DIY Modern Outdoor Sofa
32,076
592
12
About: I run FixThisBuildThat.com where we focus on Woodworking and DIY Projects, Plans and Tools. Come check us out and let us inspire you to build something awesome!
If you liked the video please subscribe to my YouTube channel!
This Instructable is how to make a DIY Modern Outdoor Sofa. It is make from cedar 2x4 and 1x4's and can be made with just a miter saw, circular saw, and cordless drill...though it is easier if you have a tablesaw.
You can also see the full blog post at: http://fixthisbuildthat.com/diy-modern-outdoor-sofa-plans/
Tools Used (affiliate):
Materials Used:
  • (7) 8′ 2×4 cedar boards
  • (1) 8′ 1×4 cedar boards
  • (3) 12′ 1×4 cedar boards
  • 1-1/2″ SPAX HCR-X Screws
  • 2-1/2″ SPAX HCR-X Screws
  • 3-1/4″ SPAX HCR-X Screws
  • Outdoor spar urethane
  • 1″ rubber feet
Step 1: Build the Sides
Start by laying out the board to match the colors and pick my best pieces.
Next cut parts for the side assemblies from cedar 2×4. Each side needs a 27-1/2″ top, a pair of 22-1/2″ uprights and a 24-1/2″ base.
Build the sides by drilling ⅜” holes halfway through the tops parts on each end. Use 2-½” screws in the holes to join the boards.
Use a 3/8″ plug cutter to cut plugs to fill the holes in the armrest. Install the plugs with glue and sand flush.
Step 2: Build the Base and Attach to Sides
Cut a 2×4 base stretcher to 69″. Flip it and the armrest bases upside down and connect them with 2-1/2″ screws.
Flip it back over and attach the armrests to the base with 2-1/2″ screws through 3/8" holes like earlier. Fill these holes with cedar plugs as well.
Step 3: Build the Seat Base
The base frame is made from 2×4’s and needs a front and back each 69″, two sides at 24-1/2″ and two inner supports at 24-1/2″. Attach the front, back and sides together to form the outer frame
The two inner supports need notches cut in them to hold the 1×4 seat slats. Lay out four notches 3-1/2″ wide by 3/4″ deep on the inner supports. Use a dado blade on the tablesaw or circular saw to cut out the notches on the boards.
Cut two 24-1/2″ cleats to support the outer ends of the 1×4 slats. Rip a 2×4 in half for these or use 2×2 material. For the final seat parts cut four 1×4 seat slats to 66″.
For the inner supports, space them evenly with the center of the boards 23″ from the outer edge. Do the assembly upside down so the top surface will be flush when you finish.
Flip the seat over and attach the cleats to the sides. The slats should be flush with the outer frame so use a scrap 1×4 to set their position. When the scrap is flush, attach the cleats with 2-½” screws.
Now lay the 1×4 seat slats into the notches and attach them with 1-½” screws.
Step 4: Build the Backrest
From 2×4’s, cut four uprights to 21″ with 15 degree angles on the bottom end. The uprights will be connected by 1×4 slats similar to the seat base. Lay out three 3-1/2″ wide by 3/4″ deep notches and cut them with a dado blade or circular saw like before.
Add a taper to the back of the uprights by striking a line 1″ over from the top notch and 6″ down the upright. Cut to the line on the tablesaw or with a circular saw.
Cut three 1×4’s to 69″ long for the back slats. Lay out the uprights with the same spacing as the seat supports and attach the slats with 1-½” screws.
Step 5: Sand and Finish the Parts
Sand everything and apply finish. It’s much easier to work with the large flat assemblies than to try to sand into corners once the sofa is put together. Sand to 150 grit and apply 3 coats of exterior spar urethane.
Step 6: Attach the Seat to the Sides
Put rubber feet on the bottom of the sides before assembly.
Clamp some temporary blocks to the sides to position the seat which should be 12-1/2″ to the top of the seat. Put the seat in place and secure it to the sides with two 3-¼” screws per corner.
Step 7: Attach the Backrest
Put the back in place and join it to the seat supports with a 3-¼” screw through each upright into the seat supports.
On the back side use two more screws to secure the outer pieces together and put another fastener into the back of the inner supports.
Step 8: Add Cushions and Enjoy!
The base cushions are 24″ deep and 23″ wide and the back cushions are 18″ tall and 23″ wide. You can also purchase cushions online or at a local store to fit your needs.
  • Woodworking Contest
    Woodworking Contest
  • Arduino Contest 2019
12 Discussions
Technoaussie
2 years ago
Nice looking furniture.
Please don't think the following comment/advise is meant to be anything other than helpful. Flat (parallel to the ground) seating with tilted back rests almost guarantees this will be an uncomfortable seat for maybe as many as 80% of the adult size population for any length of time.
If you take a look at similar commercially made furniture you'll see that most of it has a backward tilt on the seat as well as the back rest. Only people with short legs (children for example) will be comfortable for long on a seat that has a tilted back and seat that is parallel with the ground.
I admire your color choice and general design of the furniture. Having made all the furniture in my home — Some of it with flat seating that I had to rebuild when I discovered what I'm telling you here, I think anyone following your excellent instructions might consider the seating tilt and really impress their friends.
fixthisbuildthatTechnoaussie
Reply 2 years ago
I agree, and I did consider tilting the seat, but the fact that this is foam that has give to it somewhat negates that. But I'll tell you if 80% of the people that come over hate it or not :)
jon_chalk
2 years ago
Beautiful. Well documented. Good instructable.
ulotina
2 years ago
Nice..
PhillipS13
2 years ago
absolutely awesome! could you post a link or maybe another instructable on how you did the cushions?
bbqandbeer
2 years ago
EXCELLENT!!! I've been looking for a project like this :) I will save for when my shop is ready and I can get building one of my own!
