DIY Rasengan
22,946
127
9
About: Thank you instructables!!
Hi,Happy Halloween Day to all.This rasengan is ideal for Halloween day.We can see it as a powerful weapon of many superheroes.Here is a simple tutorial for making rasengan at home.Here's a video of if working:-
Step 1: Looks
We can also change the pattern of rotation of the device.Here are some pictures showing it working.
Step 2: Things Required
Things required are :-
  1. Super glue
  2. AA cell
  3. Wires
  4. Small motor
  5. 3V DC motor
  6. CMOS
  7. L.E.D
  8. Gear from old RC car
  9. Round cardboard
Tools:-
  1. Nipper
  2. Pliers etc.
Step 3: Making L.E.D Glow
Take a CMOS and connect the L.E.D terminals to the cell for L.E.D to light up.You can tape it up but if you want to save power then make a push switch making small adjustments.
Step 4: Preparing Cell 2
Just tape up two wires from the two terminals of AA 1.5 volt cell.Don't use BULKY cell (larger size) This cell is for the small motor to run.
Step 5: Joining L.E.D to Motor
Using super glue join the L.E.D part to the top of motor.Make sure that the motor isn't blocked with super glue.I faced this problem :-( if so then open and clean the inner shell of motor and then close everything again.
Step 6: Completing Moving Part
Connect the motor to cell and using tape make the bond and bend the motor slightly to one side.
Step 7: Main Moving Part
Join the cell to the wheel of geared part from old RC car .
Step 8: Strap
Use cardboard or similar material for making its strap and then using duct tape join the geared part of car to the strap.Keep safe distance for the whole setup to run freely with crashing with hand.I had used wheel to increase the distance.
Step 9: Done!
Wear and show it off to everyone.Showing superpowers.It can be the last hour project for Halloween Day.Enjoy!
Please vote if you like it!
Happy Halloween Day!
Thanks!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Classroom Science Contest
    9 Discussions
    ohoilett
    3 years ago
    Just brought all the Naruto nerds (myself included) out of the depths of their mother's basement.
    Gomi no Sensei
    3 years ago
    You should get yourself a hot glue gun. Then you won't need to use 100m of sticky tape.
    NikitaJ3
    3 years ago
    1. Summon shadow clone
    2. Concentrate chakra energy into your hand
    3. Get your clone to perform hand gestures over your hand really fast
    4. Continue for ~5 seconds. Chakra mass in hand at this point should resemble a spinning ball of air roughly the size of a basketball
    5. Dismiss clone
    6. Slap a fool
    cgrrty
    3 years ago
    It would be better to show more abundant,show words and picture.
