DIY Dog Light Using Piezoelectricity
4,971
36
17
Want a clean energy dog light that doesn't need batteries? Piezoelectric discs are a cheap alternative! Try this easy project to make a unique dog light using piezoelectricity!
Step 1: Gather Supplies
You will need:
From SparkFun website:
Piezo element - sen- 10293
4 x Diode 1N4148
1 x LED light bar - white (SMD)
1 roll Hook-up-wire - black (22AWG)
1 Breadboard - translucent self-adhesive
Small tupperware to fit breadboard
Exacto knife to strip wires
Wire cutter
Electrical tape
Dog booties made to fit your dog. See Instructables: 10 minute Dog boots
Piece of fleece or other stretchy material
Scissors
Step 2: Measure, Cut and Strip Ends of Wires
1. Cut 4 pieces of hook-up wire. Measure from the angle of the dogs first joint to the centre of the dogs back. Cut and strip approximately 1/4" at both end of the 4 wires.
2. Strip ends of the wires of two piezoelectric discs
3. Wind each end of a stripped piezo disc wire to a black wire, and cover with black electrical tape.
Step 3: Make Diode Rectifier Bridge
Bend each diode into a C shape
Place the 4 diodes in the breadboard in these locations:
1. A1 to A5
2. A6 to A11
3. B1 to B6
4. C5 to C11
Remember the black end of the diode must face the bottom of the breadboard. Make sure that none of the diodes are touching or it will not work.
Step 4: Connect Piezoelectric Discs to Breadboard
Use a poultry skewer, or other sharp object to make 6 small holes in the tupperware, approximately the size of the hook-up wire. Try heating them so they will melt through the tupperware. Try to make them under the overhang from the lid.
Step 5: Connect the Piezoelectric Discs to the Breadboard
Remove the adhesive so the breadboard is attached to the bottom of the tupperware.
Thread the 4 wires through the small holes.
For the first piezo disc insert black into D5, red into D6.
For the second piezo disc insert black into E5, red into E6.
Step 6: Add Hook-up Wire to LED Light
Cut 2 short lengths of hook-up wire, strip all the ends, and attach two to the ends of the LED wires. They only need to be long enough to loop around and in through the tupperware base to attach to the breadboard.
Thread the two free ends in the two centre holes and insert the negative end into E1, and the positive end into E11.
Step 7: Attach LED
Attach LED to lid and close tupperware. Bend wires if needed to close lid.
Step 8: Homemade Dog Harness
Take some stretchy material such as fleece. Cut a rectangle measuring the length of your dogs back as the width. The width should be longer than the tupperware. The length should be long enough to wrap around the belly with enough length to cut ties.
Cut three ties on each end.
Cut narrow slits to be hooked into the tupperware bases hinges.
Step 9: Place on Dog
Close lid.
Attach coat to dog with ties, making sure one tie is in front of the front legs.
Place the piezo discs into the dog booties, and velcro the booties closed.
Watch your LED light up with each step of your dog! See the attached video.
If you like how this works you can substitute a solderable breadboard to make this more permanent.
Enjoy!
Dog Challenge 2016
Runner Up in the
Dog Challenge 2016
Renewable Energy Contest
Runner Up in the
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    17 Discussions
    ohoilett
    2 years ago
    I like it! Really clever. You may not need the rectifiers since LEDs are diodes and block reverse voltages. Unless the reverse voltage spikes end up being in the 10s to 100s of volts (which is possible). I may suggest voltage limiters though with zener diodes. Have you noticed any of your LEDs burning out at all?
    ohoilett
    2 years ago
    You can also make the lights stay on longer using capacitors as a charging bank.
    geekrex
    2 years ago
    the dog is really a good model,its hard to click a photo of my dog standing still :D
    ohoilettgeekrex
    Reply 2 years ago
    I would suggest this Instructable then. I thought it was really clever.
    https://www.instructables.com/id/Dog-Selfie-Attachment/
    arylic
    2 years ago
    Good job, fun for a project but my dog would just rip those gadgets to pieces. #naughtydog.
    miraheng
    2 years ago
    My piezo is not lighting up any bulb ! Sad...
    PiezoManmiraheng
    Reply 2 years ago
    Here are some suggestions:
    1. Check that the diodes are not touching each other
    2. Make sure any open metal is not touching
    3. Try another LED
    summerfawn
    2 years ago
    So, how would I do one based on my own power? I need light in my living room.
    rafununusummerfawn
    Reply 2 years ago
    I frankly doubt that piezos could deliver enough energy to light your living room. There are different kinds of piezos. Some piezo deliver high voltage, thousands of volts, and vry very small intensity (pico amp.) others (such as these in the instr.) deliver voltages higher to destroy a Led. High voltages can easily destroy a Led junction and a 1N4148 one as well.
    PiezoMansummerfawn
    Reply 2 years ago
    I think you would need to have a capacitor to store the energy, and likely have more discs. If you had an area of your floor you walk on frequently you could put piezo discs there to charge the capacitor for when you need light.
    miraheng
    2 years ago
    what if i did not use breadboard, just the normal board , can i soldered based on the picture u gave? tq
    PiezoManmiraheng
    Reply 2 years ago
    You would need a soderable board. Easy to buy on Sparkfun or the Source.
    wannabemadsci
    2 years ago
    Nice project! Who knew our furry friends could generate electricity! (Other than static from petting! :-)
    What are the specs of your piezo discs? And where did you get them? I didn't see them on your Supply List. Thanks!
    PiezoManwannabemadsci
    Reply 2 years ago
    Forgot to include the discs. Cheap on Amazon- one example: https://www.amazon.com/gp/aw/d/B0076ON66S/ref=mp_s_a_1_3?qid=1466538768&sr=8-3&pi=SX200_QL40&keywords=piezoelectric&dpPl=1&dpID=41pbHCJmZTL&ref=plSrch
    amyschlosser
    2 years ago
    Nice work - your dog is quite cooperative!
