DIY LiPo Charge/Protect/5V Boost Circuit
32,947
196
19
About: Awesome Electronics Tutorials, Projects and How To´s
In this video I will show you how I combined a couple of ICs in order to create a charge/protect/5V boost circuit for a single cell LiPo battery. Along the way I will show you how I designed the PCB, how I ordered it and what kind of problems occured while soldering the components and testing the circuit. Let's get started!
Supplies:
Step 1: Watch the Video!
The video gives you all the information you need to create your own Charge/Protect/Boost circuit. In the next steps though I will present you some additional, helpful information.
Step 2: Order the Components!
Step 3: Create the Circuit/Order the PCB
Here you can find the schematic of the circuit and the Gerber files. You can use them to order the PCBs with JLCPCB: https://jlcpcb.com/order/pcb
Or you can simply open my EasyEDA project with my board design and click the fabrication output button: https://easyeda.com/GreatScott/LiPoChargeProtectBo...
Once you receive the PCBs, all you have to do is solder the components to it with the help of the schematic.
Step 4: Success!
You did it! You just created your own LiPo Charge/Protect/5V Boost circuit
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
4 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
19 Discussions
FixDaily
Tip 2 months ago
R2 and R3 are inverted, R1 should be 1K and R3=7.5K, this schematic is wrong on the feedback system. As far as is see, there is no other problem.
Thanks
Rubines
1 year ago
I modded the device to 12V, but unfortunately the step up driver gets very hot when it is loaded with a 400mAh load. I added a heat sink so the circuit does not enter the overheat shut down protection but it still gets very hot. I added a thermal image after using it for 10 minutes. You see around the step up switcher ic, the temp is at 70 degree Celsius.
FixDailyRubines
Reply 2 months ago
That's because the feedback resistors are inverted on his schematic, happened the same to me, so i decided to look up on the datasheet and make the Vout calculation and found out the problem. How it is, there is not enough feedback so the IC keeps pulsing until it shorts down itself.
You have to change R2= 1K and R3=7.5K and you also need to replace the IC, you probably have a short to GND on IN pin.
KCM5
11 months ago on Introduction
I know this was posted months ago, so I apologize for necromancing this thread.
In the parts list, two 22uF ceramic capacitors in package size 1812 were used. But of all the components, these LCSC #C28504 are the most expensive - 0.81 USD at the time of this writing. If you wanted to build 10 of these boards, you're nearly $15 USD just for these capacitors.
I suspect you selected these because you already had some on-hand. But this leads me to a question...
Is there any reason a capacitor of the same or similar values (eg. LCSC #C129303) could replace this? The latter cost currently 0.07 USD. I think the answer is no, but I want your opinion.
Now this leads to another question about making the board a little bit "modular"? What I mean to ask is, in your experience, is it reasonable to create a board that will accept the same part in a different package sizes on the same, largest pads? I've attached a picture to help clarify.
The best reasons I can think of are
1: It could be confusing, complicates or messes up the BOM
2: It's (probably) not a best practice, or for some reason frowned upon.
3. EasyEDA might not let you (still inexperienced, so I don't know the answer to this.)
What are your thoughts on this subject?
Deadly shadowKCM5
Reply 4 months ago
You can change capacitors but for best result you must add to output one tantalum capacitor 100uF10V and 2200uf10V electrolytic capacitor because in my practice i saw this module do not working with some display modules because on the output we have a bad noice.
lucylily
1 year ago
Don't waste your time on this. It's nothing more than an a PCB vendor promotion.This is yet another junk circuit from JLCPCB.I got PCB from jlcpcb, but cannot
recommend them (cheap, but bad quality)
e024576
1 year ago
Regarding ordering components from LCSC - I see on their website a "BOM TOOL" which can import a spreadsheet listing all the components. So, why not include a parts spreadsheet?
warhawk8080
1 year ago
Awesome...always love your designs and things!
Shared this at OSHPark for another way to order the boards...
https://oshpark.com/shared_projects/u9rscwQi
Satrah101
1 year ago
why did you choose 603 parts.
ClemRz
1 year ago
Awesome! What should I change if I want the exact same characteristics but with an output of 3.3V?
emmseysquareClemRz
Reply 1 year ago
Try creating a voltage divider on the output of the circuit.
AllexandruPClemRz
Reply 1 year ago
but it s a boost converter ic , i don.t think you can get lower than the 4v or input voltage of i.c
AllexandruPClemRz
Reply 1 year ago
voltage divider maded by 2 resistort and midle to fb of boost ic .
MindFly
1 year ago
Would more than one amp (about two) be possible with some small changes?
comp73094MindFly
Reply 1 year ago
I've tested out boards from Amazon, and milled out my own version of Great Scott's, you can get 1amp easy with the MT3608. However, due to the current limiting factor of my lab bench power supply I could get it to only get to about 1.3amps or so. The power supply reaches the 3 amp current limit. Keep in mind if you are planning to pull 1amp or more from the MT3608, while possible, the chips get very warm, and the voltage drops to about 4.8vdc.
I would make sure the coil and schottky diode can handle the extra current. The diode that GS uses should be more than adequate. BTW, according to the MT3606 data sheet, the schottky diode recommendation formula is SQRT(Iout×Ipeak).
vesowarworld
1 year ago
Hello, It is a good project. I have couple of LiPo batteries and I use them on same way but not on one board :(.
I use TP4056 with protection board DW01A and I solve the problem for low voltage protection for LiPo with use of voltage divider on 100 ohms resistor on pin that read VCC.
I see this from one Russian blogger, he use diodes for voltage drop, but I thing why to not add one resistor to ground :).
rpotts2
1 year ago
Stumbled over here looking for PCB tutorials. I always enjoy seeing a new 'ible from you! can wait to see the video!
