DIY Heng Lamp
45,312
639
22
About: At Just Add Sharks we don't only sell laser cutters, we love to make things on them too. Born out of a love of Maker Faires and Hackerspaces, Just Add Sharks is a company run by makers for makers!
The HENG Balance lamp just successfully funded on Kickstarter, the design is pretty cool and unique so we decided to make a copy of it. At it's heart it's just an LED lamp with a simple micro switch to turn it on and off, we had all the parts to hand and a laser cutter to make the more complicated bits. The lower magnet is pulled towards the upper magnet and that turns on the micro switch.
The materials used:
6mm Poplar Plywood
3mm Poplar Plywood
0.73mm Frosted Polypropylene
and most importantly Flexible Maple Veneer Sheet
For the electronics we used:
12V LED strip
12V Wall Block Power Supply
5A Microswitch
Finally some Lead Shot to weight the base of the lamp
All of the drawings for the laser cut parts are included in the svg file which was made with inkscape, if you're having trouble opening it in your CAD package why not try downloading inkscape and resaving it in a different format.
Step 1: Floating Corks
The official Heng design has wooden balls suspended in the middle of the frame, sadly they can't be laser cut so instead of waiting for balls to arrive in the post we compromised with wooden corks that could be produced immediately. While we were busy testing the feasibility of the design we forgot to take any photos on the internal construction. The 3D render shows the way the layers were stacked up to give us space for the magnets and a knot on the end of the string, all safely tucked away inside the cork.
Once the cork was glued together it was skinned with the flexible maple veneer to give it a clean finish and hide the laser cut layers. Two corks were made, one was suspended from the top of the oval, the other was attached to the micro switch in the base as described in the next step.
Step 2: Oval Frame
The main body of the lamp is a large oval shape with a recess for an LED strip. Using a laser cutter the best way to make this shape is to build it up using several layers of material. The two outer sides were cut from 6mm ply, the next step in creates another recess which the polypropylene will sit on, finally the two inner layers were also cut from 6mm ply and are where the LEDs sit.
All the layers were glued together and clamped into place, there is a gap at the bottom of the oval where it will sit over the base. The LED's come with their own adhesive strip but we applied another layer of carpet tape which is much stronger. The LED strip was stuck around the inside of the oval ensuring that they were evenly spaced on both sides. Wires were soldered onto the strip at the bottom end of the ring.
The oval ring was skinned on the outside with the flexible maple veneer, this was a simple strip 30mm wide ensuring that the grain of the veneer was aligned horizontally so it flexed in the right direction. Many clamps were used to hold the veneer in place while the glue dried.
Step 3: Base Sections
The base was made from thirteen stacked disks, this gave a hollow cavity suitable for housing the electronics.
The top two layers of the base had a slot cut into them to hold the rest of the oval in place. The three sections that make up these layers were aligned by leaving them inside the frame they were cut from. There is a hole right in the centre of these layers where the string is threaded through. There should also be a hole for the LED wiring to be threaded through the side of the base, this was drilled into the side of our base but the drawing has been modified to accommodate this.
The design of the lamp looked like it would be relatively top heavy so we decided to weight the base of the lamp to ensure that it doesn't topple over. Two 6mm rings form a cavity which can be filled with lead shot. The rings were capped with 3mm disks, this keeps the weight as low as possible.
The oval rings were glued into the base and the base was skinned with the wood maple veneer.
Step 4: Wiring the LED's
The wiring for the lamp is rather simple, the power supply is connected to the LED's and the positive rail is switched through the normally open contact of the micro switch. The metal lever is bent into a hook shape and the string from the lower cork is passed through the base and tied onto it. The switch was mounted on a small piece of wood and the whole arrangement was glued into the base. Cable ties were used to provide some strain relief on the power cable should anyone accidentally trip over the wire.
Now when the string is pulled, it activates the switch and turns the lights on. There is definitely a better way to do this enclosure rather than gluing it all shut, perhaps using something like this captive nut arrangement.
