DIY Leather Phone Case
1,920
16
About: I am an industrial designer and a maker. I like to make prototypes, unique pieces, equipment and other stuff. In this channel I will show you what I do, and in particular the making of design pieces, with v...
I decided to make this mobile phone case just because I like leather accessories very much. They have the natural ability to convey a sense of luxury and fine craftsmanship. In fact, I don't have a great experience in leather working, but in general, I can handle it and so I decided to give it a try. As a designer, working outside your comfort zone is very important.
Step 1: The Sketch
As I always do, I started with a sketch, to fix the ideas and define the details of the project. I made the sketch using watercolors and ink on Strathmore watercolor paper . This kind of media takes a little more time than needed to make this sketch, but practicing drawing skills is always a good idea.
During the sketching, I already had in mind what type of leather to use.
Step 2: Paper Templates
I then made paper templates to be used as leather cutting patterns. I used my cell phone for measurements. I basically made the case out of paper first to check the correct measures.
Step 3: Cutting Out the Leather Pieces
I then chose the skin to use and cut the various pieces using a craft knife.
I used a thin black leather and a suede with a crocodile textured effect as an inlay.
I then marked the front side and the back pocket with my Hanko logo to customize the phone case.
Step 4: First Bonding
Once all the pieces have been made, I glued the two sides of the front and the two of the back to make them easier to sew.
Step 5: First Sewing
Once the glue has been dried I reinforced the bonding with a machine seam. A special foot made to seam on the edges helped me in this operation.
Step 6: Wooden Template
To shape the leather so that it perfectly joints to the shape of the cell phone, I first built a wooden template, in order to press the leather against the phone to shape it. I first scored the contour of the phone on a plywood panel that I then cut it with my band saw.
Step 7: Shaping the Leather
I then put the leather to be shaped into warm water for about half an hour, so as to make it more malleable.
After covering the cell phone with a transparent film, so as not to wet it, I then inserted the leather between the wooden shapes. I then clamped it all around with some clamps.
Step 8: Final Bonding
I waited for one night for the leather to dry and the next day it had taken the desired shape. Also in this case I glued the front with the back before sewing them together, I put them back in the wooden vice to make the glue dry.
Step 9: Final Sewing
Once the glue was dry, the two parts were sewn together. Even in this case, I used the foot that was the most suited to the purpose.
Step 10: Cutting Off the Excess Leather
As the last step, I cut the excess leather near the seam. I then finished a bit the cut to make it a little nicer.
Step 11: Final Shots
And voilat, the game is done! The cover is over and ready to be used in the mundane evenings.
Thanks for checking this Instructable. There also is a video of the realization of this case on my YouTube Channel where you can better see the making process.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    2 Discussions
    Alex 2Q
    1 year ago
    Great design and work as usual Guido! I loved the drawing part especially of the video and think about using that more in my videos.
