DIY Knobs Using Polymer Clay
3,283
91
14
About: I am a full-time craft blogger who blogs all things creative to satisfy your creative cravings.
In one of the furniture we thrifted, there were these knobs which do not serve any purpose. They were just for the aesthetics.They were old and rusted and totally 8 knobs per door. I do not want to spend a lot for these knobs and also don't want the glossy spray painted gold look instead I thought the knobs with some design embossed will look will be good on the cabinet. So I decided to use my favourite medium - polymer clay to give them a little update. I will also show you 3 options that you can use to update your old knobs using polymer clay. Let's get started.
Supplies:
Step 1: ‚ÄčMaterial Required :
  • Old knobs
  • one 1 oz block of polymer clay (for 8 knobs)
  • Acrylic roller or anything similar to roll the clay
  • Craft knife
  • Any textured sheet or small cookie cutters or toothpick (optional)
  • Black Acrylic paint (optional)
  • Paper towel(optional)
  • Oven to bake the clay
Step 2:
Clean the old knobs with a damp cloth and allow it to dry. Roll a sheet of polymer clay onto the surface. I'm using a tile as my surface and pasta machine to roll the clay. But you can use an acrylic roller or anything round in shape to roll the clay. Make sure it in even.
Step 3:
Place the knob upside down on the rolled sheet of clay and cut the clay around the outline leaving half an inch allowance using the craft knife. Cover the knob using the clay. Make sure there are no air bubbles.
Step 4: Now There Are Two Options You Can Do to Add Character to These Knobs.
1) Use Small cookie cutters to create shapes like flowers : Here I used a tear shaped cookie cutter and build a flower shape on the top of the knob. I used a toothpick to add details on the petals and flower centre.
2) Use a toothpick to carve designs on the clay covered knob : Here I used a toothpick to carve the design on the knob. I carved the design that is on the furniture door in which we are going to use the knobs.
Step 5:
Bake the knobs as per the instructions on the package of the clay. I used sculpey premo polymer clay so I baked the knobs at 275F for 45 mins. Allow it to cool and your knobs are ready.
Step 6: Embossed Clay Knobs
The materials required are the same but the steps are little different. I showed the above two ways as an option for you.You can select whichever method suits your design and style.
Roll a sheet of clay as shown in step 2 above. Use any textured sheet to create an embossed effect. Here I'm using a flower patterned textured sheet to match the designs on the cabinet I'm using the knobs. The textured sheet I'm using is from Sculpey brand. Place the sheet upside down on the sheet of clay and use the roller to make the impression of the design even.
Step 7:
Remove the sheet and place the knob upside down . Trace around the outline leaving half an inch allowance using the craft knife. Cover the knob the embossed clay circle. Make sure there are no air bubbles.
Step 8:
Step 9:
This step is totally optional. I felt the embossed design did not show well. So I applied a coat of black acrylic paint and removed it immediately using a paper towel to achieve an effect as shown below. Left is after applying the paint and right is without the paint. Which one do you like better?
As you removed the paint, you can use the knobs immediately.
Hope you like this easy upcycle idea using clay. If so please vote for me in "Clay Contest".Thank you :)
For more DIY projects like this, visit www.vikalpah.com
Clay Contest 2016
Second Prize in the
Clay Contest 2016
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    14 Discussions
    Carmel MO
    2 years ago
    I love this instructable. You make something decorative that is also useful. It's easy to do and fun to make. Anyone can do this without needing to buy expensive equipment. You have my vote. :-)
    offseid
    2 years ago
    Very nice! So the plastic doesn't melt in the oven I take it? Thanks for sharing!
    Vikalpahoffseid
    Reply 2 years ago
    Thank you. It is a metal knob :)
    Vikalpahshazni
    Reply 2 years ago
    Thank you very much, Shazni :)
    tinaciousz
    2 years ago
    Thank you so much for this!! I have a package of FIMO clay sitting on my desk at work and now I can actually use it. :)