The polypropylene light diffuser pressed into place, wedging itself between the outer wooden layers and resting on the recess. Polypropylene can be laser cut but because we just needed straight strips we chose to do this with a craft knife instead.
So that is our DIY version of the Heng Balance Lamp, 4 hours from seeing the original to making our own copy, if you make your own we'd love to see photos and perhaps you could share the improvements that you make too.
Remix Contest 2016
Runner Up in the
Remix Contest 2016
Make it Glow Contest 2016
Runner Up in the
2 People Made This Project!
  • Organization Contest
  • Epilog X Contest
    Epilog X Contest
  • Sweet Treats Challenge
22 Discussions
TheCircuit
7 weeks ago
Could Share me details about how you connect the Micro Switch.. It ll be helpful making this project..
When I watch the video, when the lower magnet is taken near upper magnet it make a "Click Sound" Similarly when it is moved away it make a "Click Sound" The doubt is Micro Switch make Click Sound only when it is pressed.. So how does this work..
aaditya.sanjeev
Question 2 months ago
I don't know how to connect the micro switch Please help
NeeravP
10 months ago
can you send the dxf file of tha same i am not able to download svg file at neerav.parasher@gmailcom
JaimeG86
12 months ago
Great lamp. I am making one soon. Thanks for the idea.
chunkysteveo
1 year ago
Oh now that's cool! Initially I thought the magnets were completing the circuit with some HAL detector, but a mechanical switch being pulled, very clever! Maybe to make a silent switch you could "wire up" the upper cork with a HAL detector switch that would activate a relay/circuit when the lower is detected?
Steve
PaulGetson
2 years ago
I think I prefer it with the cylinders. Nice job.
MattGyver92
2 years ago
I'm curious about what magnets you used.
Great instructable.
ErgoE2
2 years ago
I cannot believe but i do this same desing 5 years ago!!! i think the same lamp, i draw the lamp that you show!! i do not know that someone invented too! its amazing! really i draw, and think the mechanism of the magnets.... i do not speak english, hope this understood... anyway, its incredible!
JohnC430ErgoE2
Reply 2 years ago
maybe you showed it to one of your friends or someone saw your drawing. they stole your design. too bad. some of my own designs were stolen and patented by co-workers of mine. but that's life.
ErgoE2JohnC430
Reply 2 years ago
oh, sorry for what happend to you! But, in this case is just coincidence (i live probably in the other part of the world).
JohnC430
2 years ago
very cool design. elegant and pretty.
steve.crane
2 years ago
Nice job. One thought on what could make the finished lamp seem a tiny bit more professional would be a retract mechanism so the lower cord disappears into the base and the cork sits flush at the bottom with no cord visible.
raspberrycoulis
2 years ago
Great guide Martin! Think I'll be having a go at making this one day!
Drake88
2 years ago
One way to make a wooden ball -
Use wooden dowel of the wood you prefer, then cut about 2 to 3(or more, it depends on the size of the ball) inches off. This will become your ball, eventually.
Then angle-cut each end so that you have a start at rounding each end off to form a perfect 'dome'. Then - using any drill, drill press, or basically anything that can hold the dowel and turn it at a high rpm, carefully use rasps, files, and sandpaper/emery cloth to round the 'dome' at each end. Once the dome is finished, cut each off leaving at least 1/4 inch of the straight sides. Using a Forstner bit, core each dome WITHOUT cutting through.
Carefully sand the 'extra' sides(used to hold the piece in a vise for drilling) down to the point where the curvature is just beginning to start.
Glue the halves together to create a ball, making certain to keep the wood grain of both halves going the same way - you may need to do some finish sanding to make it look or feel better once the glue has set.
misko13
2 years ago
What an amazing lamp!! I've always liked making my own version of other people's designs, and this is a great one
deluges
2 years ago
Very neat project, thanks for sharing! I will try to make something similar soon!
