DIY Lemon Dishwasher Tablets
16,194
277
23
Homemade dishwasher tablets are easy to make and often cheaper than store bought brands that are filled with chemicals galore. Making them at home also gives you the opportunity to create and play with your favorite scents for cleaning your dishes.
Step 1: Ingredients
You'll want to gather the following:
  • 1 Cup Arm & Hammer Washing Soda
  • 1/2 Cup Epsom Salts
  • 1 Cup Borax
  • Juice from 1 Lemon
  • Essential Oils (Optional for Scents)
I chose not to use essential oils for my tablets, but you could easily add them. Eucalyptus or lavender could both be nice additions to your lemon dishwasher tablets!
Step 2: Combine Ingredients
Combine your borax, washing soda, epsom salt, and lemon juice into a bowl. When you add your lemon juice, your solids will begin to fizz. That is okay! Keep going. Using a rubber spatula or wooden spoon gently fold and mix the ingredients together until they begin to clump and are adequately mixed.
If you are using essential oils, add a 4-6 drops and mix in thoroughly.
Step 3: Press and Dry
Spoon your mixture into empty, clean ice cube trays. Using the back of your spoon or your fingers press your tablet mixture into the ice cube slots firmly. The firmer your press down on your tablets, the more likely they are to stay together once you pop them out of the ice cube tray.
Let your tablets sit for 24 hours to dry completely and harden.
Step 4: Pop and Store
Once you have let your tablets dry for 24 hours, release them from the ice cube tray. Store your tablets in a dry air sealed container like a mason jar or tupperware.
Step 5: Done
You're done! Use your dishwasher tablets like you would regular store bought tablets in your dishwasher. Enjoy the fact that you can clean your dishes without all of the harsh chemicals!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Jewelry Challenge
    Jewelry Challenge
23 Discussions
Narsil
3 years ago
Please tell me you know that Borax, Epsom Salts, and Washing Soda are "common" names for laboratory chemicals.
KWDragonNarsil
Reply 3 years ago
And I assume that you understand that not all chemicals are created equal. Not every chemical is harmful to humans and the environment. Dihydrogen monoxide, for example, is a chemical, but we've done pretty well with that so far. I like the idea that this Instrucable gives me a gentler way to use my dishwasher. I plan on trying these this week. I will let you know how they work. :-)
XiverNarsil
Reply 3 years ago
Borax, Epsom Salts, and Washing Soda all occur naturally and are used around the world in almost every culture.
HollyHarken
3 years ago
Nice instructabe, can you use it without the citric acid from the lemon? Unfortunately the acid in the lemon will etch your glassware and silverware. Never use any citrus based dishwasher detergent for that reason. It is very hard to find a non acidic dishwasher detergent, but if you are determined you can find it.
mikesmithflHollyHarken
Reply 3 years ago
I'm fairly certain the small amount of citric acid in this will have reacted with the sodium bicarbonate to become a small amount of sodium citrate. oops, a home "lab" chemical.
the small amount of juice from a single lemon, or maybe 2 dozen lemons have very little citric acid and would have a hard time etching modern glassware. modern creams and acids used for etching are MUCH stronger.
that said, fancy stemware and silver likely aren't safe to be put in a dishwasher.
beautypros
3 years ago
This sounds good., can't download the recipe because I am not a member :-(
bethmeerkatAZbeautypros
Reply 3 years ago
You don't have to be a member to access the information. If you know how to cut and paste into a document, then print it out, you can save it! I believe being a member gives you the advantage of having all the info easily available and print, not to mention other membership advantages! I encourage you to read the membership info closely. Of course, becoming a member is a good thing! You can also easily resort to the old pencil and paper method with the ingredients list not being too long ;-)
chupike
3 years ago
I read that Borax is actually Formaldehyde and is a very toxic chemical.
TeresaM7chupike
Reply 3 years ago
A quick trip to Wikipedia will relieve you of that misinformation.
Kreat0r
3 years ago
very creative!
Renarde Rousse
3 years ago
Definitely going to have to try these! Thanks
mommyhen42
3 years ago
I love these and have been making them for years
The problem is that if you have hard water like we do, you get spots on the glasses, even with jet dry.
So I dont use them here anymore, however my kids dont have hard water and totally love them and have used them ever since they have been on their own.
Awesome way to save money
robthefireguy
3 years ago
Thanks, I am going to try this with essential oil.
denewf
3 years ago
Anyone do a cost comparison??
Dlori
3 years ago
Going to try this as I use some of the indigence for DIY laundry soap. Thank you
yrralguthrie
3 years ago
Borax, of the mule team variety, is sodium tetraborate or sodium borate (to get all official for a second) and NOT boric acid (hydrogen borate), which is a common misconception on the interwebs apparently.
Not_Tasha
3 years ago
Looks interesting! Can you post pictures of before/after in the dishwasher?
