DIY ECG EKG Portable Heart Monitor
24,258
186
33
Trying to capture a trace of my very occasional heart palpitation has proven to be nearly impossible. Being keen on electronics, I thought I would make my own ECG (ElectroCardioGram) monitor.
This is intended to be a fun project, not a replacement for a proper ECG. A hospital ECG will likely be a "12 lead" monitor (which actually only has 10 leads due to sharing). This monitor has just two leads, which are placed over bony areas of the chest (sternum and lower-left rib).
The project was fun - circuit design, PCB manufacture, Arduino coding, datalogging, LCD screen, 3D printing, data analysis, etc.
This is not intended to be a full, step-by-step guide. I think you really have to know a little bit about what you are doing in each area listed above. I will try to give enough information to give people the confidence to have a go. There is nothing particularly hard here. This is not a finished, polished piece of kit - more a fully-working prototype.
The finished project, consists of a portable plastic box, with a colour LCD screen which shows the live ECG trace. It has connectors for the electrodes and has a slot for a micro SD Card which stores the data. There are four AA cells inside the box - it is fully self-contained. It has a real-time clock so that the heart data can be labelled with time-of-day and date.
The SD Card holds the voltage data which forms the ECG trace. There is no indication of absolute voltage, but there is an accurate 1-second time-base embedded in the data. The data is stored as a plain text string of numbers, each on a separate line (ie CSV). It imports straight into a spreadsheet.
Safety is paramount, don't put electrodes on your body when they are in electrical contact with ANYTHING connected to the mains (including the USB Arduino Programming lead). Be wary of similar projects which use a serial monitor to display the results - possibly connecting your body to the mains via a USB lead.
Disclaimer: Never connect this project to your body without having the finished project comprehensively checked by a fully-trained medical equipment technician. Ask him/her to issue you with an electrical safety certificate.
Step 1: Overview
The diagram shows the basic functionality.
The photograph shows the main commercially bought modules (Left to right: Real Time Clock; ECG Front End; Colour LCD Screen; Arduino Pro Mini; OpenLog; Battery Holder)
ECG Front End
The whole project is built on an ECG front end available from "100RandomTasks" (cost=22CAD, around £13 GBP)
http://www.100randomtasks.com/ecg-front-end
This brilliant, tiny circuit board, does all the hard work in processing the minuscule heart signals, rejecting the electrical noise, and amplifying the heart trace signal to a voltage which is perfect for feeding into an Arduino. It is possible that an alternative would be the AD8232 heart monitor module which has become available.
Datalogging
The Datalogging aspect was very simply achieved using an "OpenLog" circuit board - available from lots of suppliers (£4 from China £12 from UK) - just search for OpenLog in Google an/or Ebay. OpenLog does everything necessary to put the data onto the SD Card. The SD Card holds the heart's voltage data which forms the ECG trace. There is no indication of absolute voltage, but the Arduino provides an accurate 1-second time-base which is embedded in the data. The data is stored as a plain text string of numbers, each on a separate line (ie CSV). It imports straight into a spreadsheet. OpenLog is an absolutely brilliant tool for getting virtually any data onto a Micro SD card - fantastic.
Cost
Most people are interested in the minimum cost. If you buy everything on ebay and order from China the main components cost (2018 prices)
  • £5.20 TFT display
  • £2.25 Real Time Clock module
  • £1.50 Arduino Pro Mini
  • £3.50 OpenLog
  • £13.00 ECG Front End (from Canada)
There is now an AD8232 heart monitor available for £3.60 from China which might be an alternative to the ECG Front End that I used.
Chinese rip-offs are not recommended, especially if you want guaranteed quality components and make use of library code developed by the original suppliers who deserve support.
Obviously, there are other costs:
  • SD Card
  • Discrete components, connectors and batteries
  • PCB manufacture materials
  • 3D print materials
  • Medical grade electrodes
It is quite a while since the parts were purchased - study the photo of the modules to see what was used here - there is nothing 'special'.
