DIY Kubb Set
50,518
537
36
About: Analog maker dabbling in digital manufacture
Kubb(aka Viking Chess) is a fun outdoor game in which you throw batons at blocks of wood:
It can be played on any surface - grass, sand, snow, dirt, whatever. Making a set is easy if you have some 4×4 lumber and dowels around, and one of the first projects I followed on this site was fungus amungus's instructions for doing exactly that. I've made a couple of sets for friends since and I wanted to make another, but had no 4×4 lumber or dowels and was disinclined to buy some when I had a lot of other wood lying around. This instructable will show you how to make an entire Kubb set with very little waste from 4.2 m of 2×4 construction lumber (~$4) and some wood glue, assuming you have access to a table saw. If not, buy the dowels and 4×4 you need, or pick up one of the many commercial sets (~$50) available. Or just use some firewood!
Step 1: Kubbs
Glue together two 1540 mm long 2×4s using plenty of wood glue. I used my garage door as a clamp (more examples of improvised clamps here). Rip away the edges to provide one square 70×70×1540 mm length. Cut into ten 150 mm lengths.
Step 2: Batons
Cut a 910 mm length of 2×4 and rip into 38×38 mm lengths. Rip again to an octagonal cross-section. There is an easy way to do this without measuring - just set the distance as shown in the second photo. For a square of side length 1, this generates a perfect octagon of side length √2-1 (0.4142...). Crosscut into six 300 mm lengths.
Step 3: King
Trim two 45° corners off a 1255 mm long 2×4 to give a trapezoidal cross-section. Cut into four 310 mm lengths. Glue together to form a square with 88 mm sides. I used some rubber surgical tubing as a "clamp". If the small hole in the middle bothers you, glue a piece of wood trimmed to the right dimensions inside. Trim the whole thing to exactly 300 mm, then carve additional decorations to make it as kingly as you see fit. I continued with the octagonal vibe and made some bevels with the table saw, and made a cross motif on the top to echo a chess king.
Step 4: Corner Markers
Use the 45° offcuts from ripping the king. Trim the edges and sharpen one end (I used a miter saw). You'll have enough to mark the corners and the center line and have spares. I made mine 350 mm long, cut out the knots, and got seven (1 spare). Use them to mark out a playing area 5 paces wide by 8 paces long, with center markers half way along the longer side. If you're feeling in a making mood, why not make a mallet to pound in the stakes?
Step 5: Finish
Coat with whatever you see fit. I put a clear coat on this set. It's going to take a battering so I can't recommend putting in too much effort into a softwood version.
Step 6: Go Play!
The rules are available online (pdf), or just watch the video. Both came from the U.S. National Kubb Championship webpage. Note that social games of kubb use the "tower rule" to prevent the games becoming interminable: thrown kubbs that are touching get stacked on top of each other.
Outside Contest
Runner Up in the
Outside Contest
Summer Fun Contest
Runner Up in the
Summer Fun Contest
3 People Made This Project!
  • Warm and Fuzzy Contest
  • Cardboard Challenge
    Cardboard Challenge
  • Comfort Food Challenge
36 Discussions
Iron-Hide
8 months ago on Step 6
Excellent 'ible.
I am so impressed with the tip on cutting the perfect octagon.
Why haven't I seen that before? It is so simple and efficient.
I will be using that idea when I make another great Scandinavian yard game of Molkky/Smite/Number Kubb (or whatever you want to call it).
Also, the way that you made the King out of four beveled sections of 2x4 is brilliant.
Two years ago, I made a Kubb set that is scaled up by 50 percent.
I call it "Giant Danger Kubb".
Kubbs are 9 inch (23 cm) tall 4x4's, King is an 18 inch (46 cm) tall 6x6. Batons are 18 inches
long and 2-1/8 inches (5.5 cm) diameter. I use the standard sized Kubb court/pitch setup.
It bumps up the "danger" quotient when you toss those big pieces of lumber around.
I learned a lot. Thanks so much for sharing.
makendoIron-Hide
Reply 8 months ago
Thanks. Yeah, dowels are expensive, it's a good solution and they throw really nicely. Danger Kubb sounds like a blast
fungus amungus
8 months ago
Whoa, never saw this until now. Great stuff! Love how you skip the 4x4s. Lugging that stuff around was annoying.
makendofungus amungus
Reply 8 months ago
thanks for alerting me to the existence of this game in the first place!
I love how kubb has become known as "viking chess" when there is no evidence of it's existence before the early 1990s. Contrary to popular belief, we're not still vikings in Sweden!
I think the nickname has arisen because of where it was invented and the fact it contains strategic elements with wooden playing pieces (and like in chess, the king plays a central role in the coup de grace). I don't think it should be taken literally.
richardsan
8 months ago
I’ve played Kubb a number of times. Quite fun!
It’s not “aka Viking chess”. Nothing to do with chess at all. There are sites with more historic info, if one cares/dares to search.
Nice ibble...ty
alt_mode
8 months ago
Love This Insructable! Kubb is a very fun game!
flyingblindonarocketcycle
Tip 8 months ago
I use those little lawn marking flags to mark the field. I had a bunch left over from marking sprinkler lines in my lawn. They work great and push into the ground with ease.
nilsbinnemans
3 years ago
Very nice. What would you recommend as weight for a single kubb block?
makendonilsbinnemans
Reply 3 years ago
Thanks. Speaking as someone who went camping near an old brickworks and played with bricks and sticks - it really doesn't matter. Even very heavy kubbs fall easily. Have also made a set out of (very light) cedar: also fine.
Hippykidz
3 years ago on Introduction
Thanks Man! Great ibble. I just got turned on to Kubb a few weeks ago and happen to have a supply of 4x4 cut offs that should be about right. I'm thinking a length of closet dowel and a few hours and I'll be the proud owner of my very own Kubb set! Thanks Again !
makendoHippykidz
Reply 3 years ago on Introduction
Perfect - that was pretty much exactly what I did when I first encountered the game. Enjoy!
Looks like a fun game and thanks for showing the trick for making an octagon without measuring.
It does in fact make a perfect octagon of sides equal to 0.4142135... multiplied by the length of the side of the square. So for a square of √2 the sides will be 0.585786...
makendopaul.mackwood
You're absolutely right; each cut
off triangle is a right-angled isosceles triangle with 2 sides (sqrt2 - 1) (0.41421356)
and the other side = sqrt(2(sqrt2 - 1)^2) = 0.586. The remaining side is
sqrt2 – 2(sqrt2-1). That is much more satisfying. I must have made a transcription error in the initial calculation. Thanks!
eladejarl
As a Norwegian I can assure you that kubb is NOT viking chess. That would be Hnefatafl (It means the "King's table"). There are some speculation that kubb might have been around in the viking age, but there is no evidence.
