DIY PVC Pipe Bicycle Trailer (Single Wheel)
5,735
112
7
About: US Army Retired (medical) - Always Looking for handy work to do. Wood & PVC projects. Getting ready to make a 95% PVC pipe uni-bycycle-trailer to haul my best friend, (ALO - My Service Dog), around in.....
Sorry guys! In hindsight, I wish I had taken the measurements on this trailer as I was building. This is my first attempt at making a bicycle trailer.
I saw a lot of different "single wheel" trailers and wanted to build something strictly out of PVC pipe and plastic.
I had the plans in my mind so this whole project was touch and go as far as measurements.
The overall measurements are about 5 feet 7 inches long and 14 inches high at the front. From the base of the wheel to the top of the fender frame it's about 25 inches tall.
Step 1: PVC Bending Jig...
I used a Heat Gun to heat the PVC pipe for the curves I needed. I made a jig to do this. I used screws and plywood. Wear gloves when holding it it place to cool!
This part takes a little patience as you don't want to burn (yellow) the pipe.
Step 2:
The piece that the wheel attaches to, I heated the pipe and pressed a 1x2 piece of wood to flatten the pipe.
I bought 2pcs Stainless steel bushings to insert into the PVC wheel mount to reduce friction wear.
I used 1/2 PVC pipe for the upper framing. The floor base frame is 1" PVC pipe...
I have not glued it yet but after some minor tweaking, I'll finish it and update this instructable.
The Skin...
As soon as I get some, I'll be riveting Coroplast (corrugated plastic 4' X 8' X 4mm) as the skin for the floor, sides and wheel fender. Home Depot sells sheets for about $13.
Fittings I used are as follows...
- 2pcs - 1" 90° Elbows
- 4pcs - 1" 45° Elbows
- 1pcs - 1" 4-way fitting
- 5pcs - 1" T's
- 10pcs - 1" to 1/2" T's
- 2pcs - 1/2" 90° Elbows
- 8pcs - 1/2" 45° Elbows
- 2pcs - 1/2" 4-way fitting
- 8pcs - 1/2" T's
Hope this gives ya'll some good ideas on building your own trailer! Again, sorry this incomplete.
If you have any questions, I'll try and get back to you soon...
    • Epilog X Contest
      Epilog X Contest
    • Sweet Treats Challenge
    • Warm and Fuzzy Contest
    7 Discussions
    RicoR13
    9 months ago
    how strong is this how much weight can you put on it? witout breacking
    dimaspin
    1 year ago
    How much weight can it carry?
    foothillbilly
    2 years ago
    I would like a picture of the bushings with the wheel fitted if that's possible. Also, please show and explain your hitch.
    Ingenerare
    2 years ago
    Looks Great! Is t strong or does it rorate when it is loaded?
    mahonri
    2 years ago
    This looks really good! Could you provide details about the hitch you are using to connect to your bike?
    seamster
    2 years ago
    This looks cool. I'm curious to see the full details when it is completed.. I hope you'll update! :)
    I'm wondering about the bottom. Will you be adding a board of some kind to create a "floor" to load gear onto?
    This looks really impressive, especially because you made it with PVC.
