fit 3 x RX 580 with a hashrate of 20 MH/s each - or a total hashing power of 60 MH/s. A PCI Express slot is a connection port on the motherboard and looks like the picture below - they are often coloured white but can be different colors- you can get other types of slots but most GPU's work on a PCI express.We used the GA-Z97X-Gaming 3 which you can get here!
2) Graphics Card - Pick your GPUs! Some graphics cards cost a fortune but don't hash much whilst some are more reasonable but use more power. Ultimately its a balance between how powerful you want your rig to be and how much you want to spend - but a word to the wise - make sure you pick an efficient GPU. You can buy second hand GPU's from reputable providers such as GPU Shack - be careful though when you buy them off a street corner as often they have problems that you won't see until you get the card home and plugged in. I have a list of GPU's here that you can sort through and work out what fits your budget.
3) Hard Drive - You need a hard drive to store your operating system and your software for mining. A standard SSD drive will do (an SSD hard drive is just a storage device and is called solid state as there aren't moving bits which can break). The size will depend on what you are planning to do when mining. If you are planning to download the entire blockchain and mine as shown in this guide here - then you will need to take into account how big the blockchain will become and need to spend a little more. If you are just going to mine ethereum as part of a pool then you don't need to store the blockchain and can get a smaller SSD drive. We used the SSDNow V300 120GB. Buy it here.
4) RAM - or Random Access Memory - this is a basic component in any computer is basically a scratchpad for jotting down calculations and recalling information quickly in a computer. 4GB should do the job.You can get some here.
5) A PSU or Power Supply Unit - Power supply units come in many sizes and this can trip some people up when they are looking at calculating what size they need. You need to sum up the power consumption of your GPU and all the other components and make sure your power supply has the capability to supply more! So if you have two GPU's that consumes 220 Watts and other components that need 250 Watts then you can get away with a 750 Watt power supply unit as the total power needed is only 690Watts.If you are building a "mega rig" which has 6 GPU's you might find it more cost effective to have two separate power supplies because at 750 Watts and $100 each rather than a 1500 W and $300 dollars!We got a Seasonic 1200 Watt which you can buy here.
6) A Case - Again this can be quite a difficult choice to make as it will depend on your GPU's and whether you are using GPU risers. You don't want components sitting on top of each other as there is a fire hazard potentially. You can leave the whole system open air or even build your own case to give it that personalised touch. You can buy off the shelf rigs from a couple of providers - for example SW mining here have their own set of rigs that take up to a week to ship. They do all the hard work for you.
Step 2: Connecting GPU's to Motherboard
Depending on how many cards you are to include in your build, you will need to mount the cards externally. To do this you will use extensions called risers which can be acquired on various online stores like Amazon. These let your GPU be away from the motherboard which also helps with heat dissipation. Once you have your riser, you will connect the GPU to it like you would to a regular PCI x16 slot on your motherboard. DO NOT FORGET TO PLUG IN POWER CORD FROM PSU!!!
Step 3: Connect Risers to Motherboard and POWER
The GPUs will take two kinds of power input. First, they’ll need the GPU riser to be powered through the SATA to Molex connector. This allows the PCIe interface to use reference power from a location other than power pulled from the board. While PCIe is capable of powering from the board through the PCIe interface, the amount of power we’d be drawing from the board for all six GPUs isn’t feasible. As such, we’ll need to get SATA power cables out and attach them to the back of the power supply to the SATA ports and then to the six SATA tails coming from the six GPU risers as well as one additional for the SSD that we mounted earlier in the process. These cables add a good bit of clutter, so do your best to keep them neat.
Also connect poer plugs from PSU to GPU itself.
Step 4: Add Windows OS and Install Mining Software
The first thing you need to do is install an operating system on your computer. For the more technically minded there is linux Ubuntu but for the majority Windows is probably best as it automates installing drivers for your computer to talk correctly amongst all the components. The advantage of Ubuntu is it gives you more options and its free!
You can download EthOs which is a specifically designed APP for Ethereum Mining - you can read more about this online but its a great way of having a bespoke mining system for your rigs and GPU's to manage them! Once you have installed the operating system there are two ways you can mine: Solo Mining - Solo mining means its you against the rest. If your hash is correct you win the block reward. But with a rig of 60 MH/s and a network hashing power of 1.2 GH you aren't going to get ether very often. The other issue is you have to download the blockchain for yourself. See our guide here on how to solo mine ethereum. Pool Mining - This is where you team up with other miners to reduce the volatility of your returns. This means whether you get 5 ethere every 5 days or 1 ether every day. The advantage of this is you get a continuous stream of ether and you don't have to download the entire blockchain.
You are now ready to mine! Good Luck out there!
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    6 Discussions
    BrownDogGadgets
    Question 1 year ago
    Wouldn't it be easier and cheaper to just buy coins instead of spending all that money on PC parts?
    1 answer
    DIYPro0505BrownDogGadgets
    Answer 1 year ago
    It might be, however if you buy good hardware, you can mine coins with if for a year or two, then get your coins and sell the hardware. That would make your coins only cost the difference of what you paid for the system and what you sold it for.
    DanielB822
    Question 1 year ago
    Hi. I'm considering making a simular rig like yours. Have you calculated the costs of running it and compared it to the realistic potensial profits?
    DIYPro0505DanielB822
    Answer 1 year ago
    Hello, yes i have compared the profits to the costs. And have come to a conclusion that it depends if you want to HODL your coins and wait for price increase or want to sell as soon as possible. Currently living in NYC i pay $0.21 per kwH and its not too profitable at the moment but i am working on moving the system to a place with cheaper electricity cost. IF you don't want to mess with all this hardware and electricity cost you can always try cloud mining, I personally also use HashFlare.
    painfullDanielB822
    Answer 1 year ago
    Hi DanielB822, I live in QLD AUST, and we pay $0.1894 +GST for electricity through the day, a little less for night (off-peak). This website has a calculator for working out your profitability with any configuration of mining device with basic running costs (power consumption): https://goo.gl/xHQf2f
    It tells me - don't try doing this in QLD AUST :s PROFIT PER MONTH: $-59.37
    painfull
    Tip 1 year ago on Step 1
    I think you are over-explaining the components. If I'm reading a recipe for a chocolate layer cake and about to bake one, I probably know what flour is and how it works in a typical baking situation. If I'm reading your Instructable on how to build a Crypto Mining PC and considering making one myself, you should assume I know what the components do and how to build a regular PC ;)
