DIY Horn Antenna for the Wi-Fi Band (2.45 GHz)
7,333
42
14
In this tutorial we will construct a horn antenna for the Wi-Fi band at 2.45 GHz from a sheet of brass. All fabrication steps are explained and measurement results are provided in the last step. The results from a 3D electromagnetic simulation, such the Gain or the Radiation Pattern of this antenna are available here : http://kavea.free.fr
Supplies:
Step 1: Tools and Materials
To build this antenna you will need:
  • 1 mm thick sheet of brass or copper
  • SMA connector
  • 1 mm diameter copper wire
  • soldering iron (min 50 W)
  • dremel or something similar to cut the sheet
  • drill
Step 2: Cutting the Sheet of Brass
In this step you will have to cut out 7 parts of the antenna from a sheet of brass. To do this, use a dremel or similar grinding tool. As usually, pay attention on protection of your eyes and the face since grinding discs can brake. Dimensions (in mm) of each part is visible on the photo.
Step 3: Soldering
To solder obtained parts you should have a good soldering iron or better a soldering station with a power of 50 W or more. Use a point soldering at the beginning in order to slightly join all parts together. When it's done you can solder all joints.
Step 4: Adding an Excitation Monopole
In the last step you will need to build a small monopole. To do this solder an SMA connector to a copper wire in order to get a whole length of 3 cm (see photo, but pay attention on the optical effect, the length is exactly 3 cm !).Then drill a hole of 6 mm diameter 31 mm away from the rear part of the horn (see photo), then solder the monopole.
Step 5: Measurements
Here we provide measurement results for the SWR and the S11 parameter. As we can see from the photo, obtained antenna have a bandwidth (@ SWR=2) between 2.34 GHz and 2.62 GHz.
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    14 Discussions
    yshivu
    1 year ago
    Nice explaination ....but how can we set the frequency of the horn antenna.
    tytower
    2 years ago
    Aditionally . If I use finer copper wire to construct the antenna would I not get a sharper bandwidth?
    kaveatytower
    Reply 2 years ago
    Yes, the diameter of the wire will change the BW but also the central frequency. However 1mm +/- 0.5mm will not affect a lot the result.
    martis2580kavea
    Reply 2 years ago
    Which software do you use to simulate horn antenna?
    dthurston1
    2 years ago
    Nicely done... so the next question .... how does one deal w/dual band wi-fi ...? Diplexer?
    DT
    kaveadthurston1
    Reply 2 years ago
    In practice a wifi antenna is made to be matched at both 2.45 GHz and 5 GHz (laptops etc). For home purposes it can be done with horn type antennas since it can provide very broadband response. In these two cases you dont need anything. However if you have two different antennas, one for 2.45 and other for 5 GHz band you will need a switch or a diplexer to isolate two antennas. Otherwise their impedances will be seen in parallel from the receiver.
    dthurston1kavea
    Reply 2 years ago
    Settles that ...
    Any comments on mounting and direction ?
    DT
    kaveadthurston1
    Reply 2 years ago
    Nothing special, as usually do not put it near metallic objects and respect the polarization (usually vertical so put the antenna like on first image, connector up or down)
    tytower
    2 years ago
    So what is the exact length of antenna you used? You say 3 cm but in your picture it looks longer by a few mm . length is critical to results so exactly how long was your test antenna? Additionally what is the basis of your measurement to position the antenna away from the sides? Can you give the source of these measurements please ?
    kaveatytower
    Reply 2 years ago
    The monopole is exactly 3 cm length, it seems to be longer because of the optical effect ;) Can you clarify your question about measurements ? You are talking about the physical dimensions or the S parameters measurements ?
    tytowerkavea
    Reply 2 years ago
    I mean how do you calculate exactly where to position the antenna relative to the front back and sides?
    kaveatytower
    Reply 2 years ago
    Your welcome! The monopole should be placed 31 mm from the back and at the middle from the sides i.e. at 43 mm (86 / 2). This position has been optimized in the 3D FEM solver, but theoretically it's lambda/4 from the back . Any metal sheet will work if you respect the internal dimensions of the horn, an other point is the poor conductivity of some alloys which can lower the gain. And not all alloys are solderable. The best choice still copper, but more expensive than brass.
    tytowertytower
    Reply 2 years ago
    Oh and I meant to thank you for putting this up . I intended to make one but did not know where to start.
    tytowertytower
    Reply 2 years ago
    Also if I use alloy sheet will that work also?
