This moccasin shoes are easy to make, It took me about 2 hours to make them.
Step 1: WHAT YOU NEED
You need:
-scraps leather;
-leather strings (I did them myself from a scrap piece of leather);
-paper or cardboard;
-pencil;
-scissors;
-leather glue;
-leather holes punch (a smaller and a bigger size);
-big needle.
Step 2: THE SHAPES
These are the shapes that you need to cut in the leather.
If you print the ones in the first photo you will have a pair of moccasins size 36,5 (6 to 6.5 US woman size).
Match the 20 cm bar with real 20 cm. For every european size up you add about o.5 cm on the length.
Cut the shapes in a piece of cardboard or hard paper.
Step 3: CUT THE LEATHER
Cut the leather different pieces.
Remember to cut them half in one direction and half overturned (left and right shoes).
Step 4: POKE HOLES
Poke the holes with the smaller leather punch where the pattern require them.
Step 5: START SEWING
Sew the smaller leather shape to the bigger one with the leather string, like in the photo.
Start in the first hole of the bottom part, leaving a knot on the outside, then start sewing only from the second hole.
(the bigger part have 2 extra holes). End on the other side in the same way.
Step 6: THE BACK
Cut a small rectangle of leather, wide 2 cm and long like A.
Spread leather glue all over the back of it, join A with A and glue the small leather square in the inside part of the shoes.
Step 7: SEW THE BACK
Now pull up the flap, make some holes in the back part of the shoes (matching the one of the flap).
Sew like in the photo with a piece of leather string, leaving two knot in the bottom outside part of the shoes.
Step 8: THE SIDES
Spread the glue allover the long strip of leather, glue it to the shoes like in the photo, half inside and half outside of the edges, with the holes in the outside part.
Step 9: ADD THE LACE
Poke more holes with the bigger size leather punch (they need to be bigger because the lace need to be able to move inside of them, to tighten the shoes) in the inside edge of the shoes, corresponding to the one that were already in the strip. Also make two extra holes just when the strip finish.
Add the lace, starting from the hole in the middle of the front part, going through the strip, and then going outside on the other hole in the front part.
Than you can tie a bow knot.
Step 10: DO THE OTHER ONE
Do the other one and you are done!
★ I like how they come out, but I need to say that the next pair I will do, I will do it a tiny bit different.
I will make the long leather strip longer, with two extra holes, so that the strip will arrive closer to the front part holes.
★ The soles part of the shoes is quite thin, so they are good like house or beach shoes, but if you like to wear them outside you can add an insole, and glue a piece of thicker leather to the bottom like a sole (with proper leather glue).
Runner Up in the
Leatherworking Contest
24 Discussions
2 years ago
What type/weight of leather did you use? I recently made a pair from a kit, but i know that I could do it from "scratch" im just not sure what weight would be good! These are awesome! I cant wait to make a pair :)
2 years ago
If you want good, modern soles that still have that barefoot feel, climbing shoe resole kits are $40 online (fiveten sells them). Since they're for climbing shoes, they still feel like you're barefoot, but give you the traction you're lacking by wearing smooth leather
4 years ago
Where is a good place to get leather?
Reply 3 years ago
Tandy Leather try tandyLeather.com
Reply 3 years ago on Introduction
I would try the thrift store, if you live near one
Reply 4 years ago on Introduction
From deer, cows, rabbits to name a couple.
You can get scraps pieces of leather from Ebay or Etsy too. Or Tandy leather have nice new leather.
Probably any fabric store will have leather. Jo-an Fabrics or I'm sure you can get it online cheaper.
This is amazing. You have resurrected mocassins. Props. Best moccasin tutorial ever.
Nice! its about time someone posted an instructable on how to make moccasins. For along time i have wanted to make a pair of moccasin hunting boots. Would you know how to make those?
What you are looking for is mukluks. They are native american boots and can go mid shin or higher up the leg.
Mmm I don't know, but if they are what I think they are, I have a pair of them, and I can check how they are made and then if they are easy to make I write back...
Actually I see on google image that is not what I have, but there is something here on instructables similar: https://www.instructables.com/id/Mukluks-for-Christmas/
4 years ago
Great work Marcellahella.My only suggestion is that instead of having a straight cut at the back of the moccasins,u could cut it in a curved shape.
Congratulations !! on you winning :). Great show.. :)
Thank you! I'm pretty happy about!
Amazing...who knew you could make moccasins??? AWesome! :)
Sure you can! Thanks!
I wouldn't go trudging through the mall with them, but they are quite stylish for the outdoors! Very nice, thanks for the step by step guide. I've always wanted a pair! ;)
You are welcome!
