DIY Quilling Tool From Junk Drawer Finds!
1,126
9
4
About: Like Birdz of a Feather, let's flock together to create sustainably. After all, good planets are hard to find! I take my inspiration from everything around me; especially things that might otherwise end up i...
When you're home & garden DIY'ers that repurpose and upcycle as much as we do - whether it's a reno or craft project - it only makes sense that we would endeavour to do the same when it comes to our tools!
While I'm overseeing an accessible bathroom renovation at my Mom's house, I have some time to spare. Hubs bought me a package of construction paper to take with me me so I could try my hand at something I've been wanting to learn: quilling. But after I arrived one morning and cut some strips, it struck me that I don't have an actual quilling tool to get some practice in!
Why wait to buy a quilling tool when you can make one in under 5 minutes with a few everyday items? I sped up the video above so it’s only around 1 minute long, but it really did take less than 5 minutes to complete this project!
Step 1: Raid the Junk Drawers
Being somewhat of a MacGyver of DIY (I get that from Hubs), I raided a few of the junk drawers in my Mom’s house and found just what I needed to make my quilling tool.
Step 2: The Keepers
On my scavenger hunt I found a few of those mechanical pencils that hold thick lead. The prongs of the lead sleeve open up pretty wide, so all I had to do was find something to replace the lead with to create my DIY quilling tool. A trip to the bathroom garnered me a cotton swab (a.k.a. a Q-tip). I also got scissors in the kitchen drawer, a utility knife in the tool box and a seam ripper in my Mom’s sewing box to round it all out.
Materials
Step 3: Let’s Make a Quilling Tool!
The Q-tip is perfect for this tool because the spindle is made of extruded plastic which is hollow through the middle.
To start, cut the ends off the Q-tip, leaving you with the spindle. The ends may be sharp or have some burrs, so sand them down until smooth. I only did one end to save time.
Depress the top of the mechanical pencil so the lead sleeve opens up. Insert one end of the spindle into the sleeve and release (ensuring the smooth end is exposed if you only sanded one end like me). This will stabilize the spindle and give you something to hold onto to as it's cut in the next step.
Step 4: Cut Slit Into Spindle
Grab the utility knife and extend the blade as shown. Insert the point of the blade into the middle of the plastic spindle about 3/8″ from the end. Gently rock the blade back and forth until you cut a slit to the very end (be sure to watch the video to see how this is safely done).
Make sure to only cut through one side; this will create the opening that grips the quilling paper.
Although I cut my opening 3/8" long, you can customize the length of the slit to accommodate the width of any quilling paper! The beauty of this tool is that you can make a few different tips to quill. You can even make it two-sided so you can flip it around, or widen one of the slots for thicker paper :)
Step 5: Widen the Gap and Test
Use the seam ripper to widen the gap so you have a slightly wider slot to accommodate the paper. You should be able to guide the sharp part of the ripper along one side of the cut to shave off a sliver of plastic.
Test the slot out with a piece of quilling paper. If you are satisfied with it, move onto the next step. If not, you can always finesse it or cut the end and start over again.
Step 6: Test and Shorten Spindle
Now shorten the spindle. I cut it to just under 3/4″. An added bonus of shortening the spindle is that it gives you extra material to customize more tips with different length slots if needed!
Put the spindle back into the mechanical pencil with about 3/8″ inside the sleeve and 3/8″ below the prongs. This exposes just enough of the spindle to insert the quilling paper.
Hey, I just realized that even after the transformation you can still call it a Q-tip (short form for quilling tip)! How ironic is that?
Step 7: Take Your New Tool for a Spin!
Insert a piece of quilling paper into the slot and roll it around the spindle. The prongs of the lead sleeve will act as a bumper as you roll the paper to keep it relatively even.
♪ You spin me right ’round baby right ’round, like a record baby, right ’round ’round ’round ♫.
Step 8: A Few Important Questions
Pull the wound paper off right off the spindle and you have your first quilled circle!
How simple was that? Do you see the exclamation mark in the 1st picture? Quill YOU try it out? And the most important question of all: quill you vote for me in the Build a Tool Contest?
Step 9: Subscribe to Birdz of a Feather
Have fun with your new quilling tool!
Get your DIY mojo on and subscribe to Birdz of a Feather's blog here! You can also follow us on Pinterest, Facebook, YouTube and Instagram.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    4 Discussions
    StringGoddess
    8 weeks ago
    I love that you made it entirely from the junk drawer. Well done!
    Thank you StringGoddess! Sometimes it’s easier to be creative by looking at what you already have :)