Step 2: Circuit Design
As you can see from the circuit schematic, most of the circuitry is dealt with by the plug-in modules and doesn't appear on my schematic. All of the purchased modules (RTC, ECG, Arduino, OpenLog, TFT) simply plug onto the connectors on the schematic. There are also connectors for the on-off switch, two buttons, batteries, etc.
The schematic contains two errors.
  • Note 1 - the TFT requires 3V signals, but the Arduino runs at 5V. I have put a simple (!) potential divider circuit made up of two resistors to drop the voltage. Somehow I got the wiring wrong - doh! I corrected the mistake by slightly rearranging the layout of the resistors when I soldered them onto the board. The necessary correction is shown in the second diagram, just swap A for A, B for B, etc.
  • Note 2 - The ground pin 10 from the Arduino, should go to ground! Again, corrected by tweaking the PCB (Must have been a late night)
The heart signal voltage output is read by one of the Arduino's analogue input pins. The RTC, TFT and OpenLog all have serial communications with the Arduino. There is provision in the circuit for the Arduino to use an external voltage reference from a zener diode, instead of the internal reference voltage. This was never used and the components were not fitted.
To reduce current consumption, the LEDs in the TFT display can be switched off by one of the pins of the Arduino and an accompanying VFET.
The 'usual' prototyping on a breadboard was carried out to check on the way in which the various modules work. The photos show the RTC, TFT and OpenLog being checked-out.
Step 3: PCB Design and Manufacture
KiCAD was used for the circuit design. The files are not available here because there are so many dependencies (custom parts, custom pinout designs, libraries, etc) that too many individual files would have to be supplied.
The PCB is a single sided design with the components and six wire bridges on the top side and the tiny VFET soldered on the copper side.
The PCB was made with a UV sensitive resist board and a transparency with the traces printed on.
The resulting copper layer was mediocre and required some patching - not my best work, but functional.
A PDF of the final board design is supplied (but remember the circuit errors noted in the previous step). The dimensions of the fine black line surrounding the artwork (ie the board cut-line) are 85.04mm x 68.38mm
Step 4: Assembling the ECG
The assembly of the PCB was pretty straightforward. The design is pretty tight for space, but worked really well.
Step 5: 3D Printed Case
The free version of SketchUp was used for designing the 3D Printed parts, and then exported as STLs.
There were three parts, a lid, the main box and a belt hanger (which has not yet been fitted).
One very pleasing aspect was the inclusion of a 'knock-out' area for fitting the main power switch. This was printed with a thickness of 1mm and was easy to cut out with a knife (but was invisible without a backlight before it was cut out and hence, could have been left unused without spoiling the lid).
Also, a centre-line and 'pilot mark' was included for the fitting of the push button switches.
All these aspects are easy to add to the 3D model, and save lots of hassle when trying to cut and drill the case.
Step 6: Arduino Software/Sketch
The Arduino software grew in a rather iterative manner! It is not particularly pretty, but like every aspect of this project, I wanted a working solution as quickly as possible.
The software still includes debugging code, which is currently turned off with a 'debug' variable flag.
Once the software is running in datalogging mode, it simply reads the analogue voltage presented by the ECG front-end and sends it via serial link to OpenLog. In use, the values range between 50 and 700. I could have increased this range/resolution nearer to 1024 by adding an external voltage reference.
Timing
The most interesting aspect (?) is the timing element. Regular and reliable timing is tricky for a device like this due to different delays which get introduced by different parts of the program. As soon as the TFT is in use, the looping slows dramatically, so when collecting data with OpenLog, the TFT is not updated and it is blank. When datalogging, the finished ECG takes samples at a rate of better than 190 per second (around every 5 thousandths of a second), which is fine.
Timing must be regular, and a 'marker' of some sort was required so that the regularity could be measured and checked. This was achieved by using an interrupt handler which was triggered every second by the internal Timer1.
All the interrupt handler does, is set a 'flag' called InsertZero, it then lets the software carry on. In the main loop, the flag is tested and a zero is sent to the datalogger when the flag is set. As the miniumum value of the real heart data is about 50, the zero value is easily picked out as a '1 second marker'.
Programming interface
Having been 'bitten' before, right from the initial design, I made sure that the programming pins of the Arduino would be accessible once the project was assembled and running.
