DIY INFRARED CAMERA
6,484
117
5
This is a cool superpower. The power of seeing in the dark. Even when there is no light at all. In this tutorial, I'll show you how to achieve this ability (with the help of a little bit of technology).
Step 1: Watch the Video
After watching this video, you'll have all the knowledge necessary for this project. But you can still read the following steps to be sure.
Step 2: What You Will Need
You'll need these tools:
_a glue gun
_a soldering iron
_a 12v power supply (you can use an ATX homemade one)
You'll also need these materials:
_a infrared-led-lamp-thing-security-camera-attachement, you can buy one here: https://goo.gl/us2PY7
_a smartphone
_some wires
_some solder
Step 3: Gluing
Glue the lamp to the back of our smartphone, making sure, that the hole in the middle is in facing the camera.
Step 4: Adding the Power
Soler the red (+) wire to the + terminal of the red socket and to the + terminal of the white socket. Then, solder the ground wire to the other terminal of the white socket. Then switch on the power supply!
Step 5: SUCCESS!!!
Congratulations, now you have some superpowers got with the Bataman methods :P But please use this gadget responsibly. I'm not responsable of any of the silly things that could happen!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    5 Discussions
    SerhiiB1
    Tip 1 year ago
    Smartphone's camera doesn't sense Infrared very well because it has IR filter inside, you need a camera without IR filter. Here you can see the difference between a camera with IR filter, and without it:
    Left-field Designs
    2 years ago
    I don't think you are getting the full effect of the IR there is an IR filter plate on the ccd of digital cameras if you remove this you will get much more ir in and so clearer pictures.
    www.instructables.com/id/infrared-digital-camera---the-real-way/%3famp_page=true
    gtoalLeft-field Designs
    Reply 2 years ago
    Agreed, most of the IR is filtered out - you'll be able to see an IR LED directly (eg a remote control) and maybe some things that are within a couple of feet of your IR light source but the sort of thing you see with a night vision security camera where people are illuminated maybe 30 ft away is unlikely with most cell phone cameras, even though that illuminator you're using reaches distances like that. Unfortunately the filters can be extremely hard to remove without damaging your equipment - you might consider experimenting with a Pi Zero and a Pi NoIR camera...
    bwh13
    2 years ago
    What are those pictures you've taken?
    I have no idea what I'm looking at?
