DIY Portable Router Table and Drill Press Table 2 in 1
39,789
500
38
About: I am an industrial designer and a maker. I like to make prototypes, unique pieces, equipment and other stuff. In this channel I will show you what I do, and in particular the making of design pieces, with v...
I designed this little table with the idea of doing a dual function. I wanted to have a fully functional and flexible table to fit my drill press, but also the possibility to transform it into a router table, by simply fixing my palm router under it, when I needed. This is the solution I found. It has two t-track, two fences, three feather boards, a Lexar protection and a dust collector. It is made out of 18mm and 27mm thick birch plywood with some 3D printed parts.
The table can be easily transformed from a router table to a drill press table by unscrewing two knobs and detaching the two main parts composing it.
If you are interested in building a table like this, or you want to change the size to suit your needs, you can download, through the link below, the Fusion 360 file of the assembly, and STL files of all parts to be printed. DIY
DOWNLOAD 3D MODELS ▶ Router Table 3DFiles
Step 1: Design and 3D Modeling
The first step was that of measuring my drill press and my router to define the dimensions of the table. WIth that dimentions, I defined the detail of the project and 3D modeled every single piece, to be sure that everything worked and also because I needed the 3D models of some parts to 3D print them.
Step 2: 3D Printing of Some Parts
While I was working on the wooden parts of the table, I have 3D printed all the plastic parts of the model, such as the feather boards, the protection holder, the dust collector, the table caps and the knobs.
Step 3: Cutting Out All the Parts
The first woodworking step has been to cut out all the parts from a 18mm thick sheet of birch plywood (3/4 inch thick material can be used instead) with my bandsaw. To cut narrow curves I used a Forstner bit of the right size on a drill.
Been that the was only simple cuts, to mark the sheet I have reported the measures with a pencil and a ruled without the necessity to print full dimension drawings.
Step 4: Rabbets and Grooves
To assemble the table together I decided to use rabbet joints, to give it a certain solidity. So, after cutting out all the parts, I have made all the rabbets and the grooves for the T-track with my router and a rabbet router bit.
Step 5: Assembling the Table
To assemble the table I used a strong wood glue and some little nail on the sides, while to fix the table top and the t-tracks I used only screws, so that, if I want, I can change the table to and use a different one.
Step 6: Finishing the Tabletop
To finish the table top I used some coats of floor finish to give it strength and make it smooth.
Step 7: Making the Fences
To make the fences I mounted the already assembled table under my drill press and I drilled all the holes to fix the feather boards, the protection, and the dust collector and to fix the fences to the table. After that I rounded all the corners and finished them with the same floor finish I used for the table top.
Step 8: Making the Transparent Protection
To make the transparent protection I used a piece of thick Lexar. I first printed on paper the shape of it and transferred it into the plastic with a knife and then I cut it out with a coping saw. After that I sanded it with a belt sander to refine the shape and finally I glued it to its holder with some plastic cement.
Step 9: Final Assembling
When all the parts, both wooden and 3D printed, were ready, it was time to assemble all them together to see if everything was working properly. I also check for squareness and collisions, but the final test was to try it and see how it worked.
Step 10: Trying It
To be sure that everything worked perfectly I tested it in many different ways, both in its router table and drill press table configuration. I was very pleased with the many ways to fix and align the working piece and by the efficiency of the dust collection system. I'm very happy it, it works great! It is a very small table, but it fits perfectly my drill press and is very useful when you need a portable router table.
Thanks for checking out the build and don't forget that you can download, for free, the 3D models if you want to build one yourself.
You should also check out the build video, so you can also better see how it works:
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    38 Discussions
    mdog93
    1 year ago
    What is the benefit of using this table on your drill press against a normal drill press jig? Isn't it quite large and cumbersome?
    Looks great by the way, high standard of work. I also did a degree in product design, and am just starting up on my own as designer/maker.
    Guido Vrola Designmdog93
    Reply 1 year ago
    It is not too large nor cumbersome. The fences and/or the feather boards can be removed. If you remove them, it simply becomes a table with a t-track that you can use to fix the pieces in place. But the fences, especially that on the back, are very useful to ensure that the piece is squared with the plane, or if you have to drill a series of holes moving the pice only in one direction...it gives you versatility.
    zanona
    1 year ago
    This table is insane. It's already in my to-do list. I wish we have t-tracks available in Brazil. The pair I got was from Rockler, they are superb. Have to improvise here.
    pemazzei
    1 year ago
    Very nice!
    It is a capolavoro!
    Sorry we don´t have all these great woodworking machines to make one in Brazil.
    Best
    zanonapemazzei
    Reply 1 year ago
    Hello there, I think we do have the machines, but too expensive. O. The other hand, we can do that table with no fancy 3D printer (I wish I had one). There are plenty of ways to do that. If you wish to exchange some ideas or need help, feel free to contact me. Best.
    david.haynes.1571
    1 year ago
    I like the idea and I like to save space-on thing that caught my attention though was your corner clamps. I can't find them and they appear to work well. Where did you get them?
    David
    They are made by Wolfcraft and they are very handy to use. You can find them there on Amazon:
    http://amzn.to/2v2Sny3
    DavidH752Guido Vrola Design
    Reply 1 year ago
    Thank you- I have ordered 3 sets (6). I like your idea of combining tools and will ponder application to my shop as a result. Cheers,
    David
    Yonatan24DavidH752
    Reply 1 year ago
    There are tons of ideas onloine for making your own by the way.
    sperez perez
    1 year ago
    Otro Instructable mas que para hacer una cosa que cuesta 50€ necesitas herramientas y maquinaria por valor de 500€.
    ¿En serio creeis que todo el mundo tiene en su casa un taller de carpinteria?
    The machines that I used for this project worth a lot more than 500€, but this doesn't mean you can not build it with just a handsaw, a drill, and a file. Not having enough tools is just an excuse for not getting up from your chair.
    rvail136Guido Vrola Design
    Reply 1 year ago
    Shhhh...my wife might read that comment. But seriously this was well done. I'm a cabinetmaker and I've not seen much better in some of the shops I've worked in.
    barben
    1 year ago
    Guido, I don't know you but watching your design, and building makes me proud for you. This is a terrific design and so versatile. Sure wish I had seen it before building mine into the work bench. Congratulations on a job well done!
    Guido Vrola Designbarben
    Reply 1 year ago
    Thank you very much, this is a great comment to read that will spur me to continue to share what I do.
    laernmoer
    1 year ago
    this looks great! I want to do the same thing, and I'm glad to see your ible. Looks like you could also turn the router fence around when using it for a drill press to avoid needing to take off the featherboards. Might make it easier to convert between routing and drilling.
    Guido Vrola Designlaernmoer
    Reply 1 year ago
    Thank you! Your observation is correct, and more thatn this, you can also turn the fence upside down, so that if you have to put the fence very close to the drill head, the chuck don't collide with the fence because of the caved part of the fence.
    robbieb1
    1 year ago
    Nice project