Step 7: Displaying the Data
The data is displayed on the TFT screen, but to get something on paper requires some analysis.
The data is saved by OpenLog in CSV format and can load straight into Excel (etc) and inserting a 'scattergraph' shows the data with virtually no effort. The Excel image shows this. The data is upside-down compared to a 'normal' ECG. The one-second markers can clearly be seen. This has lots of drawbacks - mainly getting it to look anything like a real ECG is very tricky, and getting more than a few seconds of data displayed is very awkward.
Microsoft Small Basic Analysis
Embarrassingly, Microsoft's Small Basic is my go-to tool for quick-and-dirty data analysis! The output shown in the image is about 150 lines of trivial Basic code. It is so easy to draw the grid, open the data file, read the data, invert the data, plot the data in four rows, add labels, add a 1 second marker, etc. All with instant running, no waiting for compiling - it's an absolute breeze, and so powerful! The Small Basic Program is included here - it will need Small Basic to be installed on your PC and reads the data from a CSV file (called DataToPlot.CSV) which must be in the same folder as the Small Basic program. A few seconds of example data are included here (they show a fast and irregular heartbeat!)..
Step 8: Putting It All Together
Connecting Lead
An old audio lead is used for the connections. Only two of the leads are actually used - the white lead was intended to be an 'earth' connection on a wrist or leg, but it never seemed to function, so it is not used.
Lead positioning
The diagram shows the positioning of the leads. The relevant ones for a two-lead set-up are labelled RA and LL. (The diagram is for a 3-lead set-up but RA and LL are right for the arrangement used in this Instructable - diagram from https://www.heartelearning.org/labyrinths?id=47895... )
Electrodes
The electrodes are easy and cheap to purchase. They have a wet sponge in the middle. The ones pictured are single-use "Ag/AgCl electrodes".
Electrical Noise
The voltages the device measures are tiny. Being a battery-powered device avoids lots of electrical noise. It is sensible to keep away from equipment which radiates lots of electrical noise.
Battery Life
The device takes about 60mA when running. This is reduced when datalogging. No real attempt has been made to reduce consumption - it is only used in short bursts. The Duracell data sheet suggests that the AA cells should last around 40 hours at this discharge rate.
The Real Time Clock has a 2032 cell on board. This is still going strong after being around for a few years without much use (I believe it trickle charges when the board is connected up?).
In Use
The electrodes are stuck onto the chest. The leads clip onto the electrodes and plug into the ECG.
When switched on, a reminder screen is shown. The Real Time clock only needs setting once in a blue moon. If one button is held down - the software switches to a 'clock setting' mode, where each time element (year, month, day, hour, etc) is set by a button push.
If the alternate button is pressed, the TFT displays the heart beat ECG trace. This enables the user to check that the trace looks OK, and generally be happy that it is working. At this point, pressing the two buttons simultaneously triggers the datalogging to begin - and the TFT goes blank. Pressing the two buttons again, will stop the datalogging and restore the TFT trace.
Trying this yourself
I repeat, that many elements of this project could be improved. I really just needed a tool to do a job, and I stopped fiddling as soon as the bit I was working on actually worked.
That said, this seems to be a really good prototype, with a truly useful function. It is ripe for improvement - hence this Instructable.
Note the disclaimer on the first page!
2 People Made This Project!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
33 Discussions
SFQ136
1 year ago
Parts list is lacking - need to define parts used else make it hard to find the exact right things.
straightwayalway5SFQ136
Reply 11 months ago
Ebay descriptions below
- Pro Mini ATMEGA328P 5V/16M Arduino
- Openlog Serial Data Logger Open Source Data Recorder Micro SD Support
- 8GB Micro SD High-speed TF Adapter Memory Card for Cell
- Arduino RTC DS1302 Real Time Clock Module For AVR ARM PIC SMD
- 10X Round Replacement for Massager Tens Units Electrode Pads Therapy
- New 1PC 2.2 Inch SPI TFT LCD Serial Port Module Display ILI9341 5V/3.3V
- ECG Analog Front End with 50Hz Notch Filter
I found I needed old library for the DS1302 (3/6/2015)
and only one Adafruit-GFX Library in my Arduino Library list
else I would get compile errors.
All works good now, thanks.
letitgo
Question 1 year ago
I am trying to break this project down so as to allow my High school students the opportunity to understand the whole project. As a first step I was going to attach the electrodes and ECG Front End Unit to and Oscilloscope and look at the waveform. Would you expect a lot of noise and interference in the signal?
letitgoletitgo
Answer 1 year ago
Thank you for the information
qthurtleletitgo
Answer 1 year ago
Following on from my main answer. The trace in this image shows how little noise there is in the signal from the ECG front end. There is no signal processing to remove noise in the software used to generate the trace. Every data sample (around about 200 per second) is plotted on the trace, with no averaging or anything. (The image full size is 538px wide by 237px high)
qthurtleletitgo
Answer 1 year ago
This should be satisfactory I think. There is very little noise in the signal from the ECG front end, so in principle this should be fine. My slight hesitation is the fact that noise may be generated through the ground lead of the oscilloscope if the oscilloscope is connected to the mains (rather than being a battery-powered electronic oscilloscope isolated from the earth).
I get lots of noise as soon as I connect any sort of mains power supply or USB 5V supply (computer-based or wall-plug) to the unit, so this is why I have concerns about the connection to the oscilloscope - I don't think the noise is anything to do with ripple on the mains-based 5V supplies, it is more likely to be earth potential issues I think. That is why I always use batteries.
It is really important to have good skin contact (I have just used some old electrodes where the skin gel had dried out - terrible noise, no hint of an ECG signal - until I put a few drops of water on the electrode pads and put them back on the skin).
I was very disappointed when I first connected the ECG front end up; all I got was lots of noise. There is no substitute for properly connecting a real human up to the board, using screened leads and electrodes. I don't think anything else will produce a heart trace - holding crocodile clips on the skin with sticky tape (or similar) just will not do!
Finally, I have to warn about connecting a person to the ECG front end and then connecting the ECG front end to a mains-based piece of equipment. You should not do this. Nasty things could happen to the subject in the unlikely event of an equipment failure, lightning strike or other random act.
I hope this helps. Best wishes.
MrZeroTFennekin
1 year ago
Looks awesome! Now all I need is to learn how to read those like a brain/heart specialist, but still cool!
Wrrr 10-G
1 year ago
Well done sir, very elaborate on all these fields..
qthurtleWrrr 10-G
Reply 1 year ago
Many thanks for your interest.
Best wishes
oldschoolfive
1 year ago
This is pretty neat but I wanted to correct something. Monitoring electrodes are not placed on bony areas. In "Lead 2" which is what you are monitoring, the negative lead (labeled sternum) on some equipment is placed to the right of the patient's sternum below the clavicle and the positive lead (labeled apex) on some equipment is placed between the ribs on the patient's lower chest. I don't know your age but unless you are very young this rapid rhythm over (over 150) should not be left to continue for several hours because it can lead to complications. I hope you have shown your ecg to your doctor and explained its duration.
qthurtleoldschoolfive
Reply 1 year ago
Thank you for your contribution. I'm not sure which source I got the positioning of the leads from, but I had difficulty finding an illustration to show the best location, so had suspicions that my positioning was not brilliant.
I see a device called a "Holter Monitor" which I believe is a "2 lead" ECG monitor used for 24 hour monitoring. Presumably this would use the same positioning that I should use. I have attached a couple of images which seem to reflect what you say.
I will adjust the Instructable to include some better information about the positioning. Thanks for your help.
On your comment about the rapidity of the trace I included - unfortunately, I'm no longer very young (according to my pension documents), and I did take myself to hospital on that occasion - Atrial Flutter apparently. Different to the Atrial Fibrillation I am more used to! I don't think I am alone. The UK's wonderful National Health System is sorting me out at no charge!
qthurtlecsokl
Reply 1 year ago
I'm pleased you found it interesting. It was pleasing for me, because it involved so many different types of task. Best wishes
I very highly doubt you can shock yourself with USB voltages. 5V is not even near enough to feel anything.
